Latest: ecthemc
Overall: 3567
Visitors: 120
Total: 120
58: Event Calendar
74: Event Calendar
77: Home
95: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Remove Body
Remove Body
baja?
baja?
Post Post subject: Remove Body
Posted: Fri Aug 18, 2006 09:08 PM
I have been looking through books and internet sites and have not been able to find help on how to remove the body on my 68 bug. I know it is bolted on but i dont know where the bolts are. and do i have to remove much wiring or any other parts?
azhunter
azhunter
Post Post subject: Re: Remove Body
Posted: Fri Aug 18, 2006 09:30 PM
There was a post about this a while back. But I'll dust off some brain cells for ya. The bolts are under the car on the outer edge, the battery, ground straps and engine wiring, fuel line, steering column is all there is. Hope I didn't miss anything and if I'm incorrect,,correct me. I think the wiring harness stays in the shell. Good luck and take pics
Posted: Sat Aug 19, 2006 02:11 AM
Brake master lines and wires.
SandRacer
SandRacer
Posted: Sat Aug 19, 2006 05:18 PM
The book Baja Bugs & Buggies has a section on installing a body lift that may help since you have to remove the body and raise it a bit to get the lift kit in.
The book has been around for quite some time and may even be available in your local library.
1976 Baja Bug
BajAMec63
BajAMec63
Posted: Sat Aug 19, 2006 10:34 PM
get this book its a must have!!
How to keep your vw alive...
it will tell you everything
Nitrous = It's like a hot chick with STD's, you wanta hit it, but your afraid of the consequences.
baja?
baja?
Posted: Sun Aug 20, 2006 04:31 AM
yea i have that book "how to keep your vw beetle alive forever for the complete idiot" and i have read through a lot of it and maybe i missed the part on taking off the body.
azhunter
azhunter
Posted: Sun Aug 20, 2006 06:29 AM
Get the "baja bugs and buggies" it has pictures to go by as well as a step by step. Mines almost worn out Sad
speedtrash
speedtrash
Posted: Sun Aug 20, 2006 10:02 PM
yo, this is the post( www.azbaja.com/Forums/...t=368.html ). and all your bolts are gonna be all around the side of your pan then rermove the gas tank and you'll find two more under there, then on my irs 74 there's a bolt above each shock mount(not sure about your 68 ).
carpe diem
"sieze the carpe"
bigbadbruin
bigbadbruin
Posted: Sun Sep 17, 2006 06:34 PM
get those videos from midamericamotorworks i thing there called bug me
baja?
baja?
Posted: Mon Sep 18, 2006 12:47 AM
Ok so the bolts on the right side underneath the car spin but dont come out. i can hear crunching metal inside the car. what do i do to get them out? i need to take off the body.
Posted: Mon Sep 18, 2006 02:48 AM
Cut 'em.
Fix it when you put it back togeter.
24 Kreed 20317 3" Body Lift, Class 11...
 Mon Apr 18, 2016 04:44 PM
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 3467 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Body Lifts 2 Darn_Near 2134 Re: Body Lifts
 Sun May 12, 2013 08:24 AM
1974 baja build
4 mkingaz 3326 Stretched pan and body
 Mon May 14, 2012 08:49 PM
mkingaz View latest post
No new posts VW Volkswagen & Baja Bug General Discussion body lift 2 elryano 1991 Re: body lift
 Thu Apr 12, 2012 09:58 PM
elryano View latest post
