Visitors: 271
Total: 271
22: Pictures
23: Pictures
25: Pictures
64: Event Calendar
65: Event Calendar
131: Event Calendar
133: My Account
137: My Account
138: My Account
139: My Account
140: My Account
141: My Account
142: My Account
143: My Account
144: My Account
145: My Account
147: Home
149: Home
150: Event Calendar
154: Baja Forums
173: Baja Forums
180: Pictures
181: Pictures
187: My Account
188: My Account
189: My Account
190: My Account
191: Baja Forums
192: Baja Forums
194: Baja Forums
197: Baja Forums
198: AMAZON.com
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: Event Calendar
210: AMAZON.com
212: Baja Forums
213: AMAZON.com
214: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
225: AMAZON.com
226: Baja Forums
227: AMAZON.com
228: Baja Forums
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: Event Calendar
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: Baja Forums
252: AMAZON.com
253: Baja Forums
254: AMAZON.com
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: Baja Forums
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- turbo efi baja
turbo efi baja
KooK
KooK
Post Post subject: Re: turbo efi baja
Posted: Mon Dec 01, 2008 04:20 AM
If you have any questions on anything other than, what turbo you should buy, I'll help you out as much as possible. But until then, I'm shooting in the dark because I've never really given a turbo a second thought on my Baja. I was probably going to end up suggesting a TD05H 18g.
madman74
madman74
Posted: Mon Dec 01, 2008 05:02 AM
Hey thats me! Anyways if you are looking for under 200 hp you wont need much . I would build a 1915. Counter weighted crank, I beam or h beam rods, 044 heads with 40x35.5 valves dual springs, Cb performance cam # 2208 with big base lifters. If you are going to run a carb you will need a 40 or 44mm dellorto (No webers) you will need to buy the turbo emulsion tubes and the venturi rings. As for exhaust I would look for something fairly thick walled in a stinger type exhaust. 1.5" tube maximum. As for the turbo I would find something with a t-3 flange, I think the ideal turbo would be a IHI from a 87-88 ford turboucoupe. I would also buy the intercooler from the same car. This combo at 15psi should put out around 230 hp at the flywheel. The turbo is pretty maxed out at 18-20 psi but if you go with water injection I could see 260 hp at the flywheel at 18-20 psi.
Oops it broke!
Posted: Mon Dec 01, 2008 05:20 AM
See, I told you he was a turbo efi guru. Mr. Green
Neander
Neander
Posted: Mon Dec 01, 2008 05:53 AM
haha thats for sure. are there water injection kits for vw engines? (im kinda new to turbos in case you didn't notice Smile )
KooK
KooK
Posted: Mon Dec 01, 2008 11:55 PM
What water injection does is, it's sprayed before the throttle plates and acts as a catylis, it will cool down your intake temps and act as a higher octane, allowing you to run more boost with more agressive timing. At the power level, I doubt you'd need much more than a 200cc jet running at a proper spray pressure so a one gallon tank should last you awhile. Just be careful because I have seen people gunk up non-stainless valves, and always use distilled water. There are some cool kits out there too, I know if you run an AEM, its controller has an output that will feed into a stand-alone telling it when it is low/out of water and will actually lower your boost level and retard your timing so you don't cause damage to the engine if your kit runs out. Although an input like this would be easy to duplicate on your own, the fact that they offer it in a kit like that I think it pretty cool.
If anybody ever finds any of my information incorrect, please correct me, I'm not always right.
Also, I try to stay away from I-beam rods on road cars, probably stick with a forged H-Beam and it will be more than what you're looking for.
VIN70
VIN70
Posted: Tue Dec 02, 2008 12:19 AM
why no webers??
KooK
KooK
Posted: Tue Dec 02, 2008 12:38 AM
This is just a guess, but I'm going to say that webers cannot support forced induction due to their design. Completely off the wall guess, I'm very, very, very new to carbs here.
Neander
Neander
Posted: Tue Dec 02, 2008 01:06 AM
would water injection be better than say 100% methanol injection because of the cooling factor? or is methanol a totally different deal?
madman74
madman74
Posted: Tue Dec 02, 2008 03:08 AM
hey guys, yes Kook is right on about the water injection. And yes you can do meth injection also but more expensive. I like using 1 bottle of isopropal alchohol to 1 gallon if water.
As for turboing a weber it can be done, but the carbs require alot more work, Floats, drilling some passages, seals, all the stuff that dells have done allready.
Oops it broke!
