Visitors: 96
Total: 96
02: Pictures
12: Event Calendar
33: Pictures
37: Pictures
40: Event Calendar
44: Event Calendar
55: Event Calendar
59: Contact Admin
63: Event Calendar
67: My Account
74: News Letter
76: Event Calendar
86: Event Calendar
90: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- main fuel line leak...
The following users give thanks for this topic Anonymous - Mon Jan 12, 2009 01:27 AM
Kev_n_AZ
Kev_n_AZ
Post Post subject: main fuel line leak...
Posted: Sat Nov 29, 2008 04:23 AM
when the main line that runs down the mid section of the pan leaks, what is the usual line that replaces it?
should I use a 1/4" steel brake line??
seems as though I have a fuel leak . the car interior wreaks of fuel.. the floor board is wet near the petals.
George Washington
Post Post subject: Re: main fuel line leak...
Posted: Sat Nov 29, 2008 04:32 AM
thats what it sounds like to me to keven,i had same poblem on a 65,,used brake line worked great,,but id check hose from tank to hard line first,, might be running into the tunnel under there,,
Posted: Sat Nov 29, 2008 06:14 AM
What he said^^^^^^^^
Kev_n_AZ
Kev_n_AZ
Posted: Sat Nov 29, 2008 07:44 AM
I plan on doing maintenance all day saturday.. which will include fuel tank removal and hard line replacement if necessary.
thanks for the info Very Happy
George Washington
Posted: Sun Nov 30, 2008 06:04 AM
You can braze it shut with a little filler rod...or then again maybe not...
Posted: Sun Nov 30, 2008 06:38 AM
Confused
Kev_n_AZ
Kev_n_AZ
Posted: Fri Dec 05, 2008 04:25 PM
I pulled the stock tank and the attached fuel line fell right off Rolling Eyes
thats before loosening it at all....
now it has new line in a loop with a large filter in line.. then it attaches to the central hard line for the car..
found it pretty easy to place a gas can on the steering arms below the tank to drain the tank...
no more fuel smell in car..
I even siliconed all the holes under the front bonnet as to cut down crisp morning air flow en route to work..
George Washington
No new posts VW Volkswagen & Baja Bug General Discussion $%!@# oil leak! 6 ghs215 3855 $%!@# oil leak!
 Thu Jan 14, 2016 05:00 PM
No new posts VW Volkswagen & Baja Bug General Discussion rear main seal
31 baja66 14188 Re: rear main seal
 Fri Nov 18, 2011 06:39 AM
POCman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 2071 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 4015 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts Events and Get Togethers World Wide BAJA'S ON MAIN!? 12 bajaboi727 4930 Re: BAJA'S ON MAIN!?
 Thu Oct 28, 2010 03:46 PM
