Visitors: 279
Total: 279
23: My Account
77: Event Calendar
143: Event Calendar
145: My Account
155: Pictures
157: Baja Forums
166: Baja Forums
181: Baja Forums
183: Baja Forums
190: AMAZON.com
194: Baja Forums
195: Baja Forums
196: Baja Forums
197: AMAZON.com
198: AMAZON.com
199: Baja Forums
201: Baja Forums
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: Baja Forums
209: Baja Forums
210: AMAZON.com
211: Baja Forums
212: Baja Forums
213: AMAZON.com
214: Baja Forums
215: Event Calendar
216: Baja Forums
218: Baja Forums
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
223: Baja Forums
224: Baja Forums
225: AMAZON.com
226: Event Calendar
227: AMAZON.com
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: Baja Forums
234: Baja Forums
235: AMAZON.com
236: Event Calendar
237: Home
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: Event Calendar
243: AMAZON.com
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: Baja Forums
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: Event Calendar
252: AMAZON.com
253: AMAZON.com
254: AMAZON.com
255: Baja Forums
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: Baja Forums
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: Baja Forums
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: AMAZON.com
275: AMAZON.com
276: AMAZON.com
277: AMAZON.com
278: AMAZON.com
279: AMAZON.com
1 2 3 4 5 6 7 8
Post Post subject: Re: AZ350X suspension/brake upgrade-10/26 UPDATE
Posted: Mon Oct 27, 2008 04:23 AM
Hey az350,make sure you clock your CV's ,Let me know how you mount your GPS.
Posted: Mon Oct 27, 2008 04:24 AM
let me know when it can be trailered so i can finish the steering and the rack mount
P.S. YOU SUCK ON THE GARMIN!!!!!
Posted: Mon Oct 27, 2008 04:30 AM
That's funny right there! /\ /\ /\ /\ /\ /\ /\ /\ /\
I guess the number '8' and a ) don't work well side by side!
Posted: Mon Oct 27, 2008 05:10 AM
I wish the GPS would accept an external antenna- with a flat windshield, it's gonna be hard to mount it and give it a good outside view all the time. Maybe I should just cut the roof off so the GPS can see the sky... Laughing
Thanks! Cool
Posted: Tue Oct 28, 2008 11:39 AM
I let my GPS sit on the seat of the car and it works just fine. It's picks up the GPS satalites from the side, not straight up to calculate were your at. it needs to triangleate on your postion and that hard to do if it above you Smile
Posted: Wed Nov 05, 2008 04:38 AM
Sooo, yesterday I primed and painted my upper beam supports. I also powdercoated the lower beam supports (they'll fit in my oven- the uppers are too long). Tonight, I powdercoated all the beam clamps. I'm headed out to the garage right now to start putting some herculiner on the front wheelwells and cleaning up the front end before I reassemble it.
Post Post subject: Re: AZ350X suspension/brake upgrade-11/5 UPDATE
Posted: Thu Nov 06, 2008 04:02 AM
Okay- I got the front end bed-linered tonight with a second coat. I put about four coats on the wheel wells, actually. I did the firewall and the frame head/tunnel extension also. I also taped off the lower part of my rear fenders that were all dinged up from debris from the front wheels and put some on there- looks kinda cool, actually (better than all the dings in the paint from the rocks!).
So, tomorrow I think I'll hang the beam back on there and start final assembly. Hopefully next week it'll get to Bugzyla's lair for brake plumbing, rear upper shock mount fabrication, and steering completion. Then all I'll have left is to snooker mama into letting me order some REAR FOA's... Laughing
I do plan on doing some insulating in the roof, rear package tray, etc. to try and cut down on some interior noise. Also have my CB and GPS to install, and my wiring cover to fabricate. *Sigh*- I guess it'll NEVER be finished!
Posted: Fri Nov 07, 2008 06:02 AM
So, got a little bit closer to the finish line tonight. Here's a couple pics I snapped.
Here's the front end after bed-linering it.
Here's with the beam back on. Now, the steering box is on, as well as the tie rods.
And here would be my bed-liner rock guards. Laughing
Post Post subject: Re: AZ350X suspension/brake upgrade-GETTING CLOSER!!
Posted: Mon Nov 10, 2008 05:16 AM
TWO FEET ON THE FLOOR!- Rear end is assembled, and both back wheels are supporting their own weight! CVs are clocked, greased, and both axles installed. Wow. With any luck, it should roll out of the garage and see the light of day TOMORROW. Won't be driveable for a bit yet, but it'll move from garage queen to trailer queen- a step in the right direction anyway. Tomorrow, I need to find a left International tie rod end, a front wheel seal, and that's about it. I have to shorten a couple of cap screws for the front caliper mounting brackets, then I can install both front wheels.
With any luck, I'll load it tomorrow, and will be taking it to Daryll on Tuesday for a few minor things. Just waiting on my front shocks at that point...
I can't wait to see how it looks out in the driveway tomorrow.
Posted: Mon Nov 10, 2008 06:18 AM
Do you have or need the seal numbers? What about door handle is that one need replaced? Looks sharp, like the bed-liner use. Heck of a job you are doing, it will definitely be worth the time effort and money.
Posted: Mon Nov 10, 2008 03:47 PM
Thanks for the props, Leather. I found a number on the one front seal that I have- hopefully finding another one won't be too hard. There's no brand name on it- it says "CR" and "USA" and "545358"- hopefully that will be enough.
The door handle works fine, although I do have another one I swiped from a door I had laying around, I just haven't gotten around to replacing it yet. I've got some sound deadening to do inside the doors at some point, so I'll probably swap the handles then.
Post Post subject: Re: AZ350X suspension/brake upgrade-4 ON THE FLOOR!
Posted: Tue Nov 11, 2008 04:58 AM
Well, it's back on all four wheels- FINALLY! Hopefully will be trailering it over to Daryll's tomorrow after I get off work. It looks AWESOME sitting in the garage. The front end ground clearance is about 16 inches, and just about 17 at the engine cage. I can't wait to DRIVE IT!
Posted: Tue Nov 11, 2008 05:23 AM
what size tires are those on the rear?
meangreen
meangreen
Posted: Tue Nov 11, 2008 06:06 AM
looking good,nice ride.....and i like the ford in the background to...of course if its lifted i really dont care if it's a geo metro,just like the lifted look i guess
Posted: Tue Nov 11, 2008 06:08 AM
33x9.50x15 BFG Mud-Terrains.
18 Dirtjunkie 6622 Official 2016 Hassaymp...
 Tue Nov 08, 2016 02:49 AM
No new posts Projects and Builds Suspension Help 5 RDMINAZ 4343 Suspension Help
 Mon Jul 18, 2016 03:06 PM
42 wideopenmotorsports 14325 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 03:14 AM
1 LittleBaja 2203 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2037 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
