Latest: bawward
Overall: 3614
Visitors: 125
Total: 125
08: Home
11: Event Calendar
15: Event Calendar
38: Event Calendar
78: Home
81: Home
94: Home
98: Pictures
104: Home
108: Event Calendar
109: Event Calendar
110: Event Calendar
116: Home
117: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Rust Removal???
Rust Removal???
Post Post subject: Rust Removal???
Posted: Fri Jun 06, 2008 03:40 AM
Hey guys & gals,
I was wondering if anyone has used this stuff from: www.safestrustremoval.com ?
If so, does it work?
I got a couple places I can't get to with sand paper or grinder and I don't want to let it go on.
Post Post subject: Re: Rust Removal???
Posted: Fri Jun 06, 2008 03:51 AM
link dont work
Posted: Fri Jun 06, 2008 04:00 AM
That's because I typed it wrong. DUH!!!
Sorry. Try this 'un: www.safestrustremover.com
Posted: Fri Jun 06, 2008 04:26 AM
never tried it how much is it
Posted: Fri Jun 06, 2008 04:31 AM
$25 a gallon. and up. Depending on how much you need. Says you can recycle it until it no longer works. They say you can filter the particles from it and keep on using it. Plus, it "supposedly" won't hurt the environment or pluming so you can pour it down the drain when it wears out.
Posted: Fri Jun 06, 2008 05:44 AM
i would give it a try if it is only 25 then try it out and if it dont work then your out 25 and if it does work then you have the rust gone.
Posted: Fri Jun 06, 2008 06:57 AM
I could see it working on surface rust. Not pitting or serious rust.
Posted: Fri Jun 06, 2008 07:05 AM
yeah i dont know it doesnt specify does it. your probably right, only surface rust. what kind of rust are you trying to remove
Posted: Fri Jun 06, 2008 05:59 PM
A little of both,surface and pitted. Seems to me one or more of the videos show some serious pitted rust getting "washed away".
I'll get some and see. I was just wondering if any of yous guys tried it.
Post Post subject: ** Update** Rust Removal???
Posted: Wed Aug 13, 2008 04:43 PM
Very Happy
Well folks, it works.
I've been running it over some pretty rusted doors and it's clearing the rust away. Cool
Problem is keeping odd sized/shaped areas wet until the rust is gone.
I tried using a pump from a desktop water feature but it doesn't have enough umph to pump to the top of the doors. I'll have to look for a better pump.
Posted: Wed Aug 13, 2008 07:04 PM
I was looking at buying some for small parts. How did you catch the runoff from the door?
Posted: Thu Aug 14, 2008 01:51 AM
I built a troff about 3" high, 5" wide and 40" long and lined it with plastic. Set the door inside the troff upright which allowed the bottom 2 or so inches of the door to be submerged. I then dropped the pump and ran a hose up the door and hung it with a small chain. The natural curvature of the hose allowed me to direct the flow. The fluid just ran down the door back into the troff.
Although this idea sounded good in my head, I needed to build a troff bigger and much deeper. Unfortuneately I had only 1 gallon of the stuff so I was forced to keep it as small as possible.
Small parts should be easy compared to a door.
Posted: Fri Aug 15, 2008 12:01 AM
Like you found out it needs to soak. A flexible hose with holes drilled and attached to suction cups should keep a larger area it wet. HF has it sometimes for $20.00. The more rust the longer it takes. My old boss tried a small swimming pool filled with phosporic acid to clean larger body parts. Google rust removal electrolysis. This also works you need, the more consumable electrodes the faster it works. I tried the Safer and electrolysis (dirt cheap) and Sandblasting is still the quickest. Muratic acid is another story in itself. Fast and very dangerous and may not be legal for this use. Drag car builders used to dip new car bodies in them to remove metal to lighten them but still call them stock for drag racing.
Posted: Fri Aug 15, 2008 01:18 AM
What media/grit do you use for light and or heavy rust? Where do you buy it?
Thanks.
Posted: Fri Aug 15, 2008 01:33 AM
Sandblasting quickest,,,,,,,hhhhmmm I guess so but man does it leave a mess. Even inside the booth I made, the media still finds it's way out.
Yet, I'm still going that route when I get the body painted. I'm not going to waist any more time ordering the fluid and building a bigger tub/trough for the doors.
Just gonna blast them and be done with it.
No new posts VW Volkswagen & Baja Bug General Discussion BODY REMOVAL '66 BAJA (HELP!) 5 ClassZero 5674 BODY REMOVAL '66 BAJA ...
 Sat Sep 07, 2013 05:08 PM
ClassZero View latest post
Replacement Possible or Not
3 jemizasi 4532 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion No Rust Paint? 4 Bryman042 5884 Re: No Rust Paint?
 Sat Mar 05, 2011 04:04 AM
No new posts Projects and Builds 1966 Joxracing/rust bucket baja***Help!***
93 joxracing 58174 1966 Joxracing/rust bu...
 Sat Dec 25, 2010 09:17 AM
joxracing View latest post
No new posts Projects and Builds Engine Cage Removal and Installation???? 4 glenf 3941 Engine Cage Removal an...
 Wed May 27, 2009 04:01 PM
glenf View latest post
