Visitors: 314
Total: 314
51: My Account
52: My Account
53: My Account
54: My Account
55: My Account
56: Home
60: Home
74: Event Calendar
88: My Account
97: Home
103: Home
107: My Account
108: My Account
109: My Account
110: My Account
113: My Account
125: Event Calendar
129: Event Calendar
140: Event Calendar
144: Pictures
146: Event Calendar
150: Baja Forums
157: My Account
158: My Account
163: Event Calendar
172: Baja Forums
183: Pictures
189: Baja Forums
190: AMAZON.com
191: Baja Forums
192: Event Calendar
193: Baja Forums
194: Baja Forums
197: AMAZON.com
198: AMAZON.com
202: AMAZON.com
203: Baja Forums
204: Baja Forums
205: Baja Forums
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: AMAZON.com
213: My Account
214: AMAZON.com
215: My Account
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: Baja Forums
230: AMAZON.com
231: My Account
232: My Account
233: My Account
234: My Account
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: AMAZON.com
240: Baja Forums
241: AMAZON.com
242: AMAZON.com
243: Baja Forums
244: AMAZON.com
245: Event Calendar
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
249: Baja Forums
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: Baja Forums
254: AMAZON.com
255: Baja Forums
256: Baja Forums
257: Baja Forums
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: AMAZON.com
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: Baja Forums
275: AMAZON.com
276: Event Calendar
277: AMAZON.com
278: AMAZON.com
279: AMAZON.com
280: Baja Forums
281: Baja Forums
282: Baja Forums
283: AMAZON.com
284: Event Calendar
285: Baja Forums
286: Baja Forums
287: Baja Forums
288: Baja Forums
289: Baja Forums
290: Baja Forums
291: Baja Forums
292: Baja Forums
293: AMAZON.com
294: Baja Forums
295: Baja Forums
296: Baja Forums
297: Baja Forums
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: My Account
304: Baja Forums
305: AMAZON.com
306: Baja Forums
307: Baja Forums
308: Baja Forums
309: AMAZON.com
310: Pictures
311: AMAZON.com
312: Baja Forums
313: AMAZON.com
314: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 3-2 Taillight Converters
neon99
neon99
Post Post subject: Re: 3-2 Taillight Converters
Posted: Wed Sep 10, 2008 04:38 AM
Is it possible to wire up a 3way toggle switch ( left< off >right ) to use as a turn signal and use the box... I was thinking you could run the brake lights as normal from the master cylinder but for the turn signal part would I need to wire in a flash for the turn signal part or does the box itself works as a flasher?
Posted: Wed Sep 10, 2008 04:50 AM
x2 ^
I want to run a 3 way switch for my turn signals too.
Posted: Wed Sep 10, 2008 05:26 AM
No problem. I can make you guys up a quick wiring diagram if you want.
neon99
neon99
Posted: Wed Sep 10, 2008 06:40 PM
Thanks, the wiring diagram would be much appreciated... with some brake and turn signals I will be one step closer to being street legal !!
oman
oman
Posted: Wed Sep 10, 2008 08:07 PM
so can you run leds like the ones up above on a six volt car? i got pulled over for having dim lights so i need to upgrade lol
Posted: Thu Sep 11, 2008 08:17 AM
Here. I scratched this out for ya:
Don't get confused. It's really simple. Since the next logical question is going to be, "How do I get my Emergency lights to work, too?", I addressed this on the diagram as well.
We'll start at the top where the +12V ignition fed circuit is. You don't want your turn signals to work with the key off. If you're a dumb-ass like myself, you'll drive to work and leave your turn signal on all day and kill your battery. Find a 12V power source that shuts off when your key is off. Wire a 2-terminal flasher in line (get it at Pep Boys, #552 works fine), then run that wire to your toggle switch (or turn signal switch). Then it goes to the 3-2 taillight adapter via wiring diodes (skip the diodes if you don't want flashers... I'll get back to that in a minute). The outputs on the taillight adapter go to each turn/brake light. Before the adapter, you'll notice that there are splices in the wire to go to your front turn signals. This is so the front turn signal lights do no illuminate when you hit your brakes. Get it? OK. The brake light switch on your master cylinder supplies power to the 3-2 adapter, too.
