Visitors: 248
Total: 248
02: Home
07: Pictures
21: Home
22: Home
48: My Account
50: Pictures
51: Pictures
52: Pictures
53: Pictures
54: Pictures
55: Pictures
57: Pictures
58: My Account
81: Pictures
103: My Account
110: My Account
129: Event Calendar
139: My Account
140: My Account
141: My Account
142: My Account
143: My Account
145: My Account
146: My Account
147: My Account
149: My Account
150: Baja Forums
151: Pictures
154: Baja Forums
168: Baja Forums
171: My Account
173: Baja Forums
175: My Account
176: My Account
177: My Account
178: My Account
179: My Account
180: My Account
182: My Account
183: My Account
184: My Account
186: My Account
187: My Account
188: Baja Forums
189: Baja Forums
190: AMAZON.com
191: My Account
192: My Account
193: My Account
197: AMAZON.com
198: Home
199: Baja Forums
202: Baja Forums
203: Pictures
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: Baja Forums
209: AMAZON.com
210: Baja Forums
212: Baja Forums
213: Baja Forums
214: AMAZON.com
215: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
222: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
228: My Account
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: My Account
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- voltage?
voltage?
nube_w_1970baja
nube_w_1970baja
Post Post subject: voltage?
Posted: Fri Dec 19, 2008 05:22 PM
the last couple days i've been having the problem of: sometimes, my car starts and other times it does. when it doesn't, the starter solenoid won't even pop/click.
volt meter almost always reads 15 volts...
i replaced the battery under warranty from walmart last night (was about 8 months old). this battery is supposed to be used in trucks, it's bigger than the battery for my 97 buick lesabre...
is my battery toast or is there something else like the voltage regulator that is done for?
i do have auxillary lights, but rarely use them.
MusicManiac
MusicManiac
Post Post subject: Re: voltage?
Posted: Fri Dec 19, 2008 05:31 PM
Have you had the starter tested? I was having a somewhat similar problem not too long ago. Did you check the ground straps? I have limited knowledge for sure, but when my starter wouldn't click or anything, it was due to a bad ground strap. It looked good still, but the eye that the bolt goes through had been torn on one side and wasn't making a solid connection. I ended up replacing the ground strap and even though the starter tested fine at Checker, I replaced it because I couldn't figure anything else out. Turns out that the starter had shorted itself out somehow since the ground hadn't been connected. Worth looking at at least. I am sure someone else will stop by soon though with a more knowledgable answer. Good luck!
nube_w_1970baja
nube_w_1970baja
Posted: Sat Dec 20, 2008 05:39 AM
nope, everybody is busy
bajaboi727
bajaboi727
Posted: Sat Dec 20, 2008 01:39 PM
TRY KNOCKING ON THE STARTER SYLONOID WITH A HAMMER A FEW TIMES THAN TRY TO START IT!. I was having the same problem.
just my .02 Razz
KooK
KooK
Posted: Sat Dec 20, 2008 02:53 PM
Believe it or not, that will work a lot of the time, but only few a week or two. Sounds like the starter solenoid is trying to up and leave, normally I'll just replace the whole starter because for these cars, they're cheap anyway. When you reinstall one, I always recommend (like MusicManiac mentioned) a grounding strap. Even though the starter is grounding itself through your transmission, I'd put a strap from one of your starters mounting bolts onto the body of the car. This will provide both a better ground for the starter and the few electrical pieces of the engine as well.
Cookie
Cookie
Posted: Sat Dec 20, 2008 05:35 PM
You can bench test your own starter using jumper cables a working battery and a screw driver. First take off the starter put it in a vice or stand on it if it works it can move around. on the battery side set up jumpers + to + and - to - put the positive side on the top bolt on the back of your starter the one that goes to the batery. Ground it by hooking up the - to the starter body. take a screw diver to the wire plug that goes to your ingnition and the battery it should pop click and turn on.
Posted: Tue Dec 23, 2008 10:04 PM
Every once in a while (usually when I'm going to try and start it after sitting a month or so) mine just does nothing when turning the key, but I've found that if I just jump the wires with a screwdriver to engage it, I can use the key from then on, at least until the next time it sits forever. I've disasembled the starter before and cleaned it (there was a ton of sand in it) but I should get new one someday if I'm going to use it regularly.
On another bug I had, I had a lot of problems with the starter working fine when cold, but hot it wouldn't turn the engine over fast enough to start. Ended up being a bad starter which I think was caused by excessive friction from having all the rings shot and scoring up the piston/jugs. I used that engine as a core for the one I have now.
Edit to add: MAKE SURE IT'S IN NEUTRAL!
DutchBug
DutchBug
Posted: Wed Dec 24, 2008 12:32 AM
Try the hammer, I bet on it that that's it.
nube_w_1970baja
nube_w_1970baja
Posted: Wed Dec 24, 2008 12:58 AM
yeah, i ended up taking it to auto zone and buying a new one the other night.
how is it when you take it apart and rebuild it? worth the time and money?
Athlon64
Athlon64
Posted: Fri Jan 16, 2009 10:46 PM
It is if you don't need a armature or the windings, but if its the brushes or the soleniod and bendex then yes, Alot of times if the starter doesen't even click then its the solenoid, check the crank signal to see if its going thru the neutral safety swich if you have one, make sure your getting a postive crank signal on the crank wire from the ignition swich, or button. If clicks, but the motor doesen't run it can be three things, #1 solenoid. On the bottom of the soleniod the motor power wire hooks up there, get a test light and when you go to crank it make sure you have power comming out of it going to the motor. #2 Or the brushes have worn down and one of the brushes has lifted off the armature commutatior and the motor won't run. #3 or one of the brushes is stuck and not contacting, sometimes tapping it with a hammer will loosen a stuck brush and it will crank then. if it doesent click at all and you have power, then the bendex drive piston in the soleniod has rusted stuck, tapping it will free it up so it will move again and start. and of coarse don't forget to check the grounds to the frame and engine block. Make sure you have 2 grounds 1 to the engine block and anouther one to the frame. If you dont have a good ground to the frame, it can pitt the CV joint jornals or ujoints and pitt the gears in the transmission if you have rubber engine mounts electricly seeking a ground thru them when lighting or outher body grounded loads are turned on. And lastly make sure you have a big enough wire from the battery to pos+ and from batt- I would use at least 1 ougt wire for bouth. the stock vw uses a group 42 battery 480 cca and you can get a group 24 750 cca battery but it is longer and may not fitt if you have a stock battery box.
I have seen what bad grounds do to ujoints and trans gears, eats them right up! The more lights and crap you have on, the worse it gets
30 year triple Master EVT, ASE, heavy truck, automotive certified emergency vehicle mechanic
abcprint
abcprint
Posted: Fri Jan 16, 2009 10:58 PM
just change the whole starter and save yourself alot of pain.......
66 Baja
Posted: Sat Jan 17, 2009 05:39 PM
make sure you put in a realy, not hard put your key flips the realy next to the starter. You can also run a bigger wire to so less voltage drop to the silonoid.
No new posts VW Volkswagen & Baja Bug General Discussion COIL VOLTAGE 3 cheapbeetle 2221 Re: COIL VOLTAGE
 Sat Sep 06, 2008 04:38 PM
cheapbeetle View latest post
No new posts VW Volkswagen & Baja Bug General Discussion VOltage regulator? 6 orbot 3758 Re: VOltage regulator?
 Wed Aug 13, 2008 11:32 PM
sandshark View latest post
