Latest: jor_dang420
Overall: 3597
Visitors: 122
Total: 122
03: Event Calendar
12: Pictures
26: Event Calendar
36: My Account
37: My Account
41: Event Calendar
44: Event Calendar
48: Event Calendar
55: My Account
64: Home
71: My Account
78: Event Calendar
80: Event Calendar
81: Event Calendar
85: Event Calendar
90: Event Calendar
95: Pictures
104: Event Calendar
105: Home
109: Event Calendar
111: Event Calendar
113: My Account
114: Event Calendar
115: Event Calendar
118: Event Calendar
119: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- fuel line
fuel line
VIN70
VIN70
Post Post subject: fuel line
Posted: Fri Aug 25, 2006 02:31 AM
where abouts is the fuel line in the tunnel right in front of the shifter? i need to drill some holes in the tunnel and dont want to hit the fuel line.
Post Post subject: Re: fuel line
Posted: Fri Aug 25, 2006 04:22 AM
Take the shifter off and look thru the hole with a flash light. That way you can locate where the line is.
VIN70
VIN70
Posted: Fri Aug 25, 2006 04:55 AM
i was hoping somebody would know so i could continue with doing as little work as possible Very Happy Very Happy Cool
Posted: Fri Aug 25, 2006 04:58 AM
why do you need to drill holes there?
69bapbaja
69bapbaja
Posted: Fri Aug 25, 2006 06:30 AM
the fuel line runs on the in side along the driver side of the tube. right next to the clutch cable.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
Posted: Fri Aug 25, 2006 06:33 AM
you're assuming nobody has modified the fuel line.... Wink
VIN70
VIN70
Posted: Tue Aug 29, 2006 04:29 AM
i guess i just take a peek. im mounting a cutom console im about to finish. should be pretty bitchin a little smaller than what i wanted but not alot of room up there. unless you dont want to use the gas pedal Very Happy
Posted: Tue Aug 29, 2006 05:24 AM
why use the gas pedal? install a motor cycle handle bar set with mc throttle.
69bapbaja
69bapbaja
Posted: Wed Aug 30, 2006 05:38 PM
well most people do not cut into the tunel to MODIFY the line due to the tube is 8th inc steal and a bitch to cut thew for the normal wrencher.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 2033 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3966 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Line X 4 JVAZ 2729 Re: Line X
 Wed Aug 11, 2010 07:29 PM
JVAZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 2214 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion got a line on thing suspension parts... 1 kyle_pc_75 2366 got a line on thing su...
 Tue Sep 01, 2009 02:35 AM
57baja View latest post
