Visitors: 131
Total: 131
22: Home
23: Event Calendar
25: Home
52: Event Calendar
64: Event Calendar
74: Home
85: Home
91: My Account
118: Event Calendar
122: Home
123: Home
127: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 3-2 Taillight Converters
Post Post subject: 3-2 Taillight Converters
Posted: Sun Feb 03, 2008 08:21 AM
This came up in another thread. I see a lot of Bajas running four rear lights instead of two. Presumably this is because of the need to have separate turn signals and brake lights in the wiring configuration. Most bajas have a "Three Wire system", meaning one wire for brake, one for left turn, and one for right.
There is an adapter you can get for less than 10 bucks to run your turn signals and brakes on the same light. Being in the RV industry, we use it all the time when towing an american trailer with a foreign car.
When you install this in your system, you can run one set of rear lights.
... Just a thought....
Post Post subject: Re: 3-2 Taillight Converters
Posted: Sun Feb 03, 2008 03:49 PM
I have seen them before, but usually alot more than $10. Do you have a part number and manufacturer?
oldfart
oldfart
Posted: Sun Feb 03, 2008 04:40 PM
wally world use to carry them, not sure of the price. they were with the trailer hitches and stuff, not the regular auto electrical. You know, right down from the flourescent pink steering wheel covers and plastic kings crown aroma thingies...
Posted: Sun Feb 03, 2008 04:53 PM
www.rvwholesalers.com/...amp;page=1
Kev_n_AZ
Kev_n_AZ
Posted: Sun Feb 03, 2008 08:05 PM
hey 57baja, did ya ever see me L.E.D. tail conversion??
George Washington
bajatink
bajatink
Posted: Mon Feb 04, 2008 12:46 AM
I used that same box. Mine has four lights, because I liked the look, but only the outer ones are turn sigs. all four are brake and tail lights. I made a diagram when I wired it, I'll see if I can find it.
Posted: Mon Feb 04, 2008 05:30 AM
LED's... They're the way of the future.
Posted: Mon Feb 04, 2008 09:44 AM
That would have been nice to know, I built my own.
insanehounds
insanehounds
Posted: Mon Feb 04, 2008 08:22 PM
AZBAJA how did you build your own do you have a schematic and what did it cost in parts?
Go ugly early in the night, that way it doesn't turn to a 2:00AM fox hunt.
Posted: Tue Feb 05, 2008 11:05 AM
I will see if I still have it. If not I will draw one up. it's real simple to make. You need 2 Relays for the rear and 2 more if you do the front blinker running light thing.
But her is a quick over view.
Take the center post of the relay and run it to the bright side of the tail light aka brake side of the bulb.
run the contact side to your master brake switch. so this way when you hit the brakes you tail lights will come on.
on the no contact side hook up a hot wire to a 2 prong flasher and the wire out of that to the no contact side of the relay.
No here is the magic, hook the wire for your turn signal to the real activashion contact. So when you hit the blinker the relay flips and now it on the flahser side.
/---Brake switch--(+)
--Ground--Brake/Flahser Bulb--[Relay]---/
---Flasher--(+)
Turn signal----------------------------------|
I use a ground from the signal and wire the Relay as (+)
You can "T" the second relay with the same wire from the brake switch and the flasher. Just make sure you do not "T" the wire from the signal arm. if you do that you will have a nice set of Emergancy Flasher.
For your emergancy flasheruse a toggle with 2 sides. one side hooks to each relay and the the the contact side can "T" then go to your hot. Flip it and both relays come on and now you have Flashers.
Stuff it all into a small Radio Shack box and bolt it under you dash. If you solder you can make it evan smaller with smaller relays but heck I just used some Ford Relays almos the same thing as the Black Bosch realys but a little smaller. This has been working for years now, well over 13 or 14 years now.
Posted: Tue Feb 05, 2008 11:06 AM
oops
ignore the periods. it should look like this.
................................................................./---Brake switch--(+)
...............................................................---Flasher--(+)
Posted: Wed Aug 20, 2008 06:56 AM
... or you can buy the $10 converter. Very Happy
Just a bump cause it comes up now and again.
fast_1
fast_1
Posted: Wed Aug 20, 2008 07:13 AM
I just ordered the universal turn signal switch from Chiro...
www.chircoestore.com/c...ts_id=1885
I wonder if this convertor would be a good addition. I'll have to see once I get the switch...
Posted: Wed Aug 20, 2008 07:49 AM
you know paying members get a discount at chircos. Fast_1 look for the members specials on the right ------>
Neander
Neander
Posted: Thu Aug 28, 2008 01:09 AM
i totally had one of those converter boxes on my baja when i got it. not knowing what it was(there was no writing on it of coarse Rolling Eyes )i cut it off. it wasnt hooked up to any lights yet, its like whoever put it on just got lazy and didnt finish it. HOPEFULLY i kept it because i have 4 lights that i want to all be my tail lights and still be turn/ brake
No new posts VW Volkswagen & Baja Bug General Discussion 4 lug to 5 lug converters 2 weddlebaja 1891 Re: 4 lug to 5 lug con...
 Fri Mar 12, 2010 02:13 AM
