Visitors: 132
Total: 132
32: Pictures
41: Event Calendar
46: Pictures
68: Pictures
72: Pictures
83: Contact Admin
84: Pictures
95: Event Calendar
101: Pictures
111: Pictures
112: Event Calendar
131: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- '65 BAJA
'65 BAJA
bajaboi727
bajaboi727
Post Post subject: '65 BAJA
Posted: Thu Dec 11, 2008 01:30 AM
Anything special I need to worry about? Anything that make them not so "wanted"? Going to go look at one tomorrow it's a project car but I was just wondering. Nice thing= NO EMISSIONS Smile
Post Post subject: Re: '65 BAJA
Posted: Thu Dec 11, 2008 01:41 AM
Swingaxle rear is, for some, the downside. Others love that. IRS can be installed with a little bit of fabrication to weld in the pivots for the arms.
Original engine was 40hp 1200cc. Look at the engine. If the carb is a single Solex 28PICT, it is still the original motor. If it has aluminum intake manifold ends with 2 tubes at each head, it has a 1600+.
Original electrical was 6 volt. Good chance both have been upgraded. Look at the battery. If it has 3 caps, it is still 6V. Not a big deal to upgrade to 12V.
Probably more of a concern is rust, as with any 40+ year old car. Even in AZ.
Posted: Thu Dec 11, 2008 02:05 AM
i love swing my swing axle
got camber?
haha.
Posted: Thu Dec 11, 2008 02:32 AM
yeah i love my irs i dont think that i would get a swing but whateva
and good point on 6v and 1200cc engine
Posted: Thu Dec 11, 2008 02:38 AM
you got the good front suspension, king and link pin front end.
you can do alot with that.
you gonna run dunes or trails?
Posted: Thu Dec 11, 2008 03:52 AM
maby
bajaboi727
bajaboi727
Posted: Thu Dec 11, 2008 03:17 PM
both, and it has a a 1600 or bigger...yeah the swing axle kinda sucks Sad il make her work Smile
Thuff
Thuff
Posted: Fri Dec 12, 2008 05:22 AM
Can you make a custom front torsion housing that will except the link pins so you don't have to cut out the front end of your car?
Posted: Fri Dec 12, 2008 05:57 AM
Uuuummmmmmm, Thuff...
He already HAS King & Link front suspension....
:~P
Actually, if he had Ball Joint and wanted K&L, Tweeds USED to make K&L arms for BJ front ends. They don't make them now. But since he has K&L, he doesn't need to convert.
Posted: Fri Dec 12, 2008 05:58 AM
:~P
Posted: Fri Dec 12, 2008 06:13 AM
It will be fine. The worst draw back is the door locks that are noted for unlocking an the door opening. Get some good seat belts. Drive it and change what BUGs you the most. See you in the desert. Drve it an make sure it does not pop out of any gear. You could do a quick saftey check to see what it needs right away.
Posted: Fri Dec 12, 2008 06:25 AM
Guess I'm stammering...LOL
Something weird going on with posting right now. Each time I post it tells me that the line ""posting" is not an object" ????
My 65 got flogged into death by fatigue. The doors never once popped open.
Posted: Fri Dec 12, 2008 06:52 AM
It only happens when the aluminium striker plate gets worn down.
opps
bajaboi727
bajaboi727
Posted: Mon Dec 15, 2008 04:34 AM
got a 67, the one on CL in peoria for a grand thats a 66 is the one and its a crap can to say the least.
4 Admin_AzBaja 5575 Baja Bugs on Wiki need...
1568 mufasavnvmc 889149 Re: what did you do to...
285 MusicManiac 215820 Re: Baja sightings
0 Northmountainauto 42 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1092 Baja hiding in Chandle...
