Latest: xbluegto
Overall: 3573
Visitors: 156
Total: 156
30: Pictures
41: Home
94: Event Calendar
117: Pictures
119: Event Calendar
126: Home
138: Home
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Preston's Baja Project "Smokey" UPDATED - 10/26/09
The following users give thanks for this topic AzBaja - Sun Jan 18, 2009 07:04 AM, Anonymous - Sat Apr 25, 2009 09:18 PM
Post Post subject: Preston's Baja Project "Smokey" UPDATED - 10/26/09
Posted: Fri Dec 12, 2008 06:32 AM
Well, it's slow going but getting there.
Get her sanded for the most part and prepped for paint.
Here are pics from start to present, MORE TO COME!
Here is a VERY VERY ROUGH idea of what the paint will look like, i can't emphasize the roughness of this sketch, it took me about 2min in Photoshop so bear with me here, it's just to get the idea accross Wink
UPDATE
THANK YOU MR. BAJAWARRIOR (Scott) for helping me install my "new" front end Cool
And there you have it, mounted and ready to, uh well... it's getting there lol.
now it needs some headlight mounts,paint, and some metal to cover the rust up under the hood. Cool
Post Post subject: Re: Preston's Baja Project
Posted: Fri Dec 12, 2008 06:47 AM
cant wait.
are you going to do anything about the surface rust that you have and what do you do with all of those spots. do you use bondo or what.
Posted: Fri Dec 12, 2008 06:54 AM
going to bondo the right front 1/4 panel where the previous owner decided to half a** it, which resulted in his bondo job cracking thus cracking the paint, as for the rust: Grind out, Cut, Weld, Smooth, Paint over, DONE. Cool
i have some sleepless nights ahead of me to get this thing done before Bug Infestation IV Shocked
Posted: Fri Dec 12, 2008 07:58 AM
Are you gonna get busted for impersonating the po-po with that paint job? Laughing
Lookin' good man. Keep it up.
Posted: Fri Dec 12, 2008 03:42 PM
nah, as long as it doesn't say POLICE anywhere i'm fine Cool
JumpinBruceB
JumpinBruceB
Posted: Fri Dec 12, 2008 06:24 PM
Lookin good im not looking forward to all that sanding on mine but as im sure i will see when you get this baby painted it will be way worth it
Posted: Sat Dec 20, 2008 05:00 AM
Well, just got a "new" one piece front end *Thank you DONT* Cool
so now my hood/fenders/nose cone are useless Very Happy
Well i feel good! i've always kind of liked those front ends, and now i have one!
a bit more work to make it happen but it will be well worth it Cool
Posted: Mon Dec 22, 2008 08:05 AM
Wow that Black and White looks real nice...or did you photoshop it?
Posted: Mon Dec 22, 2008 05:47 PM
Laughing Laughing Laughing 10 second photoshop there. just to get the idea Rolling Eyes
Post Post subject: Re: Preston's Baja Project UPDATED - 1/1/09
Posted: Thu Jan 01, 2009 10:38 PM
Bump for the update! Cool
SuburbanLegend
SuburbanLegend
Posted: Fri Jan 02, 2009 06:39 AM
Nice job on the gas tank and fiberglass fabrication. That's very similar to what I want to do with the gas tank on my project.
I'm curious to see how you connect and seal the fuel filler neck to a fuel cap Question ...
Posted: Fri Jan 02, 2009 06:34 PM
We're going to take the orginal fuel filler from the front end we cut off, and mount it to the end of the hose whitch will be mounted to a bracket under the hood, the hood already has a fuel hole cut in it so all i have to do is reach through. nothing is welded to the car, Scott designed all the mounts for the hood/gas tank to be bolt-on so they could be removed later on if needed Cool the gas tank is sitting on a metal lip which has the orginal mounting tabs bolted to it, so it sits like it was factory installed.
Posted: Mon Jan 12, 2009 07:50 AM
UPDATE!
paint should begin tomorrow. doors will be done, we shoot the black on friday hopefully.
Here's a photoshop of what it will look like, after 9000 photoshops trying to figure out what i wanted my paint to look like i've finally decided on this scheme:
Sun visor and rear cowl will be white as well.
Posted: Wed Jan 14, 2009 08:44 AM
1/13/09 UPDATE
pretty much sanded down and ready for paint, still have more sanding to do, mounted the light tabs and mocked up some offroad lights. IT'S ALMOST DONE!
Cutting and Grinding around the stock fuel filler to make it fit under the new hood.
Finished product
More pics to come at the end of the week!
Post Post subject: Preston's Baja Project !!!UPDATED!!! - 1/13/09
Posted: Wed Jan 14, 2009 04:07 PM
Looks good Preston, I am glad you could put that front end to good use. I was bummed when my fuel cell hit those strenghtening ribs.
4 Admin_AzBaja 5712 Baja Bugs on Wiki need...
1568 mufasavnvmc 903616 Re: what did you do to...
285 MusicManiac 218970 Re: Baja sightings
0 Northmountainauto 267 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1516 Baja hiding in Chandle...
