Latest: xbluegto
Overall: 3573
Visitors: 186
Total: 186
24: Event Calendar
31: My Account
34: My Account
58: Event Calendar
95: Pictures
127: My Account
176: Event Calendar
186: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Npetric's A-arm baja
1 2 3 4 5 6 ... 9 10 11
The following users give thanks for this topic Anonymous - Sun Apr 26, 2009 02:13 PM
npetric
npetric
Post Post subject: Re: Npetric's A-arm baja
Posted: Mon Oct 13, 2008 03:15 AM
My wife let me play on my day off..........
67 a-arm baja honda 3.0
Posted: Mon Oct 13, 2008 03:27 AM
WTG,,sounds BITCH,N Smile
fast_1
fast_1
Posted: Mon Oct 13, 2008 03:58 AM
mmm... nice!
npetric
npetric
Posted: Mon Oct 13, 2008 06:28 PM
Im gonna try and get enough done this week to try and take it out this weekend
TwistedMetal
TwistedMetal
Posted: Fri Oct 24, 2008 10:26 PM
Update??
Nose-shift 091 for sale. 6-rib and beautiful! Type 2 CVs and shafts included... $500
npetric
npetric
Posted: Fri Oct 24, 2008 10:51 PM
Well....another week goes by and still havent test drove this damn thing....
I do need some help from you guys......
Bled the brakes last weekend. I have a 2master cylinder brake pedal. the front bled fine the right rear bled fine but the left rear would not bleed with my vacum bleeder. Decided I had to go old school and get a helper.....
Was able to bleed them but ran into a turning brake problem. The right side turning brake seems ok but the left has nothing until you pump the brake pedal...then you cant even move the left turning brake handle 1/2".. WTF????
Bled it again.....same thing.
The turnig brakes are new......but I bought them a long time ago.
The caliper seems ok. It seems like it is releasing fine. Any ideas???
Posted: Sat Oct 25, 2008 01:12 AM
can you post a pic of your setup and how you have things run...?
VIN70
VIN70
Posted: Sat Oct 25, 2008 02:02 AM
same thing happened to mine but my right rear wouldnt work, left worked great very short throw in the turning brake, i ended up having a very small leak at one of the flares, would not drip but it sucked air in.
npetric
npetric
Posted: Sat Oct 25, 2008 06:23 AM
1fasthoe.....I willsnapsome pics this weekend and post em.
I am pretty sure I dont have any leaks but i could be wrong.
TwistedMetal
TwistedMetal
Posted: Sun Oct 26, 2008 03:45 AM
I JUST picked up my 74 Baja tonight, so I can't help with any questions, and have never dealt with turning brakes or line locks yet.
I had a question about your A-arm setup though...it looks like your mounts at the frame are relatively horizontal to the ground, are they as they appear or is there a little pitch to them? I'm STRONGLY debating A-arms, but I want to street drive it and after my days of rockcrawling I don't really like rod ends for street use. I don't fear them failing, just don't like the noise, and teflon rodends are $$$. Would prob just try urethane bushings and 1-ton balljoints? I don't know yet...but I would prob try to incorporate a little more pitch in the mounts to suck up the big rocks/holes...
1FASTHOE, I'm the guy that has been grillin you on your 22r install! Thanks for the help, I just traded an exocage job for my cousin's built 22r! .40 over race block, 20r head and dual downdraft Webers!
Posted: Sun Oct 26, 2008 06:25 AM
welcome to the site and the dark side..... Twisted Evil
npetric
npetric
Posted: Sun Oct 26, 2008 07:02 PM
Twisted....the front in actually raked 10degrees and I can still adjust the upper arms a bit. My plan is to make it streetlegal....soI willlet you know how it does when ready!!!
TwistedMetal
TwistedMetal
Posted: Sun Oct 26, 2008 10:51 PM
Sweet! The only thing really stopping me right now is the cost of coilovers and not sure how to build the spindles as I've never done anything like that yet. That, and I can rework the beam suspension almost entirely for free if I can remember how my tools all work.
Here's my last project...I KNOW what travel is...just gotta figure how to get it via different method now!
www.pinkbike.com/photo/2484137/
npetric
npetric
Posted: Mon Oct 27, 2008 03:39 AM
A arm spindles
These are the spindles I used.^^^^
That is some flex on that sami...nice work!!!! Cool
TwistedMetal
TwistedMetal
Posted: Mon Oct 27, 2008 05:32 AM
Dang...that's too damn tempting! By the time I'm done cutting and widening a beam that I think looks like crap, lengthing balljoint trailing arms, buying a few rod ends and adapters to REPLACE the balljoints, some quality shocks, and a set of longer springs...I might actually SAVE money by going A-arm. And it just looks SOOO much cleaner.
Question: Is there a reason you settled on 10 degrees rake? Is that pretty typical or is there a gain/loss with different angles? I can understand why they should not be horizontal, but I would think you could absorb a little more impact with using a tad more rake? Maybe?
4 Admin_AzBaja 5720 Baja Bugs on Wiki need...
1568 mufasavnvmc 904682 Re: what did you do to...
285 MusicManiac 219174 Re: Baja sightings
0 Northmountainauto 281 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1560 Baja hiding in Chandle...
