Visitors: 138
Total: 138
04: Home
34: My Account
35: My Account
36: My Account
37: My Account
38: My Account
39: My Account
44: Pictures
72: Event Calendar
82: Event Calendar
99: My Account
105: Pictures
116: Pictures
122: Home
126: Pictures
128: My Account
133: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- carrier bearings in control arm?
nube_w_1970baja
nube_w_1970baja
Post Post subject: carrier bearings in control arm?
Posted: Wed Nov 19, 2008 02:01 AM
so i replaced the cv and a clicking sound is still coming from the driver side rear.
the wheel when on a lift seems to have A LOT of play when pushed left and right. so, i threw the good ol' air gun on the castle nut and pulled it 2 or 3 threads tighter. sound is still there...
so, if i'm not mistaken i need to take the whole thing apart and replace the inner bearings and seals and everything, right?
my question is, do you have to take the control arm off the car to replace them (as the book says) or can you do it without taking the arm off?
also, how long does it take and do you need any special tools?
Post Post subject: Re: carrier bearings in control arm?
Posted: Wed Nov 19, 2008 03:41 AM
You can do it on the car. It would be a good time to upgrade to the Sway Away chrome moly spacer kit. It takes about an hour a side if nothing is frozen. The job can be done without any special tools.
Posted: Wed Nov 19, 2008 05:16 AM
Yeah. It's not a big deal.
nube_w_1970baja
nube_w_1970baja
Posted: Thu Nov 20, 2008 06:22 AM
sway away spacer kit? how big is each spacer? and have you ever heard of them failing or falling off?
Posted: Thu Nov 20, 2008 03:30 PM
The stock ones are not up to the task of supporting the load off roading, stiffer suspensions, larger engines, tall/wide tires place on them. Symptoms are stripped hubs due to a loose axle nut caused by the spacers collasping. Get the VW factory manual it has detailed information you will need if you do the job yourself.
wtracing
wtracing
Posted: Thu Nov 20, 2008 08:39 PM
where can i get this kit and about how much do they run
Posted: Thu Nov 20, 2008 09:43 PM
Try Woods, Karls, CE and Chirco. As for price I do not remember.
nube_w_1970baja
nube_w_1970baja
Posted: Fri Nov 21, 2008 02:44 AM
so then getting the stock stuff from bap will work, just not for long?
i think all in all for seals, bearings and spacers will run about 60 bucks...
so, i'll get those pretty soon
Posted: Fri Nov 21, 2008 03:21 AM
It is your money and time. I would not want to do the job if the better spacers were not used. I would trust the old stock ones more than I would new stock spacers. German steel vs Brazil/China steel. If your drum is not loose the spacers are still good.
No new posts VW Volkswagen & Baja Bug General Discussion Baja: The Edge of Control
18 AzBaja 17727 Re: Baja: The Edge of ...
 Tue Sep 30, 2008 01:45 AM
No new posts VW Volkswagen & Baja Bug General Discussion Uh-oh front control arm problems... 8 joshsoko92870 3142 Re: Uh-oh front contro...
 Sat Sep 20, 2008 04:03 AM
VIN70 View latest post
