Latest: xbluegto
Overall: 3573
Visitors: 133
Total: 133
111: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- tippy toed tires are buggin me
oman
oman
Post Post subject: tippy toed tires are buggin me
Posted: Thu Aug 07, 2008 07:02 AM
so my baja has the normal tippy toes goin on in the rear end (the tops of the wheels angle out, the bottoms angle in) and i was wondering how to fix this... right now there are old school spring shocks on their lowest setting for the suspension. do i need new shocks? or will it take a couple grand of fabbing (which i don't have) to fix this? help pleasssse Sad
Post Post subject: Re: tippy toed tires are buggin me
Posted: Thu Aug 07, 2008 07:39 AM
Hmm Do you mean your baja (pre 68/swing axle) bug tires are sitting on the outer edge of the rear tires?
If so that is a torsion problem not a shock problem.
Posted: Thu Aug 07, 2008 07:46 AM
Convert it to IRS.
Posted: Thu Aug 07, 2008 03:57 PM
Mykul wrote:
Convert it to IRS.
What he said, its the only way you will get rid of the positive camber issue.
Posted: Thu Aug 07, 2008 06:25 PM
You need to limit the downward travel until you convert to IRS. Raise the bottom stop 1/4 inch.
oman
oman
Posted: Thu Aug 07, 2008 06:50 PM
hmmm how hard is it to convert to irs? is there a kit i need or.... and yes it is a 1960 with a swing axle. can you define torsion problem? thanks thanks
Posted: Thu Aug 07, 2008 07:45 PM
When you raise the rear of a swing car the tires get positive camber. At some point the change from extreme positive camber to extreme negative camber launches the rear of the car over the front. IRS minimizes the problem. Swapping pans is easiest. Weld on inner pivots are available. A IRS donor Beetle would supply you with reference points for assembly, tranaxle,axles and suspenion components. Then you can borrow, buy or make a locating jig from the IRS torsion housing to locate the new pivots on your vehicle. Take some angle measurements from the IRS before you disassemble it so you can check your installation.
VIN70
VIN70
Posted: Fri Aug 08, 2008 02:38 AM
"minimize" is the key word, if you go too high you will still have positive camber.
68 Baja Beetle project build
3 Scrappy68 1435 Lets talk tires.
 Sat Aug 26, 2017 12:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wheels and tires. Size is important? 0 andrewbaja 1890 Wheels and tires. Siz...
 Mon Jul 25, 2016 01:44 AM
andrewbaja View latest post
vw baja stock tires
7 iBeastSousa 3450 tires
 Tue May 27, 2014 10:12 AM
No new posts VW Volkswagen & Baja Bug General Discussion Tires question 4 vtbaja 2930 Tires question
 Sat Aug 31, 2013 05:22 AM
1engineer View latest post
25 Rigger 10492 I am looking for some ...
 Fri Oct 05, 2012 03:30 AM
Rigger View latest post
