Visitors: 133
Total: 133
17: Pictures
28: Event Calendar
31: Event Calendar
46: Home
52: Pictures
54: My Account
83: Pictures
87: Event Calendar
89: Pictures
90: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- This is sad
This is sad
nukeworker
nukeworker
Post Post subject: This is sad
Posted: Thu Nov 06, 2008 06:15 AM
I need some brake hose (long story). Went to Checkers and NAPA and Car Quest. None of them had it. They all said to go to my local (only one in the area) ACVW guy "Doghouserepair.com." Pretty sad when you can't even get some of the basics for an ACVW at the local parts places. I guess our cars are getting REALLY old. Sucks.
bajaman73
bajaman73
Post Post subject: Re: This is sad
Posted: Thu Nov 06, 2008 08:56 AM
Shocked I need the blue ones!! Went to local VW shop and IT WAS GONE!!! Now it's a Paintless Dent Removal Place?!?! AnyWays, I guess i'll just order from a closer (mail order) place.
Broken parts is a nice way of saying \"You shoulda bought a better one!!\"
View user's profile Visit poster's website MSN Messenger Yahoo Messenger
Posted: Sun Nov 09, 2008 02:18 AM
You are so lucky the parts houses did not have parts for aircooled VWs. Other than Valvoline raicing oil, and Bosch products most all the other parts are worse than the normal VW suppliers have and even with shipping more expensive.
fatalifeaten
fatalifeaten
Posted: Tue Nov 11, 2008 05:58 AM
napa didn't have lines?
--Harlan Ellison
nukeworker
nukeworker
Posted: Wed Nov 12, 2008 02:05 AM
Nope. It's the blue hose that goes from the master cylinder to the brake tubing.
VIN70
VIN70
Posted: Wed Nov 12, 2008 04:05 AM
master cylinder to the reservoir???
nukeworker
nukeworker
Posted: Sun Nov 16, 2008 03:43 AM
Ya. From the res to tubing and from the tubing to the MC.
nube_w_1970baja
nube_w_1970baja
Posted: Sun Nov 16, 2008 06:52 AM
look around PHX for a place in town that can custom build hydraulic lines, could probably find them in braided stainless steal if you want them to look good...
also, try 4-wheel parts, one in mesa and main warehouse in south PHX
planenutz
planenutz
Posted: Sun Nov 16, 2008 12:34 PM
NAPA has some multi-duty hose that is good to like 250psi, fuel, oil, etc. I would think it would work fine there. It's a bit on the thick-walled side, but a good worm clamp and you're in business! Wink
Posted: Sun Nov 16, 2008 05:32 PM
Any VW parts store / VW shop stocks the 7mm blue silicone brake hose. Do not use reguar hose the brake fluid will make it swell up and block the flow of brake fluid to the master cylinder or leak.
AVOCADO
AVOCADO
Posted: Tue Nov 18, 2008 04:31 AM
You should just buy a brake hose of the same diameter and cut it into the lengths needed. Any local parts store will have that and its all attached with worm clamps anyways. right.
OLIVE DRAB 63 BAJA BUG
