Latest: Milkmanbryan
Overall: 3583
Visitors: 112
Total: 112
26: Event Calendar
31: My Account
60: Event Calendar
76: Event Calendar
105: Pictures
109: Event Calendar
110: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- transmission
transmission
1970_baja
1970_baja
Post Post subject: transmission
Posted: Fri Oct 10, 2008 11:58 PM
so i was driving to school this morning and all of a sudden my bug stopped going. it kept running but wouldnt go. i started it back up and put it in 1st and it would move a little and then die. is this transmission?
T_Town_Baja
T_Town_Baja
Post Post subject: Re: transmission
Posted: Sat Oct 11, 2008 12:39 AM
Does the engine die or does the engine run but you dont move when in gear?
Couple things, can you push the clutch in, shift gears and let clutch out without grind? If so, not a clutch issue
Most likely (hoping), you just spun a drum. This is when the rear drum is loose, and the axle splines chew through the drum. You stay running but cant go anywhere. You could have someone look at the big nut on your rear axles as you try to move, if one of them is spinning, then you spun a drum.
Blaine
Posted: Sat Oct 18, 2008 03:08 AM
WELL???? Did you figure out what was/wasn't going on?
Posted: Sat Oct 18, 2008 05:25 AM
Sounds to me like he spun the splines out of a drum.
Posted: Sun Oct 19, 2008 06:06 AM
Spun drum, I used to have a problem with that when the car was a swing axle. Look at the nut spin round and round.
That would be my vote.
No new posts VW Volkswagen & Baja Bug General Discussion Transmission, thermostat, and dimmer switch ?'s
pics included
4 pschneider 4753 Re: Transmission, ther...
 Sat Jun 19, 2010 07:25 PM
No new posts VW Volkswagen & Baja Bug General Discussion transmission question 4 thext94 1768 Re: transmission quest...
 Fri Jan 29, 2010 06:07 AM
Brettucks View latest post
