Visitors: 120
Total: 120
08: Pictures
84: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- VOltage regulator?
VOltage regulator?
orbot
orbot
Post Post subject: VOltage regulator?
Posted: Tue Aug 12, 2008 09:12 PM
May i ask a question regarding wiring.
Do you really need the voltage regulator?????
Can i hook everything up without it??
Post Post subject: Re: VOltage regulator?
Posted: Wed Aug 13, 2008 01:40 AM
SURE! If you want to "smoke test" your wire harness and electro's. Shocked
Especially if your running a generator. At high rpm's I believe they can produce a fair amount of juice, WELL above 6 or 12 volts, (depending on your setup) w/o.
Most new altenators have a regulator built in. If your running an altenator, check the manufacturer to be sure.
Absolutely keep the regualtor in the circuit if the answer is no to any of the above.
orbot
orbot
Posted: Wed Aug 13, 2008 02:35 AM
Holy....... you started another question.
Whats the differece between an alternator and a generator.
Well here is what i have, i believe its internal regulated, if not let me know
orbot
orbot
Posted: Wed Aug 13, 2008 02:36 AM
Oh yeah forgot.
On the second pic the bottom bolt has a B+
The upper thingy has a D
Posted: Wed Aug 13, 2008 03:26 AM
You have an internally regulated alternator there. All you have to do is run the B+ wire to the battery and the small spade terminal to the idiot light.
orbot
orbot
Posted: Wed Aug 13, 2008 03:41 AM
Thanks..
sandshark
sandshark
Posted: Wed Aug 13, 2008 11:32 PM
Yeah Thanks Zyla! It appears - I'll double check IDing the square wall mounted gizmo - my Baja has both an internally regulated alternator AND a separate reg.!!!!! BTW Zyla, I just stripped the entire car ( still need to remove windshield & front fenders), and need to have it blasted. Recommend anybody?
No new posts VW Volkswagen & Baja Bug General Discussion voltage? 11 nube_w_1970baja 6133 voltage?
 Sat Jan 17, 2009 05:39 PM
No new posts VW Volkswagen & Baja Bug General Discussion COIL VOLTAGE 3 cheapbeetle 2231 Re: COIL VOLTAGE
 Sat Sep 06, 2008 04:38 PM
cheapbeetle View latest post
