Latest: Smokey4
Overall: 3593
Visitors: 100
Total: 100
28: Pictures
74: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What are the benefits and inconviences of Dual Carberators
grasshoper
grasshoper
Post Post subject: What are the benefits and inconviences of Dual Carberators
Posted: Mon Aug 04, 2008 10:07 AM
what are the benefits of dual carberators and double barrel carberators?
what are the troubles of them?
which one is better?
do they cause lower mpg or higher? or neither?
do they increase hourse power?
fast_1
fast_1
Post Post subject: Re: What are the benefits and inconviences of Dual Carberators
Posted: Mon Aug 04, 2008 05:37 PM
I am an air-cooled novice, but I have heard that it can be a pain to get dual carbs synced right. Also if you look at dual carbs there's more stuff that can break and/or fail.
Running a single two barrel means less things to go wrong, no pain in the rear syncing, and weird linkages. In theory if you get a single two barrel that has the same CFM as a comparable dual carb set up your HP should be the same. But you also have to consider intake manifold differences, they will probably give you a different power band. A single, two barrel will have longer runners which in theory will give you better bottom end and duals will have shorter straighter runners that will theoretically give you higher top end.
As for mileage a single two barrel with the same CFM as duals should get the same mileage, but I have had little experience with this as of yet. I would guess the duals might get a little lower mpg. If you haven't read the Baja Bugs and Buggies book yet, get it. It has a lot of good info. He really never touches on dual carbs, and seems to favor the single two barrels, but I am sure some of the experts here can fill you in better.
grasshoper
grasshoper
Posted: Tue Aug 05, 2008 02:39 AM
yeah I have the book but I couldnt find much about the carb I wanted you know ill read more later I heard the sync probleme to that would be a pain.
but thanks for the advise.
im hopeing to get a carb that doesnt lower the mpg but does perform great.
im rebuilding my 1675 to replace my 1500 which will be for sale soon its a very high performance engine and it was rebuilt this year.
so ill keep you call posted on that if anyone is interested.
im having alote of trouble removing the gland nut on the fly wheel it refuses to come off ill make a seperate posting but if you know any techniques tell me.
thanks, bill
fast_1
fast_1
Posted: Tue Aug 05, 2008 03:09 AM
Is that shiny engine in your picture the 1675??
Posted: Tue Aug 05, 2008 03:28 AM
1675?
I think there are positives for both. Personally, I prefer duals for most applications. They're not hard to synch, either. They're actually easier than single carbs in some ways.
grasshoper
grasshoper
Posted: Tue Aug 05, 2008 03:44 AM
a piston modification raised the cc. its the 88 mm pistons its easier then you think it it makes that sucker smooth as hell.
and yes thats the 1500 in the pic.
yeah im thinking of just getting the dbb
Posted: Tue Aug 05, 2008 03:45 AM
1679cc
Posted: Tue Aug 05, 2008 05:25 AM
i dont know if this is right but my neighbor told me this about when i get a bug. that the 1657cc ( i think thats right correct me if wrong)
are one of the best engines to get with dual carbs.
is that right
Posted: Tue Aug 05, 2008 11:20 AM
Its best to match the carb for what you are going to do with it. For rough off roading a single works better. You can use a Solex single up to a 1776 with a mild cam like an Engle 100. WEB Camshafts has cam profiles for single Solex carbed small displacement engines. For street and sand duals work better. Do you have a particular use in mind? My off road engine and street/Glamis engine are very similar except one has a single 32 mm Zenith carb and the other 48 IDA's. There is a 2.4 second difference in 1/4 mile times. Fuel injection would solve that. It is worth considering if you do not have carbs yet.
Posted: Tue Aug 05, 2008 05:20 PM
What fuel injection system do you recommend at a reasonable price?
Posted: Tue Aug 05, 2008 05:58 PM
Thats a good question. I have never tried FI due to owning a large selection of carbs. If you are building your own Hal Tech and Mega Squirt seems the way to go. CB Performance, Competion Engineering, Gene Berg, Redline, Turbo City etc supply ready made systems. If I was just starting out with VWs today an adaptive system combining Ignition and Fuel that could make changes for altitude and octane would be my first choice for a performance engine.
grasshoper
grasshoper
Posted: Wed Aug 06, 2008 06:27 AM
I never really thought of fuel injection yeah I have a rebuilt carb from the original on the 1500 I use my bug to gt to work and around so I need something thats good for both I go offroad alote so its gotta be strong.
and how much $ do you think I can get for my 1500?
Posted: Wed Aug 06, 2008 06:29 AM
Not enough to justify selling it. It should be kept as a back up.
grasshoper
grasshoper
Posted: Wed Aug 06, 2008 10:05 AM
really? im not really worried about my other engine i did alote of work on it ad im hopeing to keep it in good shape.
Posted: Wed Aug 06, 2008 10:18 AM
Emissions test for one and other problems like rust in a cylinder, theft, not want to sell the nicer engine with the vehicle come to mind.
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 4397 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Dual carbs 11 sandbuggy 7610 Dual carbs
 Sun Jul 14, 2013 02:02 PM
No new posts VW Volkswagen & Baja Bug General Discussion dual 40s or FI on type 4 motor 3 1969Type1BAJA 2088 Re: dual 40s or FI on...
 Thu Dec 31, 2009 04:04 PM
No new posts VW Volkswagen & Baja Bug General Discussion Having problems with weber dual carbs
17 trigger 6304 Re: Having problems wi...
 Mon Jul 30, 2007 05:22 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion dual battery set up? 3 tigerextra 2417 Re: dual battery set u...
 Mon Apr 16, 2007 05:24 AM
caversmoon View latest post
