Visitors: 91
Total: 91
11: Event Calendar
22: Contact Admin
67: Home
80: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Rope
Rope
Post Post subject: Rope
Posted: Mon Sep 08, 2008 05:47 AM
I know... It's kind of a weird topic name, just like the Shoelaces topic was a couple of months ago. You'll understand in a minute. I was out playing around the other day when I broke the driver's side lower shock mount, which, on my ride, is also the supporting point for the coilover suspension. Not a fun breakage. I tried and tried on the trail to get it fixed. I even had an extra bolt in my Emergency Kit believe it or not, but couldn't get the old one out.
So....
I ended up using some rope I bought to string it all together in small pieces. It made me a bit nervous, but I drove it over 100 miles home like this... about 50 miles of it being on a windy mountain road. My alignment was slightly off, too, as you can see from the bent tie rod.
I'm redesigning the attachment for my limiting strap now, to alleviate the additional stress that I believe broke the bolt, but I thought I'd share this:
Carry rope.
That's all folks!
Post Post subject: Re: Rope
Posted: Mon Sep 08, 2008 05:52 AM
Nice, glad you made it home safely in it.
And btw a few questions
What kind of trailing arms?
What brand of tires?
Posted: Mon Sep 08, 2008 06:12 AM
DAMN!!
fast_1
fast_1
Posted: Mon Sep 08, 2008 06:14 AM
I agree about rope. It is GREAT! I had to use rope to keep my other car drivable until I could use a welder (which I had to wait a week for and drive over 150 miles) and it worked great. Luckily I was a couple of blocks from my house when mine broke, and it wasn't part of the drive-train or suspension. It was easier than something like wire or whatever, and cheaper. Tons of respect for an innovative fix!
VWDavo
VWDavo
Posted: Mon Sep 08, 2008 06:31 AM
Awesome ingenuity. Thanks for sharing.
-Gerald Ford
Posted: Mon Sep 08, 2008 06:23 PM
Here's a quick, funny aviation story about rope and a stuck intake/exhaust valve. A certain older model of Continental airplane engine commonly have issues with a stuck valve. Friend of mine flew a plane with said engine to Arizona from Alaska for another guy. Plane had been sitting, so was prone to have this stuck valve problem, usually on engine start at refueling stops. So, my friend became quite skilled at removing the upper spark plug from offending cylinder (planes have upper and lower spark plug), pushing rope into cylinder through plug hole, and hand turning prop to use piston and rope to push valve closed. Laughing
The really funny part is that he did this "fix" on the ramp right outside an FAA office, and they didn't say a word!
Anyway, sorry to run off, but thought some might find the ingenuity aspect humorous.
Bottom line- carry rope in your plane AND your baja, eh?
DRUMMOND
DRUMMOND
Posted: Mon Sep 08, 2008 09:51 PM
If you don't mind me asking a question..
What brand of arms are you running and what size?
Where did you get your front end stops? very sweet...
What springs are you running?
going outside to put some rope in my bug right now!!
Duane Drummond
DRUMMOND RACING
PRO SEATZ
www.proseatz.com
Posted: Tue Sep 09, 2008 02:08 AM
Don't forget bailing wire. Good fix.
Posted: Tue Sep 09, 2008 03:31 AM
A few questions were asked on this post:
Trailing arms are 4" x 1/34". I thought they were Eagles, but I don't think they are now. I'm not sure whose they are. I got them from Mooreparts.
Tires are Nanco Super Traction 7.00 x 15's. They are ridiculously super awesome in the dirt! They drawback is that they wear out fairly quickly on the pavement.
Front stops: I'm assuming you mean the hook stops on the arms and the rod on the shock tower.... Home made.
Coilover springs: 200 over 300 Kings. They are perfect: Not too soft, not too hard, and once you get the center stops adusted right, they use all the suspension without bottoming out on the high jumps. It's like riding on a cloud.
perrib. I think that was you who bailing wired a pair of needle nose pliers to fix your front end once, wasn't it? I was thinking about that picture when I was on the trail out there. I actually had bailing wire with me, but chose to use the rope, as I figured there was less chance of it coming off on this particular breakage.
When you shop for rope, find the thinnest diameter you can find with the most tensile strength. This particular rope was rated at 65 lbs.
Posted: Tue Sep 09, 2008 03:58 AM
I agree bailing wire would never have worked. Its just one of those also must take along items. You were lucky you had rope. When I broke the spindle I took off the trailing arms and compressed the opposite rear suspension to get it home.
Posted: Tue Sep 09, 2008 04:19 AM
I didn't actually have rope with me. I bought it when I went to the local hardware store and bought a drill I didn't really need, two sets of drill bits, an EZ-out, a propane torch and bottle, a punch, and whatever else I forgot to mention. I bought the rope "just in case" I couldn't get any of that other stuff to work... and it didn't. I spent $200 on stuff I already had at home in the shop. The rope was the least expensive and the most effective purchase. I think it was about $5.00.
I ended up buying a new 1/2 set of trailing arms, and a set of tie rods, too. When I got home that son-of-a-gun wouldn't come out of there, either. Actually those are much kinder and gentler words than the ones I was using that day.
All in a day's fun.
It only cost me about $600 so far, and I'm still not completely fixed yet....
All for a $2.50 bolt.
JumpinBruceB
JumpinBruceB
Posted: Thu Sep 11, 2008 09:16 PM
DAMN!!
Now that is some trail work!!