OK, back to the hazard circuit. On a hazard circuit, you want to have constant power. The reason behind this is simple: Quite often if you're in a situation where you need your hazards, the engine might not be running (or even capable of running). Find a constant +12V source for this. Run it to your hazard switch, then to the second (lower) flasher, again a #552 works fine, and then to your 2-way wiring diodes, where it splices into the rest of your system.
The two-way diodes are available at any RV store or hitch shop locally. You can take this diagram to them and they'll know exactly what you're talking about. I can even get them for you if you want, as I work at an RV dealership. The two that I regularly use are made by Blue Ox or Roadmaster. A wiring diode, if you don't know already, basically works like a check valve in plumbing, only with electricity. Power can go in one way and out the other, but cannot go backwards. These 2-way diodes have two inputs and only one output.
I spent the time to do this for you guys, so I want to hear back when you get it installed. Cool?
Jeff
Posted: Thu Sep 11, 2008 08:26 AM
...and oman...
This will only work on a 12V system. You'll need to investigate switching that old dog over to 12VDC like the rest of the normal world is running... Sorry.
neon99
neon99
Posted: Thu Sep 11, 2008 06:13 PM
Well hope to have this done in the next week or 2 but hopefull the wiring will be done right and you wont be able to see any of it but the rewards of turn signals and a clean dash !! Thanks 57baja.. also can you order the 2way diodes from the same website as the converter box or does Autozone or Checkers sell them?
Posted: Fri Sep 12, 2008 06:07 AM
You've got to have a local hitch shop or RV dealer somewhere around you. Buy both the parts from them. Look in the phone book. You'll be much better off that way, and you'll get the right stuff. The Autozone/Pep Boys/Napa/local auto parts people aren't going to have a clue. If you do happen to find some sort of adapter, it will be vastly inferior product and you'll pay too much for it.
Trust me on this. You gotta trust me. I do this for a living.
If you want, you can call Niel's Motorhomes at 818-891-2166. Speak to Mario in Parts and tell him you know me and want to order the parts. He'll get you hooked up with the right parts at a fair price, and will ship the parts out to you from SoCal. Niel's is closed tomorrow (Friday) for inventory until about 4:00, but they're open Monday thru Friday normally from 8:30 to 5:30.
neon99
neon99
Posted: Mon Sep 15, 2008 06:40 PM
Are these the right Diodes? I was tryin to order everything at once from them same place. I have a Camping World and stuff like that I can go to if these are wrong and again THANKS !!!
www.rvwholesalers.com/...=98&page=1
Posted: Tue Sep 16, 2008 07:43 AM
Yep. Those are the ones. Those are the Roadmaster diodes. They'll work great. I've never had a failure and installed literally hundreds of them.
neon99
neon99
Posted: Tue Sep 16, 2008 04:14 PM
Its been ordered !!
neon99
neon99
Posted: Tue Sep 16, 2008 09:09 PM
Never mind just got a call from RVwholesalers and they no longer carry the 3-2 converter !! time to search and locate another converter cause I really don't want to run 4 lights !!!
Posted: Wed Sep 17, 2008 03:25 AM
Call Mario tomorrow at the number listed above. He'll set you up.
neal18
neal18
Posted: Thu Jan 03, 2019 05:12 PM
You can contact Big Daddy RVs, they can help you. No need to search more.
No new posts VW Volkswagen & Baja Bug General Discussion 4 lug to 5 lug converters 2 weddlebaja 2209 Re: 4 lug to 5 lug con...
 Fri Mar 12, 2010 02:13 AM
