Latest: jor_dang420
Overall: 3597
Visitors: 68
Total: 68
14: Pictures
19: My Account
28: Event Calendar
39: Event Calendar
46: Pictures
47: Event Calendar
49: Pictures
68: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- walmart special
walmart special
Post Post subject: walmart special
Posted: Thu Dec 04, 2008 01:23 AM
i was thinking of getting this for my car and building a custom speaker thing in the back were the seats is and putting 2 speakers there and to in the front and then were good to go. i think that is a far price for what you get. and i dont need a whole lot for my bug anyway. all i need is something to get me by.
www.walmart.com/catalo...d=10569324
Post Post subject: Re: walmart special
Posted: Thu Dec 04, 2008 01:25 AM
www.walmart.com/catalo...d=10569326
or this one to bolth look pretty good.
i just have no idea how the heck to hook it all up. and make it work lol.
KooK
KooK
Posted: Thu Dec 04, 2008 01:35 AM
I tried that once, I still couldn't hear crap. Which goes to show you that the only music you need is whatever comes out of your tailpipe Smile
But seriously, Bajas are loud, good luck Laughing
Posted: Thu Dec 04, 2008 01:42 AM
wow really even with like 4 speakers
dang
well does any one kknow how to hook one up without a harness
KooK
KooK
Posted: Thu Dec 04, 2008 01:49 AM
If worse comes to worse and you need it a bit louder, you can always get a cheap amplifier.
But once you get the instructions it's pretty simple to do. All you need is a 12v feed, an ignition on feed, a ground, a headlight feed (if you want it to dim at night), and two wires for each speaker. The speakers will have a small terminal and a large one, the small one is negative and the large one is positive.
Posted: Thu Dec 04, 2008 02:07 AM
ok kool
im thinking about getting it all i need is something that is not the greatest thing on earth and i can always get a amp like you said. i think im goijng to get it .
Posted: Thu Dec 04, 2008 02:15 AM
do you have to have a fuse for it and what do you hook up the stereo deck to wiring wise.
KooK
KooK
Posted: Thu Dec 04, 2008 02:29 AM
Normally the deck itself comes with a fuse in it, but I wouldn't 100% rely on it. I'd probably run a 10 amp fuse for the ignition-on source and a 15 amp fuse for the 12v constant.
As far as what you hook it up to exactly, I'm not sure, somebody here can probably fill in on that one. I'm sure considering your wiring harness has been modified that you're going to have to test a few things out for yourself. Do you have a voltmeter, a multimeter, or anything along those lines?
Posted: Thu Dec 04, 2008 02:38 AM
volt
i thiknk
KooK
KooK
Posted: Thu Dec 04, 2008 03:11 AM
Here's what I would do, under your hood, I would take the voltmeter and see if any of the open terminals that you can plug wires into, have a constant 12v connection all the time. Try to avoid sharing the terminals with other wires if possible. Once you find a good one, use that for your 12v main power going to the radio (instructions that come with the radio should tell you which wire this is). Do the same for the ignition on, just keep clicking the key from off-on to find that one. The ground, I'd probably just find somewhere under your hood that you can ground that wire to. After that, plug in your radio, turn your key on and make sure it's working. Mount the deck somewhere and go ahead and mount your front speakers where you want them. Run wiring to the front two speakers from the deck (once again, your instructions that come with the deck will tell you FL, FR for front left and front right, signifying - and + for negative and positive. After you have the front speakers hooked up, test it again to make sure you have sound, probably just pop a CD in.
After that, if it were me, I'd probably keep playing music as I mounted the rear speakers and ran the rear wiring up to the deck, shut everything off as you actually start to wire it, turn it back on when you're done and test it.
It's just 3 main wires and 2 wires for each speaker, fairly simple to do, once you get into it I doubt you'll get lost.
Posted: Thu Dec 04, 2008 04:06 AM
ok kool i have some swithces that i dont use and they have a 12v connection all the time when the car is on. so waht i was thinking is just connecting it that then when i want the radio. flip the switch and bingo i got radio.
KooK
KooK
Posted: Thu Dec 04, 2008 04:12 AM
Just remember, if you lose all power to the radio at any point, you'll lose all your presents and your clock will reset. But if you want to use a switch for your ignition-on source, that'll work.
Posted: Thu Dec 04, 2008 04:27 AM
i think that im just going to do that.
DutchBug
DutchBug
Posted: Thu Dec 04, 2008 02:30 PM
I hooked my amp up straight to the battery with a fuse (10 amp I think not sure).
I bought an old 90's car amp from the flee market for 5 euro's.
It has the tulip conections and I hook up my nokia to it.
I hate to have to listen to the radio anyway.
I already had some speakers in the car when I bought it so bought some cables and connected them. It works great and it gives a lot of sound quality and volume for 5 euro's.
So if you have no use for a radio, need a lot of volume (I do with the noise my baja makes) and don't have a lot of money its an option.
I'm sure the sound is better than most 100 buck radio's that are for sale.
KooK
KooK
Posted: Thu Dec 04, 2008 05:02 PM
You forget, 100USD is like, 3 euros Wink
No new posts Events and Get Togethers World Wide Special run with a ride along/ride alongs 12 BugZyla.com 6655 Re: Special run with a...
 Tue Jul 04, 2006 01:51 PM
tsutt View latest post
