Visitors: 87
Total: 87
04: Home
21: Event Calendar
51: Event Calendar
59: Event Calendar
64: Pictures
77: Event Calendar
79: Event Calendar
82: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Emergency Brakes With 3x3 Arms
Post Post subject: Emergency Brakes With 3x3 Arms
Posted: Sat Sep 20, 2008 07:48 AM
OK. This topic comes up from time to time, and I just did this not too long ago. The problem that a lot of guys seem to have is that when they put their 3x3 arms on the rear, they can no longer use their E-brakes because the cable is too short.
I upgraded my rear brakes to disc at the same time I put my 3x3's on, and chose the disc brake kit from So Cal Imports. BTW - they work INCREDIBLY well if anybody is interested. I'd HIGHLY recommend them. Anyway, the disc brake kit came with new brake cables, and of course, they were too short.
I took the cables to a place in Santa Fe Springs called "Control Cables". Remembering an equation from high school Geometry class , I calculated that I would need cables that were about 4-1/4" longer. They cut the inside of my cables out and installed new longer ones for $10.
Of course the outside of the cables (housings) needed to be longer, so I ran down to the local hardware store and found some springs that were the same ID as the little nubs that stick out of the torsion housing and spent another $8. I cut them down, slipped them down over the nubs, and ran the cables as normal through the springs.
They've been working great ever since.
Here's a picture....
It's a little dirty under there. I'm actually one of those guys who uses their bajas!
Hope that helps someone out there.....
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 2709 Re: bj front disk brak...
 Thu Dec 13, 2012 02:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion wanting feedback on 3 x 3 rear arms 10 ROCKSLAYER 9967 wanting feedback on 3 ...
 Thu Jan 27, 2011 06:01 AM
jon6.0 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 3x3 arms 8 texbroker 7332 Re: 3x3 arms
 Mon Nov 30, 2009 12:41 PM
No new posts Projects and Builds Bugzyla Trailing Arms 2 BugZyla.com 3809 Re: Bugzyla Trailing A...
 Tue Oct 06, 2009 02:13 PM
No new posts VW Volkswagen & Baja Bug General Discussion extended axles trailing and swing arms!!! help 10 nath_baja44 7583 extended axles trailin...
 Sat Jul 11, 2009 04:54 AM
nath_baja44 View latest post
