Latest: Sawmer
Overall: 3609
Visitors: 114
Total: 114
05: Event Calendar
07: Event Calendar
23: Event Calendar
29: Contact Admin
59: Pictures
61: Event Calendar
75: Event Calendar
81: Event Calendar
108: My Account
109: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- rear axle lugnut!!!
rear axle lugnut!!!
oman
oman
Post Post subject: rear axle lugnut!!!
Posted: Sat Aug 09, 2008 12:36 AM
so i need to redo my rear brakes, but i cant get to them because of the axle lug nut being firmly stuck on the axle! it is in gear, and i have tried getting it off while someone held the brakes, but the axle still spins just enough so i can't get it off. what do i do?????? please help its a 1960 baja if that helps
Post Post subject: Re: rear axle lugnut!!!
Posted: Sat Aug 09, 2008 01:48 AM
Are you using a HUGE cheater bar? The torque on that thing is supposed to be like 240 lb/ft or some ridiculous thing. You may need to soak it with penetrating oil (I don't know how rusty it is), and then go at it again. Air impact probably won't do it unless you're using one for like farm tractors or Terex trucks!
oman
oman
Posted: Sat Aug 09, 2008 01:50 AM
well its a large cheater bar and i have put penetrating oil on it, but the axle spins when i really push down on it!! even with brakes on and in gear, it slowly moves just enough so i can't break it free.
Posted: Sat Aug 09, 2008 02:30 AM
Are you saying that the splines on the drum are stripped? If so, that's gonna make things a little harder for sure. Does the axle spin inside the drum continually? If it won't bite somewhere, it's gonna be tough to get apart. Also, if that's the case, it won't be long until you're trying to drive and your car won't go anywhere, because those splines make the axle turn the wheel! Shocked
oman
oman
Posted: Sat Aug 09, 2008 02:39 AM
no the splines on the axle are not stripped because it holds on tight, and the ones i can see are in goood shape. when i torque on the wrench, the drum, axle and everything rotates
Sample
Sample
Posted: Sat Aug 09, 2008 02:41 AM
You need to put a couple lugs in, get a THICK piece of angle iron or box tubing wedge it in there so that it hits the ground while you are using a 36mm socket welded to a 6' piece of box tubing.
1966 Baja.
Posted: Sat Aug 09, 2008 02:56 AM
Man I hear ya. Shocked
I did mine back a year ago it took me a bit fenagling around with piece of 1" box tubing about 4' long, wedged into the lug bolts, and the longest 1/2 drive breaker bar I could find. I was about to take the approach of drilling out a piece of angle iron to match the lug bolt/nuts and wedge that down but I was fortunate that I didn't need to.
By the way, I bent that piece of box tube almost into a U by the time I finished both sides.
Good luck!
oman
oman
Posted: Sat Aug 09, 2008 03:31 AM
i got it!!! it took three different cheater bars to do it. first was the two foot long typical bent and mangled bar that wasn't long enough, then it was the old playground structure pipe that bent >:(, then it was on to a four foot long, half inch thick steel pipe that finally did the job!! i was on the brakes and my dad was on the bar and it finally came undone. thanks for the tips tho! i didn't realize the torgue needed to undo that dam thing..
greenehoosier
greenehoosier
Posted: Sat Aug 09, 2008 04:35 AM
Glad you got it. A torquemeister style tool does it in a few seconds with no drama. Also handy for flywheels.
GREAT tool.
www2.cip1.com/ProductD...C10%2D7036
sandshark
sandshark
Posted: Sat Aug 09, 2008 10:44 PM
For the future Oman, nuthin' beats heat (on the "outside" part, whether it's a nut or some threaded part that a bolt is frozen into), and an impact driver! BTW, if my memory is working, that axle nut has the highest torque spec on the whole car- at least that I've seen in my Bentley manual.
Cameron
Cameron
Posted: Sun Aug 10, 2008 09:27 PM
here is the tool i had to use on mine
www2.cip1.com/ProductD...C10%2D7040
You put it on the nut and beat it with a sledge hammer. My drum spun while i hit it but it still broke it loose.
16 DerekT 6545 Axle's needed
 Sat Dec 10, 2016 07:17 PM
No new posts VW Volkswagen & Baja Bug General Discussion Max angle for rear axles 5 Wattsd 5093 Re: Max angle for rear...
 Fri Jan 29, 2016 05:03 AM
Wattsd View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Rear Rim Backspacing 1 LittleBaja 3065 Rear Rim Backspacing
 Fri Nov 06, 2015 04:13 AM
JWHracing View latest post
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 5349 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
what do you use
4 bdrdunes 3770 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
