Visitors: 102
Total: 102
15: Event Calendar
23: Event Calendar
74: Event Calendar
75: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- CV gone to SH!T
CV gone to SH!T
nube_w_1970baja
nube_w_1970baja
Post Post subject: CV gone to SH!T
Posted: Sat Nov 15, 2008 04:08 AM
alright, i know that one is bad. a constant tapping coming from the rear end is what i hear, that is consistent with wheel speed. definately not a bearing...
how do you figure out which one is bad and where do you find those 12 point allen heads or 12 torx, whatever works?
Post Post subject: Re: CV gone to SH!T
Posted: Sat Nov 15, 2008 04:16 AM
Mine are just a 12-point socket (I forget what size- mine are 930, so don't know if the bolts are the same size as yours or not).
Is your axle angle excessive or close to max for the CVs? Is it noticeable when driving straight, or just turning corners?
I'd measure the distance between tire and fender. Then, jack the car up, and try and jack the trailing arm until you have the same tire/fender clearance (droop is to same point as when car is on ground, only with tire in air). Turn each tire, and see where clicking is coming from.
Never had to do this- I pulled that outta my hiney. Hope it's some help.
nube_w_1970baja
nube_w_1970baja
Posted: Sat Nov 15, 2008 09:16 PM
i can hear it only when i'm going straight normally at higher speeds, a constant click-click-click. angle is good, nothing chnaged recently, didn't get air...
and i jacked it up last night, tried to spin the tires, couldn't really get anything out of it. tried jolting it back and forth still nothing...
the whell does move a little when pushing it back and forth real quick left and right, is that normal?
i think i'm just going to arbitrarily switch one out and if it goes away, cool. if not, put the old one back and and put it on the other side.
Posted: Sat Nov 15, 2008 09:22 PM
With the wheel off the ground (full droop), they'll probably bind. Forcing them to turn like that will booger them up. That's why I was saying to jack up the trailing arm to the same point that the suspension is compressed when it's sitting on it's wheels, only with the wheel in the air so you could turn it and listen to the CVs.
VIN70
VIN70
Posted: Sun Nov 16, 2008 01:32 AM
here' s the tool
www.chircoestore.com/c...ts_id=2351
nube_w_1970baja
nube_w_1970baja
Posted: Wed Nov 19, 2008 01:46 AM
ok, i got the tool in a pack from checker for 10 bucks. also picked up the easy out in the event that the torx didn't work.
so if anyone needs either of those tools you can send me a message.
so, i swaped the cv and sound remains the same. so, i'll start another post
Posted: Wed Nov 19, 2008 02:00 AM
when was the last time you greased the c/v's ? all of them...
planenutz
planenutz
Posted: Thu Nov 20, 2008 11:31 AM
They need grease?!?!?!? Shocked
nube_w_1970baja
nube_w_1970baja
Posted: Fri Nov 21, 2008 02:46 AM
grease really? i thought the teflon spray that i used on my bike chain would work pretty well. all that glop running around would keep my car from running any faster...;-(
