Latest: George
Overall: 3576
Visitors: 138
Total: 138
05: Event Calendar
08: Event Calendar
48: Event Calendar
64: Home
74: Event Calendar
80: Event Calendar
96: My Account
97: Event Calendar
101: Event Calendar
115: My Account
120: Event Calendar
124: Event Calendar
125: Home
129: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- non vw motor?
non vw motor?
nube_w_1970baja
nube_w_1970baja
Post Post subject: non vw motor?
Posted: Fri Nov 14, 2008 08:46 AM
what type of other motors are powerful and dependable, carbuerated other than vw, ford 2.3 and toyota, that is good for vw for street and desert use?
nube_w_1970baja
nube_w_1970baja
Post Post subject: Re: non vw motor?
Posted: Fri Nov 14, 2008 08:58 AM
any body ever see the newer 1.3 liter mazda rotary motor or something like the suzuki hayabusa 1.3 on a bug?
i know that both are small but have incredible rev ranges and the busa' motor puts out about 150 hp at 9,500 rpm, the mazda puts out at least 170 hp at 7,500 rpm. both are water cooled and fuel injected ;(
so, what do you guys think?
navynuke
navynuke
Posted: Fri Nov 14, 2008 09:34 AM
lots of ford 2.3 motors, toyota 22RE, subaru, and ecotec motor swaps done.
whats your budget and power/weight goal?
fast_1
fast_1
Posted: Fri Nov 14, 2008 09:39 AM
I've seen rotaries in a couple of street bugs, but can't remember any bajas. I think I've seen rails with 13b Mazda rotaries.
There's been some posts about a sandrail called the Federal Evo II that has a modified Hayabusa engine in it. It's pretty sick, although a bit pricier than the average baja. Heres a link to a thread about it.
azbaja.com/Forums/view...+rail.html
Every time there's a post about a water cooled engine in a VW I have to tout the Subaru EJ series of engine (WRX and STi), preferably with a turbo. They're not carbed but well worth the extra effort.
nube_w_1970baja
nube_w_1970baja
Posted: Fri Nov 14, 2008 10:11 AM
well, supposedly, i'm supposed to get 10k after going to boot camp and finishing AIT for the national guard, so i'm thinking 5k complete and running with a motor that is willing to rock anytime i feel the need to go 110 mph in a 25 mph zone
... j/k
Posted: Fri Nov 14, 2008 03:30 PM
get a ford 2.3 or whatever they are. they have like 175 horse without any mods. and all the weight is on the rear wheels.
Posted: Fri Nov 14, 2008 03:41 PM
GM Ecotec is the direction I would go if you get away from the VW motor. They make as much HP as a 2.3 ford but only weigh 50 lbs more than a VW motor. The 2.3 tends to make the car back heavy so you will need minimum 3x3 arms, but better off with a 4x5 or 5x5 to get the wieght better centered over the rear wheels.
Posted: Fri Nov 14, 2008 04:52 PM
The downside to a 'busa motor is no reverse typically. Pushing your car out of every parking spot would suck... Laughing
I think they do run some sort of reverse gearbox on some of them though. I believe you just engage the starter (don't start the motor) to back the car up.
Posted: Fri Nov 14, 2008 09:18 PM
Also the 'busa and rotary engines have low torque, but rev to the moon. The VW transaxle is not going to want a 9000 rpm input shaft speed.
If you want water cooled a Subi or Ecotech are the best fits. Look at all the costs before jumping into either one though. Programmable PCM's, wiring harness modification, radiator, hoses, adapter plate, high pressure fuel system, exhaust, suspension upgrades to handle the weight of the added parts/hardware/engine, roll cage/shock mounts to support the new suspension and oil pan modification on the subi all add up quick.
$5k may not be enough when all is said and done. I have several thousand $$ in cage work alone!
Thuff
Thuff
Posted: Sat Nov 15, 2008 01:47 AM
I have seen a rotary motor in a street car. It seem to run pretty good. i really don't think it would be a good choice for a baja. If you want something other than a vw engine i would stick with the toyota or pinto. there a ton of parts for them and they are pretty simple to work on. If you want to go really fast put a turbo on one.
nube_w_1970baja
nube_w_1970baja
Posted: Sat Nov 15, 2008 02:57 AM
so stick to the ford 2.3 or toyota. which one can be turboed?
meangreen
meangreen
Posted: Sat Nov 15, 2008 03:22 AM
you can turbo ANYTHING !!! now as far as ease of install....couldn tell ya,but you can find the turbo charged "pinto" in older t-birds some came turboed stock....
Posted: Sat Nov 15, 2008 03:25 AM
BOTH..
nube_w_1970baja
nube_w_1970baja
Posted: Sat Nov 15, 2008 05:06 AM
cool, how much normally for everything like motor, adapter plate,
carb (type?), computer? what else do you need.
i'm starting to like the way a big radiator up front might look...
Posted: Mon Nov 17, 2008 07:16 PM
For Ford 2.3 litre turbo, PM Shawn aka Madman74. He is the resident 2.3 turbo guru. Adapter look at www.heckermachine.com/...mation.php
Nice work, nice guy, good price.
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 3853 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
No new posts Projects and Builds class 5 baja bug needs motor... 0 Azbugracing1214 2519 class 5 baja bug needs...
 Tue Jun 09, 2015 12:51 AM
No new posts Projects and Builds Where to buy ecotec 2.2 motor mounts? 1 cycleguy1979 2269 Where to buy ecotec 2....
 Sat Jun 30, 2012 01:41 AM
17 TwistedMetal 12837 Which trans with a 22r...
 Mon Dec 05, 2011 02:51 AM
chrispy56 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion awd motor for baja bug?? need some help 3 lzugl 2308 Re: awd motor for baja...
 Tue Jun 14, 2011 06:01 AM
