Visitors: 72
Total: 72
11: Event Calendar
24: Event Calendar
41: Event Calendar
60: Event Calendar
62: Event Calendar
64: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wireing tail lights
Wireing tail lights
lidster
lidster
Post Post subject: Wireing tail lights
Posted: Tue Aug 22, 2006 01:03 AM
Hey there. So im looking to put on some trailer tail lights (2 wires) and I checked the wires that the previous owner had left hanging in the back for the taillights and they arn't getting any power. Any ideas? None of the fuses look burt out. And everything else is working fine.
Eat My Exaust.
Post Post subject: Re: Wireing tail lights
Posted: Tue Aug 22, 2006 01:11 AM
Get a test light and start checking the wires from front to rear, and check the fuses anyways VWs have a habit of just burning just the tips of the fuses off.
Posted: Tue Aug 22, 2006 01:42 AM
Make sure you are testing them with the ignition on. And if you are going to run 2 wire tail lights, you will need a trailer wiring adapter because the VW is 3 wires.
Posted: Tue Aug 22, 2006 04:30 AM
walmart, autozone, and maybe checker carry the 3/4 wire to 2/3 wire trailer light adapter kits.
aby where from $11 to $25 depending on where you find it.
not hard to wire in, just need to test each wire for proper connectio/ function.
azhunter
azhunter
Posted: Tue Aug 22, 2006 05:46 PM
Speaking of tail lights,,,bajafun....your left rear is out. no brake light at least.
Posted: Tue Aug 22, 2006 06:20 PM
thanks, i will check into it.
lidster
lidster
Posted: Wed Aug 23, 2006 01:07 AM
I know what your thinking...GET A NEW WIRING HARNESS. And eventually all the wiring will be replaced. I just want to get some tail lights on so I can get down the street to get the pan welded. So bad wiring aside. I dont know what year wiring it is. The bodys a 70, engines a 73 and the pans a 60. It could be anyone of those years, or none. I'm not seeing any of the brake wires. How do I find them!!! The wires that are coming out the back of my bug I THOUGHT were for my brake lights arnt reacting when the brake is pressed and mutimeters on them. Help?
Eat My Exaust.
Posted: Wed Aug 23, 2006 01:33 AM
do you have a pick of the wiring harness that comes out below the rear window vent inside the fire wall?
it should have 3 or 4 wires. some solid some striped.
those are the tail/ turn/ stop wires. did you meter there?
now there should be a fuse up front that controlls those circuits.
did you find the fuses?
are you teasting the lights with the key "on"?
azhunter
azhunter
Posted: Wed Aug 23, 2006 04:49 PM
First place I would start is the brake light switch. Simple ohm test with the pedal depressed. I've seen these go out alot...cuz they get used so much. Wiring is unlikely unless ALL wires got open ckts. Odds are against it. I believe it's on the master cyl
lidster
lidster
Posted: Thu Aug 24, 2006 11:13 PM
howdy. So I figured out what wiring diagram my car matches and I located the stop light switch. I haven't tested it yet. But i cant find the wire that comes up from the switch connected to the fuse box. In place of it is a red wire that is connected in its spot that seems to just head into the car. So making slight progress. I dont have a turn signal arm so I hadn't even tested the blinkers. BUT GUESS WHAT I FOUND!!! lol. I found a 3 way switch that had been connected to the emergency lights. So up is left turn signal and down is right lol. My car really is screwed up.lol. We will see what the problem turns out to be. thanks for all your help guys!
Eat My Exaust.
No new posts Events and Get Togethers World Wide led auto lights 4 Stella2015 2393 Re: led auto lights
 Wed Apr 08, 2015 03:03 PM
No new posts Events and Get Togethers World Wide This was a fun get together. Christmas Lights Tour
Not Baja's but a great idea for a Baja run
7 Yummi 4648 This was a fun get tog...
 Sat Dec 14, 2013 10:48 PM
Yummi View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 2082 Re: Need Help....Dash ...
 Thu Nov 10, 2011 07:55 PM
DeathBug View latest post
what are yall's set'ups
7 vindeta 12864 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
No new posts VW Volkswagen & Baja Bug General Discussion no brake lights 4 danjones333 1692 no brake lights
 Sat Jun 06, 2009 09:24 PM
danjones333 View latest post
