Latest: hulkbaja
Overall: 3594
Visitors: 97
Total: 97
02: Event Calendar
29: Memberships
31: Pictures
36: Pictures
40: Event Calendar
42: Pictures
47: Event Calendar
48: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Uh-oh front control arm problems...
joshsoko92870
joshsoko92870
Post Post subject: Uh-oh front control arm problems...
Posted: Sat Aug 30, 2008 06:53 PM
So I put all new ball joints on the 68 Baja. I also pulled the pan and replaced it then went through and replaced various parts that needed it. I had a friend help me that had worked on bugs before (my first time), but when we put the control arms on it didn't look quite right because the coil over was touching up against the top control arm. I couldn't remember if it was like that before so after I reinstalled the engine and backed out of my drive way there was a "pop"! It seems the front left lower control arm had popped out of the torsion bar! I'm not sure if it just wasn't tightened down properly or if something was installed wrong. Here are some pics. All help is appreciated!!! The last two pics are of the drivers side.
Post Post subject: Re: Uh-oh front control arm problems...
Posted: Sun Aug 31, 2008 03:10 AM
That looks Bad.. Remove the coil overs problem #1
Things to know VW front ends are like shopping cart wheels. Work great when going forward when backing up it trys to turn around. you might of had too much toe in and this helped pull your arm off. Make sure you can see the spring pack in the end of your arm. the hole that looks like a stop sign or hexigon. the stacks should be all the way to the end or close to it. If in your case the stack is still in place on both lower arms you have broken springs. That would be the coil over fix. (Still Bad) But from what I can see your missing the grub screw/keeper bolt/hex bolt/god nut etc. from your lower arm. grease hole with no inner allen bolt and outer lock nut.
Also check the ones in the midle of your beam too. Each bolt has a point the fits into a cone drilled into the springs.
Off to the store, hope this helps for now, good luck
VIN70
VIN70
Posted: Sun Aug 31, 2008 08:56 PM
yep, i that first pic the top grub screw looks like its not tightened/seated all the way either, theres a lot of the set screw sticking out past the lock nut.
Posted: Thu Sep 18, 2008 01:51 AM
So what was the final outcome of this?
joshsoko92870
joshsoko92870
Posted: Thu Sep 18, 2008 03:50 AM
Still working on it! The bolt was just not tightened down though but now I'm onto the valve springs (broken) and I installed rear disc brakes
Posted: Thu Sep 18, 2008 06:38 AM
A quick note: If that BJ front end is lifted, Here's a thought, while we're looking at pictures. See the adjuster that goes between the spindle and the upper ball joint. There is a notch in one of the flat spots on the six-sided nut. From memory, I've had the best luck (closest alignment) running that notch pointing forward. Loosen the ball joint lock nut and rotate it. I'm sure I'll get a bit of technical posts as to how to do is properly as a result of this post (annd I welcome them... it's good discussion). I did go through all of the technical end of it when I set mine up years ago. When all the dust settled though, I found my notch pointing forward. I could be totally off but this is something to look into if you want it to drive as nicely as possible with the least amount of tire wear.
bajaman73
bajaman73
Posted: Thu Sep 18, 2008 06:18 PM
I need to my ball joints as well. Hope I don't have these issues. Shocked Is there a removal tool for the ball joints? I just replaced my whole beam spindle to spindle with another one I took off an extra pan that was layin around, the wheels were straight when I started, now they aren't. Whats the deal? I didn't turn anything just cause I didnt want to align it. Sounds like a new Post/Topic
Broken parts is a nice way of saying \"You shoulda bought a better one!!\"
View user's profile Visit poster's website MSN Messenger Yahoo Messenger
joshsoko92870
joshsoko92870
Posted: Thu Sep 18, 2008 06:38 PM
There is a fork tool at almost all the local auto stores that can remove ball joints. It'll probably be the small ball joint remover there (Kragen, Napa, Autozone). I got mine at Kragen. To put balljoints in it's best to use a press, so I went to NAPA and they charged $10 or $15 a piece to press them in, which was by far the cheapest. I called all around and got quoted up to $140.00 to press 4 balljoints in!
VIN70
VIN70
Posted: Sat Sep 20, 2008 04:03 AM
make sure whoever installs the ball joints indexes them correctly, i installed my own, and of course i put the first one in wrong Embarassed
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2328 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 7673 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3517 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 9343 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wide Ball Joint front end? 5 Darn_Near 8341 Wide Ball Joint front ...
 Wed Sep 07, 2011 08:12 AM
Darn_Near View latest post
