Visitors: 80
Total: 80
16: Event Calendar
29: Pictures
31: Event Calendar
38: Pictures
61: Pictures
76: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wheeling in one wheel drive
brian10x
brian10x
Post Post subject: Wheeling in one wheel drive
Posted: Mon Nov 24, 2008 03:12 AM
I hate getting stuck, especially since I usually go out in the desert alone.
I'm old and fat and I won't last long out there.
I'd like to at least get traction to both rear wheels. After extensive research I've learned locking/limited slip differentials would cost me more than I paid for my entire car.
I drive a lot on the street, so a spool is out.
Could I use a turning/cutting brake to slow down a spinning wheel and direct power to the opposing wheel? Is this a practical way to get traction?
Any other ideas?
Thanks in advance.
Brian
Post Post subject: Re: Wheeling in one wheel drive
Posted: Mon Nov 24, 2008 03:51 AM
Sounds good, but Im guessing that would rip your bug transaxle gears a new one!
meangreen
meangreen
Posted: Mon Nov 24, 2008 04:17 AM
yup !!! thats how i have done it for years,but it is hard on the tranny so far i have been lucky and not lost a tranzaxle to it yet........knock on wood
Posted: Tue Nov 25, 2008 03:42 AM
Why would it be hard on the tranny?
Posted: Tue Nov 25, 2008 04:10 AM
Make it do more work. If you high centered and lock up the tire in the air, that means half the cars balance is on that tire, and that would put alot more pressure on the gears.
Just guessin.
Posted: Wed Nov 26, 2008 06:28 AM
I use the turning brake for that purpose often. I can drive up a tall rock as the first wheel get off the ground I lock that one and push the rail over with the one still geting traction. I have also used it to run sideways on a steep incline. I never broke a transaxle doing this. I do use a super diff and torsional axles.
Posted: Wed Nov 26, 2008 10:03 AM
Truning brakes are hard on the spider gears. forcing most your load over them. but if you have a super diff or somthing like that you would be just fine. I have turning brakes in my car and can fast handle them like a fake posi.
Posi are not a good choice in a VW with most of the lbs out back your car all ready does not like to turn in the loose stuff no with the posi in place it will realy not like to turn and just push.
No new posts VW Volkswagen & Baja Bug General Discussion Sunday AM senic drive 1 perrib 1443 Sunday AM senic drive
 Sat Dec 22, 2012 02:00 PM
No new posts Events and Get Togethers World Wide Anyone up for a drive on Sunday? 0 pepeazul 1825 Anyone up for a drive ...
 Sat Dec 15, 2012 05:38 AM
pepeazul View latest post
No new posts VW Volkswagen & Baja Bug General Discussion wheel offset question? 0 billyjoejimbob33 1832 wheel offset question?
 Mon Oct 22, 2012 12:31 AM
billyjoejimbob33 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 6214 Wheel travel stock vs....
 Tue Jan 31, 2012 01:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion 1960 vw baja surging/wheel hop problem
baja problems
24 hayduke 8174 Re: 1960 vw baja surgi...
 Wed Aug 04, 2010 02:40 AM
hayduke View latest post