KooK
KooK
Posted: Tue Dec 02, 2008 05:26 PM
Well back when I was doing research on the deal, here's what I came up with. From what I found out the specific heat of water is significantly greater than the specific heat of methonal, meaning water has a harder time changing temperature and will provide a greater cooling effect than methonal. Now some people will try to argue the point that injecting the methonal alone will raise octane, while this is true, its gains are minimal. You figure pure methonal is around 100 octane, in a boosted application for 220whp, you'll be running 450cc injectors (at 40-45psi) with a 90+% duty cycle and for the methonal injection, you'll be running a single 200cc jet at probably 30-35psi. Disregarding the pressures in this situation and going off of the flow of the fuel injectors and methonal jet, you'll be running pump gas (we'll say 91 octane) through all 4 injectors which can equal out to 1800cc of fuel/91 octane being injected while spraying 200cc of methonal/100 octane.
So what it all comes down to is you're running a ratio of 9:1 with these fuels. 9 parts 91 octane and 1 part 100 octane which will result in minimal actual octane increase. So really the only reason to run these kits would be for the cooling effects to which we've already discussed that water has a greater cooling effect. If you want the data I can find it, but I believe the specific heat of water was around 4 and the specific heat of methonal was like, 2.3.
Cliffs: You can run methonal injection, but you'll result in better gains from running straight water.
Neander
Neander
Posted: Wed Dec 03, 2008 12:12 AM
yea i was just wondering about that, im probly goin to get the aem water injection kit with the 1 gallon tank. its like $400 i think...
Thuff
Thuff
Posted: Wed Dec 03, 2008 01:44 AM
By the way, if you were running the stock turbo up to 25psi, you were probably pushing it further than what it should have been. You'll still make more power up to a point, but you'll be throwing in tons of hot air, you're going to start detonating it up top, you're going to heat soak faster, and all this other fun stuff. In 1988 the turbo coupes were rated at 190hp and the 5spds should have had 14.7psi, the automatics were detuned and were rated at 150hp at almost 10psi.[/quote]
It is pretty easy to get 25psi out of the stock turbo. we just put a stage 3 compresser and exalust kit in it and changed the out the waste gate. and did a little bit of exaust porting. Sure was fun car though.
I am sure it was over clocked a bit since when i pulled out of camp verde heading to phoenix if i stopped at the top of the hill just out of CV, it was a nice shade of bright orange. As far as the 190 horse power the 87's were rated the same but would only get about 12 pounds of boost. at least that is what my buddy's got. Mine built 17 as did most people that i talked to that had them. i also met a guy at prp that put one in a pinto. He said he was getting 18 psi. from a stock set up. He was also turning hi 13 sec quarter mile times with no traction through the first two gears. Ugly car you would have never expected it out of it.
When my boss at the garage i worked at 14 years ago did the math of the boost increase of 5 psi and better air flow over the intercooler in real life than in the test he figured out a stock turbo coupe in 88 got 225 to 235 hp
Don't know if it is true but i know the car sure did run good.
KooK
KooK
Posted: Wed Dec 03, 2008 02:21 AM
The AEM kit is a little pricey but it's what I'm running on the yoda right now. I'm not a fan of how it will increase the pressure linearly considering the turbo/fuel is completely different, but I guess you can't ask for something that will follow every setup perfectly. Really I'm a huge fan of AEMs injection pump, the thing is massive and reliable from my use out of it. The only problem most people seem to have with them is it's harder to see the arrows on the two adjustment screws, so sometimes people get their adjustments off. You'll understand if you order the kit. But I've only got the Yoda running at about 25% of what it should be and it made 450whp on pump gas (ran out of dyno time, had to make a new map from scratch).
Thuff - high 13s is pretty impressive for something like that. It's why I don't ever completely doubt somebody, because there are a lot of cars out there that are underrated or just factory freaks (mostly American cars).
Neander
Neander
Posted: Wed Dec 03, 2008 10:22 AM
yea the aem kit seems like it be totally worth it
KooK
KooK
Posted: Wed Dec 03, 2008 05:53 PM
Here's the pump, if you know how large supra headlights are, you can tell how massive this pump is.
www.volk-tech.com/pict...empump.jpg
Although in this car I had a problem mounting the tank, it wouldn't fit in the engine bay at all, I had to stuff it under the bumper and make 3 brackets for it. The big black square one around it is the main support. The Aluminum one going off to the side is just to keep it from going side to side, and there is a 3rd you can't see that will keep it from going back and forth.
www.volk-tech.com/pict...emtank.jpg
(this is a customer/friends car, not mine) But yeah, you're right, if I run water injection again on one of my cars, hands down, AEM. It's a little pricey, but the setup is perfect in my opinion.
5 Admin_AzBaja 6774 Baja Bugs on Wiki need...
1568 mufasavnvmc 998720 Re: what did you do to...
285 MusicManiac 241201 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 9 FREE VW BAJA'S
0 Northmountainauto 1520 Shop Baja
