Latest: thelataviayoung
Overall: 3584
Visitors: 110
Total: 110
19: Pictures
33: Pictures
74: Pictures
91: Home
101: Pictures
109: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- carb jetting...well just carb problems
Neander
Neander
Post Post subject: carb jetting...well just carb problems
Posted: Fri Sep 05, 2008 05:27 AM
hey there. ive got a baja bug with 30x10 inch tires on it. it has a 1641 cc with a w100 cam. the car came with a stock solex 31 pict carb on it. i wasn't getting enough low end power so i had my idle jets bored a little bigger(he didnt tell me how much Rolling Eyes )now with the bigger idle jets it idles like crap. the idle is WAY too low and adjusting the idle screw doesn't help at all. the carb i have has 2 idle jets on it, i don't know if only 1 is supposed to be bigger or what. its a Brazilian carb. the jets fixed the low end power issue, but screwed up the idle. it also blows a little black smoke(too rich) which leaning it out kinda helped it. i dont know if i should have the timing advanced to a certain amount? or if should just give up and buy a couple new carbs and run dual. this thing is kicking my ass! Confused
Post Post subject: Re: carb jetting...well just carb problems
Posted: Fri Sep 05, 2008 06:21 AM
If it were mine, I'd run a 009 and a set of dual 40mm Kadrons on that thing. It would be a fast fix and would run great. If you felt really ambitious, you could pull the heads, do a little Dremel work, and get an extra 15% HP gain over that, too.
Neander
Neander
Posted: Fri Sep 05, 2008 06:48 AM
i would like to put duals on it, id have to get a different rear bumper tho because it the kind that connects to the firewall right were the carbs would go. but other than that, im going to hit up a guy i know in sac this weekend and see if he could hook it up with a pair of carbs. hes an old baja racer and has a TON of stuff. oh and its single port...
Posted: Fri Sep 05, 2008 07:23 AM
Single port with a 100 cam? Not a great mix. I don't know what your budget is but I'd strongly consider a dual port set up before I did anything else at all.
Neander
Neander
Posted: Fri Sep 05, 2008 11:49 PM
yea it is a horrible set up, but thats all that it came with and i dont have any extra parts. my new engine will definitely be DP. but as of today i actually got it working! i took it around the block for the first time in almost a year :). the mixture screw was just too far out. so yea it seems to be pretty good now. responsive with ok acceleration. i just need to find a better shifter and get the brakes working better.
Posted: Wed Sep 10, 2008 05:13 PM
Neander wrote:
but as of today i actually got it working! i took it around the block for the first time in almost a year Smile
Congrats on that!
Neander
Neander
Posted: Fri Sep 12, 2008 06:53 AM
thanks man. still working things out tho because the next day it was kinda bogging hard in second...still crankin on it, messing with the timing n wat not
Posted: Fri Sep 12, 2008 07:14 AM
Same problem with my 1641cc. Im sick of my solex h30/31. rebuilt it, runs good when cold but after it gets warm it acts like the accel pump is bad
Neander
Neander
Posted: Sat Sep 13, 2008 06:31 AM
i think i figured it out today... i just had to set the timing to around 28 degrees btdc. but now i think my cvs are going out Rolling Eyes theres alot of sketch noises coming out of the front as well
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 8627 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 2011 Re: Carb Intake Covers
 Tue Jan 10, 2012 11:46 PM
Gunpilot View latest post
No new posts Projects and Builds carb troubles
1968 carb troubles
11 vwbajabug1 4430 carb troubles
 Mon Nov 15, 2010 02:12 AM
vwbajabug1 View latest post
No new posts Projects and Builds wanting 34 pict-3 carb
i need a carb
0 vwbajabug1 1593 wanting 34 pict-3 carb
 Tue Nov 09, 2010 12:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion carb 9 luhrman645 3965 Re: carb
 Wed Aug 04, 2010 10:47 PM
