Latest: xbluegto
Overall: 3573
Visitors: 172
Total: 172
16: Garage
27: Garage
38: Home
50: Home
53: Event Calendar
61: Pictures
89: Pictures
90: Pictures
126: Event Calendar
152: News Letter
161: Home
164: Baja Forums
168: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- new to the baja bug
new to the baja bug
swint2007
swint2007
Post Post subject: new to the baja bug
Posted: Wed Nov 05, 2008 06:25 AM
I am about to get a baja bug from my uncle, that has been sitting in his yard for 4 years.
when he parked it, it ran, and now it doesn't. what are the likely causes of this, and where should I start as for replacing parts?
sorry for the n00b questions, but I've NEVER worked on a beetle before Smile
hopefully that will all change very soon.
Thanks!
Post Post subject: Re: new to the baja bug
Posted: Wed Nov 05, 2008 06:01 PM
It needs Fuel, Spark, Compression.
The first thing to do is squirt a little oil or diesel fuel in each spark plug hole and turn the engine over. Next see if it has spark. Repair if needed Third after four years the gas tank needs to be drained/ inspected/ cleaned/ rebuilt. If the tank is rusty, clean it with phosphoric acid and paint the inside with POR 15 gas tank paint. Replace all the fuel hoses and fuel filter. Note which hoses are suction and discharge on the fuel pump. See if the pump works.
Buy the VW factory repair manual for your year VW. Chirco stocks them, oem fuel hose and filters if you cannot get one locally.
swint2007
swint2007
Posted: Wed Nov 05, 2008 06:53 PM
Thanks alot!
4 Admin_AzBaja 5713 Baja Bugs on Wiki need...
1568 mufasavnvmc 903914 Re: what did you do to...
285 MusicManiac 219037 Re: Baja sightings
0 Northmountainauto 269 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1527 Baja hiding in Chandle...
