Visitors: 237
Total: 237
05: Pictures
36: Pictures
91: Event Calendar
133: Pictures
138: Event Calendar
139: Pictures
150: Baja Forums
162: Pictures
164: Pictures
165: Pictures
168: Baja Forums
170: Baja Forums
172: Event Calendar
173: Event Calendar
174: Event Calendar
175: Event Calendar
176: Event Calendar
179: Baja Forums
186: Baja Forums
190: AMAZON.com
194: Baja Forums
197: AMAZON.com
198: AMAZON.com
200: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: Event Calendar
210: AMAZON.com
212: AMAZON.com
213: Baja Forums
214: Baja Forums
215: Baja Forums
216: Baja Forums
218: Baja Forums
219: Baja Forums
220: AMAZON.com
221: AMAZON.com
225: AMAZON.com
226: Baja Forums
227: AMAZON.com
228: Event Calendar
229: AMAZON.com
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: AMAZON.com
235: Baja Forums
236: AMAZON.com
237: AMAZON.com
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- 90xj's baja build
90xj's baja build
1 2 3 4 ... 9 10 11
The following users give thanks for this topic Anonymous - Fri Mar 20, 2009 12:17 PM
Post Post subject: Re: 90xj's baja build (frame horns must be bent)
Posted: Thu Jun 19, 2008 09:39 PM
Id cut them off, and mock up some new big thick heavy duty noobs and make a jig for the transaxle rear mount so it will line up good!
VIN70
VIN70
Posted: Fri Jun 20, 2008 03:14 AM
90xjlimited4x4 wrote:
that would be sweet..zero camber change, you got a link for that???
Posted: Fri Jun 20, 2008 05:34 AM
Zero camber change would be nice... as long as the camber was dead nuts on in the first place. There's no adjustment. I'm not impressed. VW engineers, with all of their expensive tooling, decided slotted holes in the spring plates were necessary, and I tend to agree.
90xjlimited4x4
90xjlimited4x4
Posted: Fri Jun 20, 2008 07:57 AM
ya but the slotted hole only adjust toe camper is set with the angle of the arm and its pivot...
Posted: Fri Jun 20, 2008 04:11 PM
DONT wrote:
Yes, that is for making a custom rail. To install in a Baja would be a bit of a chore, but do-able.
i'm tossing up the idea of making my own frame horns off of the stock torsion tube. seems likt tthat wouldnt be to bad.
I've seen you post on some other sites, I have seen a car w/fab'ed horns, did you search the other sites also? Run on sentence I know, sorry teachers.
Anyway, I can't remember who's car it was, or even which site since it has been awhile since I saw it. Embarassed
90xjlimited4x4
90xjlimited4x4
Posted: Fri Jun 20, 2008 06:35 PM
i'm tossing up the idea of making my own frame horns off of the stock torsion tube. seems like that wouldn't be to bad.
ya i have the build running on this site and the samba the fabed frame horn picture was over there. but no really build up of it seems to be pretty straight forward though! just dont know if i need to yet...
putting the rear tires on in about a hour we will see if i got the brackets right....... luckily i have Thursday Friday to work on the bug every week or i would never get anything done.
90xjlimited4x4
90xjlimited4x4
Posted: Fri Jun 20, 2008 08:31 PM
well i thought i got the brackets perfect.... i was slightly off.......
left tire is slightly towed in (fully adjusted for toe out) and right tire is slightly towed out (also fully adjusted toe out)
its all welded so i figure i will slot the arms and drill two hole in front of the bolt pattern through the spring plates (non adjustable) when i get the toe perfect.
opinions?
VIN70
VIN70
Posted: Sat Jun 21, 2008 01:58 AM
im thinking of building my own, maybe even off the stock torsion...
no link for that????
90xjlimited4x4
90xjlimited4x4
Posted: Sat Jun 21, 2008 03:23 AM
i found that picture on the samba.... dont know really anything else about it...
90xjlimited4x4
90xjlimited4x4
Posted: Thu Aug 28, 2008 11:41 PM
long time no update:
been busy with family health problems got my wisdom teeth pulled. bought parts for another project...
now to the topic of today:
cage work
sorry about the dark not so great photos i took them with my cell....
i got bracing to add into the corners on the intersections just hoping for some input.
Last edited by 90xjlimited4x4 on Fri Aug 29, 2008 09:33 PM; edited 1 times in total
90xjlimited4x4
90xjlimited4x4
Posted: Fri Aug 29, 2008 02:12 AM
just got the bracing cut notched and started finish welding all the tacked in bars for today!
90xjlimited4x4
90xjlimited4x4
Posted: Fri Aug 29, 2008 09:40 PM
todays up date.
seats are fitted gonna be close to the passenger hopefully that wont ever turn out to be a bad thing. most of the internal cage work is done cant do much else till i order seat belts and get my fuel cell so im on to the engine cage. not sure how to mount it below the motor but i have the upper mounts in place.
any opinions comments are welcome!
i thought the exhasut hung down to low for when i add a spark arrester to the muffler so i shortened it up about 4inches
Posted: Fri Aug 29, 2008 10:14 PM
looks amazing.
90xjlimited4x4
90xjlimited4x4
Posted: Wed Sep 03, 2008 12:50 AM
thanks i appreciate the complement!
Posted: Wed Sep 03, 2008 01:37 AM
Loved the stingers nw every one has a droopy dog tail...Just sad. Makes the Baja Look unhappy.
1 2 3 4 ... 9 10 11
5 Admin_AzBaja 6813 Baja Bugs on Wiki need...
1568 mufasavnvmc 1000293 Re: what did you do to...
285 MusicManiac 241600 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 39 FREE VW BAJA'S
