Visitors: 63
Total: 63
05: Home
11: Pictures
24: Event Calendar
25: Pictures
35: Home
39: Event Calendar
44: Home
45: Pictures
59: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- tire help
tire help
navynuke
navynuke
Post Post subject: tire help
Posted: Fri Oct 24, 2008 10:41 AM
I am looking for some tires for my baja. with the ford 2.3, and a 3 rib trans. was trying o decide on tire size, and what kind.
thinking about all terrains, and 31X10.5, but open to input.
looking for an all around tire, and keeping my eyes open for some paddles later.
Post Post subject: Re: tire help
Posted: Fri Oct 24, 2008 04:07 PM
I am running the treadwright retreads. They are inexpensive and an all around good tire. I am running the muds but they have all terrains too.
treadwright.com/
Thuff
Thuff
Posted: Sat Oct 25, 2008 12:23 AM
I run goodyear m/t 31 10.50 They seem to work good. the gearing kills me but i should have that fixed when i get the bus tranny in.
Posted: Sat Oct 25, 2008 01:20 AM
what you might want to do is borrow some elses tires to see if you like the gearing...try 31's 32's and so on...
i had 30's on my rail with a 22r and 002, it was way to low for street use...
navynuke
navynuke
Posted: Sat Oct 25, 2008 01:33 AM
ok, I'll leave the 30's on it now till I get it running. theywont survive a trip, but I can test gearing with them by the house.
just trying to get all my ducks in a row to make it to glamis sometime in December. even though the paint project is going crazy slow so far.
Posted: Tue Oct 28, 2008 11:17 AM
I have 30x12.5 on my baja... The car needs a 5th gear my diff is a 4.37 with a VW bus over drive of .89 I think. somthing like a 4.12 or even 3.90 would be better if you do lots of street/highway driving. if you do more off road and like that real low 1st and 2nd then th 4.56 is the way to go. I tried to split it the best I could for both types of driving. next time I think I will go witha 4.12 for a little better street driving as this is what I do most of the time now any way.
navynuke
navynuke
Posted: Tue Oct 28, 2008 08:24 PM
if only I knew the ratio in my trans. havn't a clue, and not gonna tear it down to find out.
Posted: Wed Oct 29, 2008 01:18 AM
if you have a 002 gear ratio is 5.38 thats a 3 rib
002 5 rib is 4.86
091 is 4.56.... Wink
navynuke
navynuke
Posted: Wed Oct 29, 2008 02:19 AM
ok thanks, so I have 5.38 then with the 3 rib. so I might want to think about 31 or 32inch tires.
I'll try the 30's I've got before I toss em though.
another question, my front end is wide five, but the rear is a 4 bolt pattern?
I need to change hubs to go to a wide 5 in the rear right? if so when I go to longer arms I'll look into getting some other rear hubs, microstubs if I can find a deal on em sometime even.
thanks
Ken
Posted: Wed Oct 29, 2008 09:06 AM
thanks
Ken
Not true! You can use a variety of rear drums, discs or hubs. The early 5-lug axles had short spline sections where the drum mounts. The 4-lug had longer spline sections, but the same size and spline count. An early drum will slide right onto a late shaft. All of them use the same 4-bolt backing plate / caliper bracket plate mounting on the 4 bearing housing bolts. The longer spline axles were also used in early 5-lug buses, Things and Type 3s. All of these are bigger stronger drums than early bugs used. A lot of aftermarket disc brake kits are available to fit long splines and have 5-lug hubs. To put early short spline drums on long spline axles, you must use matching backing plates and put a spacer on the axle outboard of the drumand inside of the nut. The stock bearing thrust spacers work quite well for this.
navynuke
navynuke
Posted: Wed Oct 29, 2008 11:08 PM
I'll look into it more when I'm ready to deal with that, for now, it'll work fine.
Posted: Wed Oct 29, 2008 11:55 PM
WEALTH OF INFORMATION GIVEN HERE IN THIS FORUM GUYS,,JUST WANTED TO SAY THANKS FOR YOUR CONTRIBUTIONS,,YOU GUYS ARE WHAT MAKES THIS WEB SITE ! Laughing THANKS AGAIN!! Very Happy PS. SS ABOUT SPELLING
Posted: Thu Oct 30, 2008 12:35 AM
I'm running a 1915, 091 and 33's on back.
No new posts VW Volkswagen & Baja Bug General Discussion Tire track width 4 cperry2704 1476 Tire track width
 Fri Dec 02, 2016 05:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion Who's got a buddy at discout tire? 2 Ejbbal21 2188 Re: Who's got a buddy ...
 Sun Mar 25, 2012 02:43 AM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion WATED: Wide 5 Aluminim Rim and Tire
Something like a Center line
1 DEDSLED2012 2102 WATED: Wide 5 Aluminim...
 Tue Mar 13, 2012 07:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion NEWB with class 11 tire question
class 11 guys
2 icebox 6135 NEWB with class 11 tir...
 Fri Jan 06, 2012 04:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion Need to borrow (2) 4-lug sotck wheel & tire set 2 fabinc 2310 Need to borrow (2) 4-l...
 Tue Jun 23, 2009 10:23 PM
danjones333 View latest post
