Latest: Veewdave
Overall: 3606
Visitors: 100
Total: 100
11: Event Calendar
12: Home
14: Home
15: Home
21: Home
22: Event Calendar
26: Garage
29: Event Calendar
33: Home
42: Event Calendar
58: Home
61: Event Calendar
62: Event Calendar
65: Home
66: Home
69: Home
74: Home
76: Home
84: Event Calendar
87: Event Calendar
91: Event Calendar
96: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- does'nt when warmed up, need help
cheapbeetle
cheapbeetle
Post Post subject: does'nt when warmed up, need help
Posted: Thu Sep 04, 2008 05:22 AM
i need some help, i'm a need member to azbaja and a new owner of a 1969 beetle, when my beetle (1600cc single port) is warmed up it does'nt seem to idle, it just wants to die. i have cleaned the carb but had no luck! any ideas anyone? Mad
cheap beetle
Post Post subject: Re: does'nt when warmed up, need help
Posted: Thu Sep 04, 2008 05:43 AM
Check the idle on the carb, adjust the carb if needed (leaner or richer) check the timing.
Thats all i got, i had similar problems with my 68 Dual Port, usually it's a quick Carb adjustment that solves the problem.
and WELCOME TO AZBAJA!
cheapbeetle
cheapbeetle
Posted: Fri Sep 05, 2008 03:00 AM
about how many turns on the air/fuel mixture screw?
cheap beetle
Posted: Fri Sep 05, 2008 05:10 AM
you have to find the right spot for it. keep messing with it. you will figure it out just remeber how many you went right or how many you went left. it just all depends.
Posted: Fri Sep 05, 2008 05:12 AM
just keep going till it starts running better, if it gets worse turn the screw the other way.
once you get it where you like it, drive it for about 5 min then check it again and make any adjustments needed.
GOOD LUCK Cool
cwick1989
cwick1989
Posted: Fri Sep 05, 2008 05:23 AM
If it runs til it gets warmed up the choke turns off then it dies maby an air leak or a vaccum leak, silanoid, unequal compresion in your cylinder.... but id make sure its not a bad ajustment 1st! alot of people start with 1-2.5 turns out.... and then just keep your hand on the trottle then adjust it til it idles... if it wont idle then its probly an air leak and if thats what it is take a can of carb cleaner, ether, etc.. (anything in a can that sprays) and then spray the joint and or where all gaskets are and if the engine revs thats where your leak is... (make sure you dont spray the distibutor or you might have a lil fire on your hands!)Ive been goin through the sae thing you are...
cheapbeetle
cheapbeetle
you really think thats the problem? like i said it runs fine cold until it gets warmed up then it just wont idle. like they say in the south throw me a bone...........lol
cheap beetle
cwick1989
cwick1989
Posted: Fri Sep 05, 2008 05:35 AM
If it runs til it gets warmed up the choke turns off then it dies maby an air leak or a vaccum leak, silanoid, unequal compresion in your cylinder.... but id make sure its not a bad ajustment 1st! alot of people start with 1-2.5 turns out.... and then just keep your hand on the trottle then adjust it til it idles... if it wont idle then its probly an air leak and if thats what it is take a can of carb cleaner, ether, etc.. (anything in a can that sprays) and then spray the joint and or where all gaskets are and if the engine revs thats where your leak is... (make sure you dont spray the distibutor or you might have a lil fire on your hands!)Ive been goin through the same thing you are... i feel your pain!
