Latest: hulkbaja
Overall: 3594
Visitors: 82
Total: 82
15: Pictures
27: Event Calendar
43: Pictures
46: Pictures
55: Pictures
59: Home
60: Event Calendar
63: Pictures
73: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- need help on fuel pressure
cheapbeetle
cheapbeetle
Post Post subject: need help on fuel pressure
Posted: Fri Sep 05, 2008 05:17 AM
anybody know what psi my stock fuel pump should have (1969 stock 1600cc sp) i think my fuel is acting upi how can i tell? Rolling Eyes
cheap beetle
Post Post subject: Re: need help on fuel pressure
Posted: Fri Sep 05, 2008 06:22 AM
Around 2-1/2 to 3 PSI.
cheapbeetle
cheapbeetle
Posted: Sat Sep 06, 2008 11:24 PM
i checked fuel pressure and its at 7psi with a stock pump
cheap beetle
Posted: Wed Sep 10, 2008 05:19 PM
7psi is too high (on webers) (stock not quite sure) generally, it may push fuel past your needle and seat. An easy way to lower pressure on a stock pump is to put 2 gaskets under it.
But the real answer would be, what is the actual reason for your initial question? What is is doing?
cheapbeetle
cheapbeetle
Posted: Thu Sep 11, 2008 01:54 AM
seems like after its warm up it wont idle
cheap beetle
Posted: Thu Sep 11, 2008 08:51 AM
That probably isn't fuel pressure. My advice would be to buy a couple of books that you'll have forever if you like VW's:
John Muir's Idiot Manual (AWESOME)
Haynes Official VW Workshop Manual
...and maybe even a Chilton's or others. I've got several of them and you just plain can't own a VW without at least the first two. You'll drive yourself crazy, bro. You'll learn a ton from those, and if you still have questions, they'll be much better questions based on an education. I can speak for myself here, I'd much rather try and help someone out who has a general understanding of a problem and can't find a solution, than someone who hasn't tried to check the simple stuff covered in the manuals.
I hope I don't sound harsh. I really dig helping others out. I mean that.
Buy those two books, though... AT LEAST those two.
2180 Baja bug with 091 trans.
11 51BUG50 4773 Clutch and pressure pl...
 Fri Mar 10, 2017 08:22 PM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 2014 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3916 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 2167 Re: Fuel pump failure
 Mon Nov 02, 2009 07:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fuel Filler Ideas? 4 catchbats 6738 Fuel Filler Ideas?
 Sat Jul 11, 2009 09:04 AM
57baja View latest post
