Latest: BlackIrish05009
Overall: 3574
Visitors: 137
Total: 137
08: Event Calendar
16: Event Calendar
53: Event Calendar
67: Event Calendar
68: Event Calendar
79: Event Calendar
81: Event Calendar
91: Event Calendar
103: My Account
110: Event Calendar
126: Event Calendar
133: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- at wits end please help$$$$
nube_w_1970baja
nube_w_1970baja
Post Post subject: at wits end please help$$$$
Posted: Sat Dec 06, 2008 06:42 PM
i'm not sure what else i can do. still having back-fires, can't accelerate, can't get out of 3rd gear...
i need help figuring this out.
yesterday i went to Dougs Bugs and Bunnies. had them check/adjust the valves (40$). started heading out, didn't get 1/2 mil down the street before heading back with the same problem. still back fires and doesn't accelerate. co2 meter said everything is good, not lean or rich.
might be an ignition thing. WTF!!!!
so i leave, heading to north phx on the 101 at rush hour to pick up bearings and seals... feel like shooting myself, no gun....
still popping and hissing and back firing, actually worse after readjusting the valves. call back dougs bugs. it might be the coil, condenser or wires. still contemplating shooting myself.
get a new coil, and condenser. installed..
nothing is changing!!! only getting worse.
i need help from anyone that can help. i can ATTEMPT to drive to you, but no gurantees. call me at 480-338-2714, heading to mesa in a while.
THANKS, jeff
KooK
KooK
Post Post subject: Re: at wits end please help$$$$
Posted: Sat Dec 06, 2008 08:04 PM
Does it start right away or does it wait for the engine to get cold?
What are you running for carb(s) do you have?
How long has it been doing this and did you make any changes prior to this happening?
Lastly, Anything else done fuel/ignition wise to this engine that's aftermarket?
It almost sounds like the distributor isn't lined up correctly and either retarded itself or wasn't installed properly.
Posted: Sat Dec 06, 2008 10:20 PM
The timing was retarded big time, I adjusted it and set the carb it its all good now. Cool
Posted: Sat Dec 06, 2008 10:25 PM
Very Happy YOU DUH MAN,,,,
KooK
KooK
Posted: Sat Dec 06, 2008 11:25 PM
That's funny, you can tell whe I change thoughts mid-sentence Laughing
Did you have to reinstall the distributor or did it just work its way loose and twist around like crazy?
nube_w_1970baja
nube_w_1970baja
Posted: Sun Dec 07, 2008 06:52 AM
just twisted the dist. adjusted the carb.
renewed my faith today!!
if anybody ever needs a ride or gets stuck in the boonies.
or needs a ride to pick up parts...
thanks daryl, what type of beer do you like?
Posted: Sun Dec 07, 2008 07:25 AM
Landshark Lager. Cool
Posted: Sun Dec 07, 2008 07:27 AM
On a VW motor the disrtibutor will only from in one way. It has an offset notch in the distributor drive gear.
KooK
KooK
Posted: Sun Dec 07, 2008 05:26 PM
Weird, that's nice to know.
Glad to hear you got it fixed!
Posted: Mon Dec 08, 2008 05:50 AM
Just like a mopar, it's got a slot. you dizzy can be in phase or 180' out. as long as the cam and gear was set up correctly when the engine was built.
If you MSD box is going bad it will do the same thing...Thats if you run a MSD
KooK
KooK
Posted: Mon Dec 08, 2008 06:25 AM
Wait, my mopar doesn't have a slot for the distributor like that...
Posted: Tue Dec 09, 2008 12:52 AM
You most not drive a true classic mopar but one of them fake wana be mopars...
KooK
KooK
Posted: Tue Dec 09, 2008 04:43 AM
What about the 6 cylinder no spark plugs mopar?
Wink
Posted: Tue Dec 09, 2008 01:09 PM
true mopar 6 bangers lean to one side...:)
Posted: Tue Dec 09, 2008 04:20 PM
Call Daryll??? Laughing
Glad to hear you got it squared away. I'm no beer nut (ha!)- I've never heard of Landshark Lager. Confused
