Visitors: 106
Total: 106
13: Event Calendar
34: Home
41: Event Calendar
54: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Npetric's A-arm baja
1 2 3 ... 8 9 10 11
The following users give thanks for this topic Anonymous - Sun Apr 26, 2009 02:13 PM
Post Post subject: Re: Npetric's A-arm baja
Posted: Sun Dec 07, 2008 08:02 PM
what kinda trans are you running..?
npetric
npetric
Posted: Sun Dec 07, 2008 09:20 PM
A broken one Laughing
Its a Fields built 3-speed auto trans. I blew out the torqur converter seal again and puked all the fluid out and burned up the automatic section of it. It seems as though there was a problem with the torque converter and it is destroying seals. I found a place in town called BSE performance who has built severalof these units. I am dropping it off this week to get built and I will be good to go!!!
67 a-arm baja honda 3.0
TwistedMetal
TwistedMetal
Posted: Mon Dec 08, 2008 12:35 PM
That is so f*cking awesome. Tell her she's a badass! I love seeing that stuff...
Nose-shift 091 for sale. 6-rib and beautiful! Type 2 CVs and shafts included... $500
mk19gunner
mk19gunner
Posted: Mon Dec 15, 2008 02:50 AM
How did you do that? Is it all fab or is there any kit stuff to get started?
TwistedMetal
TwistedMetal
Posted: Mon Dec 15, 2008 02:55 AM
OK...PLEASE tell me you read the whole thread before asking that...
JumpinBruceB
JumpinBruceB
Posted: Mon Dec 15, 2008 08:16 PM
DOH!!
mk19gunner
mk19gunner
Posted: Mon Dec 15, 2008 09:05 PM
nope, I'm new to chat forums and got the last page as a link from some other dumb questions I asked in another link or thread or whatever you call these little topic things each new post or topic is. I did figure out about the previous page thing after posting and would still like a concise parts list for the a-arm setup and to know if npetric could build another front end assembly and what it may cost.
twisted metal thanks for trying to make me feel dumb, I'm sure your something else with a key board and your net-fu is far better than mine.
TwistedMetal
TwistedMetal
Posted: Mon Dec 15, 2008 09:28 PM
Wasn't trying to make you feel dumb, I was trying to make you feel lazy.
I can tell you atleast one thing: You aren't going to get ANYWHERE with a mouth like that.
The 2nd thing I'm going to tell you is that NO ONE is going to go through that much research and work only to hand it over to the first chump too lazy to read the prior 8 pages of a "Here's how I did it" thread.
And I have no kungfu, what I DO have is a desire to learn and now spend every waking minute(and there's a lot, I'm an insomniac) studying instant centers, polar moments, kingpin angles, anti-dive, static loads, on and on.
Try it...you might like it.
And now that THAT'S all off my chest, where are you in your build and what are you trying to gain? Perhaps it's too big of a job for you to atempt at this point. That's NOT meant to be an insult in the least. I've been building rock crawlers and tube chassis for a decade and the desert car stuff is mind boggling! I tried to jump right in and nearly drowned. I am still trying to dump everything I THOUGHT I knew and am starting all over as a newbie. That's hard to do with any self pride from previous builds, but no place for pride when starting new. Suck it up and READ READ READ, but then, go out to the garage and build, hope it fails so you can learn a little, then rebuild!
mk19gunner
mk19gunner
Posted: Tue Dec 16, 2008 12:33 AM
I do a lot of welding with arc and wire feed I've got a 70 baja that I'm trying to decide which way to go with the front end now its stock so I'll be cutting the frame head off wether its for a modified beam or swing arm any way. as far as asking about a list, I try to keep track of things like that and don't mind sharing what I've learned from my experience. thats why I enjoy things like this
TwistedMetal
TwistedMetal
Posted: Tue Dec 16, 2008 12:58 AM
Well...when you're ready to get REALLY humbled...go visit
www.race-desert.com .
Don't say much or ask, just go to the Shop section in the forums and start reading. Give me a minute and I'll even post some links up for you to check out. There's some sick Baja Bug/A-arm threads up. There's also a difference between the sand cars like Npetrics and a desert race car, so you'll kinda need to see where you're at and what you want. Honestly, it probably doesn't fugging matter. I CONSTANTLY try to tell myself that, but I get so caught up in all the little techy details...no wonder I burn out on things so fast! But MOST cars are set up like Petrics. They maintain a consistentcamber degree throughout it's travel cycle, while others(the way I'm doing mine also) actually change quite a bit to grab max traction and protect the sidewalls under hard cornering/bottom-out, and yeild a minimal scrub patch. And NO, 2 months ago I had no idea what all that crap meant either!
Npetric...sorry if I'm hijacking your thread here! Yell, if so!
TwistedMetal
TwistedMetal
Posted: Tue Dec 16, 2008 12:59 AM
Don't say much or ask, just go to the Shop section in the forums and start reading. Give me a minute and I'll even post some links up for you to check out. There's some sick Baja Bug/A-arm threads up. There's also a difference between the sand cars like Npetrics and a desert race car, so you'll kinda need to see where you're at and what you want. Honestly, it probably doesn't fugging matter. I CONSTANTLY try to tell myself that, but I get so caught up in all the little techy details...no wonder I burn out on things so fast! But MOST cars are set up like Petrics. They maintain a consistent camber degree throughout it's travel cycle, while others(the way I'm doing mine also) actually change quite a bit to grab max traction and protect the sidewalls under hard cornering/bottom-out, and yeild a minimal scrub patch. And NO, 2 months ago I had no idea what all that crap meant either!
TwistedMetal
TwistedMetal
Posted: Tue Dec 16, 2008 02:55 AM
Good design, but kinda ugly...
race-dezert.com/forum/...hp?t=39938
Not bad, but not as effective...but I doubt he'll be hitting speeds where all that will become necessary!
race-dezert.com/forum/...hp?t=51642
mk19gunner
mk19gunner
Posted: Tue Dec 16, 2008 07:50 AM
thanks
70bug
70bug
Posted: Fri Apr 24, 2009 04:10 PM
npetric any new pictures of your projects?
npetric
npetric
Posted: Fri Apr 24, 2009 04:57 PM
Unfortunately I do..... Crying or Very sad
We had a serious house fire and guess what was in the garage.......
Im gonna rebuild...but insurance doesnt cover the car or all the extra parts I had. They are giving $2000.00 for all my parts....nothing for the car or dirt bikes...
Oh well life goes on, my wife, myself and the dogs are all safe and we are starting to rebuild...
The fire started in the garage. I had been welding about hour and a half before it started. Something smoldered for a long time somewhere under one of my work benches on an expansion joint in the concrete and I dint catch it. I was in the garage working on stuff for close to an hour after I hung up the welder. PLEASE BE CAREFUL when working in your garage.
If you have an attic ladder make sure there is some fire rated drywall on the door of it. Had mine been this way the fire would have stayed in the garage. Because mine wasnt covered...I dont have a roof and only have 1/2 a house....
1 2 3 ... 8 9 10 11
5 Admin_AzBaja 7118 Baja Bugs on Wiki need...
1568 mufasavnvmc 1012439 Re: what did you do to...
285 MusicManiac 244423 Re: Baja sightings
0 Northmountainauto 1695 Shop Baja
