Visitors: 338
Total: 338
01: Pictures
16: Event Calendar
22: Event Calendar
39: My Account
40: Pictures
41: Pictures
46: Event Calendar
48: Event Calendar
58: Event Calendar
75: Pictures
91: Drivers
94: My Account
96: My Account
101: Event Calendar
105: My Account
125: My Account
126: My Account
135: Pictures
147: Pictures
165: My Account
166: My Account
171: Baja Forums
172: Pictures
181: Baja Forums
183: Baja Forums
188: Baja Forums
189: Event Calendar
190: AMAZON.com
192: Baja Forums
197: AMAZON.com
198: AMAZON.com
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: Baja Forums
212: AMAZON.com
213: My Account
214: AMAZON.com
216: Baja Forums
218: Event Calendar
219: Event Calendar
220: AMAZON.com
221: AMAZON.com
222: Baja Forums
223: Baja Forums
224: Baja Forums
225: AMAZON.com
226: Baja Forums
227: Baja Forums
229: Baja Forums
230: AMAZON.com
231: Baja Forums
232: Baja Forums
233: AMAZON.com
234: Baja Forums
235: AMAZON.com
236: Baja Forums
237: Baja Forums
238: AMAZON.com
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: Baja Forums
243: Baja Forums
244: Baja Forums
245: Baja Forums
246: Baja Forums
247: AMAZON.com
248: AMAZON.com
249: Event Calendar
250: AMAZON.com
251: AMAZON.com
252: AMAZON.com
253: Pictures
254: AMAZON.com
255: Baja Forums
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: AMAZON.com
261: AMAZON.com
262: AMAZON.com
263: AMAZON.com
264: AMAZON.com
265: Baja Forums
266: AMAZON.com
267: Pictures
268: Pictures
269: AMAZON.com
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
273: AMAZON.com
274: Baja Forums
275: AMAZON.com
276: My Account
277: My Account
278: My Account
279: My Account
280: AMAZON.com
281: AMAZON.com
282: Baja Forums
283: Baja Forums
284: Baja Forums
285: AMAZON.com
286: My Account
287: My Account
288: My Account
289: My Account
290: AMAZON.com
291: AMAZON.com
292: AMAZON.com
293: AMAZON.com
294: AMAZON.com
295: AMAZON.com
296: AMAZON.com
297: AMAZON.com
298: AMAZON.com
299: AMAZON.com
300: AMAZON.com
301: AMAZON.com
302: AMAZON.com
303: AMAZON.com
304: AMAZON.com
305: Baja Forums
306: AMAZON.com
307: Baja Forums
308: Baja Forums
309: Pictures
310: Pictures
311: My Account
312: Baja Forums
313: Baja Forums
314: AMAZON.com
315: AMAZON.com
316: AMAZON.com
317: Baja Forums
318: AMAZON.com
319: AMAZON.com
320: AMAZON.com
321: AMAZON.com
322: AMAZON.com
323: AMAZON.com
324: AMAZON.com
325: AMAZON.com
326: Baja Forums
327: Baja Forums
328: Baja Forums
329: Baja Forums
330: AMAZON.com
331: Baja Forums
332: Baja Forums
333: Baja Forums
334: AMAZON.com
335: AMAZON.com
336: Baja Forums
337: Baja Forums
338: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Spray on truck bed liner?
liftman_2002
liftman_2002
Post Post subject: Spray on truck bed liner?
Posted: Fri Aug 01, 2008 07:09 PM
I just restarted to restore my 69 Baja and was thinking about using a spray on truck bed liner for the paint. Has anyone done this?
SoCalBajas.com
Post Post subject: Re: Spray on truck bed liner?
Posted: Fri Aug 01, 2008 07:29 PM
My pan has herculiner on it. Doing the whole body would make it heavy, but durable. I prefer paint
liftman_2002
liftman_2002
Posted: Fri Aug 01, 2008 07:47 PM
How has it held up?
Posted: Sat Aug 02, 2008 12:04 AM
herculiner is great stuff
i wouldnt tink that it would go good for the body but if you do it for the pan then it is good. also it would and will make your car alot heavyer. and it probably wouldnt look to good either.
just use paint or rattle can ( joxs )
Posted: Sat Aug 02, 2008 02:13 AM
Line X 4 coats= 40 pounds and 2200.00
on hold baja build
"when I nod my head, HIT IT"
Posted: Sat Aug 02, 2008 05:20 AM
That's WILD! I had a red spray-in bedliner in my OBS diesel Ford, and it faded pretty bad. I hope that doesn't happen to this FJ. Cool though!
greenehoosier
greenehoosier
Posted: Sat Aug 02, 2008 01:38 PM
The bottom half of my Baja project is cheap Wal-Mart roll on bedliner. I used it on my Warrior a few years ago and loved it. Easy to touch up, wears well..
Posted: Sat Aug 02, 2008 04:59 PM
The herculiner is good stuff and the price is fair. We have done several pans with it, and one we lines the whole inside of the car. The only caustion I will give you is once you have bedlinered the outsied, its next to imposible to get off. So if you are going to do it make sure you are ready for it to be permanent.
Neander
Neander
Posted: Sat Aug 02, 2008 08:04 PM
i was thinking of lining my whole car too, but now i might just do the bottom half of the car and the pan for sure. what spots do you have to make sure NOT to hit with the liner that might cause problems later? and can you paint over the liner to put stripes or designs over it?
greenehoosier
greenehoosier
Posted: Sat Aug 02, 2008 08:15 PM
For me, the idea of getting it off is not much of a problem. I can replace the doors from my personal stash and the fenders were junkyard dogs that are cheap to replace. That only leaves two areas with liner on it. The front and rear quarters can be had off with a sander in an hour or two (lots of heavy grit paper...).
I have never tried to paint over it with a contrasting color. I use Rustoleum semi-gloss black over the bedliner to even the tone out a bit. That takes about 3 cans for the portion you see.... The only things you shoud be careful of are the edges-they can accumulate a bit too much if you tend to stop there. The door handle are should be light too, because it can be hard to get the handles to fit. Stay away from the bolt holes, it is tough to get the bolts in if some seeps in there.
Neander
Neander
Posted: Sun Aug 03, 2008 04:17 AM
alright then thanks
Posted: Sun Aug 03, 2008 04:41 AM
I saw too buses this weekend that had the exterior done in Hippo brand bedliner. It has a UV protector and can be tinted. The guys said it runs about $175 for a gallon, and can be purchased and mixed at carquest. He said the bus took 6 gallons. Looked cool, but thats about $1200....
liftman_2002
liftman_2002
Posted: Mon Aug 04, 2008 06:44 AM
I think I'm going to go with the lower half and the pan in side out.
little_penny
little_penny
Posted: Sun Sep 21, 2008 01:22 AM
Here is a pick of mine.
Rhino inside and out.
[img]http://i116.photobucket.com/albums/o12/little_penny02/IMG_4543.jpg[\img]
little_penny
little_penny
Posted: Sun Sep 21, 2008 01:28 AM
Sorry heres the pic
No new posts VW Volkswagen & Baja Bug General Discussion *** STOLEN White 2004 Ford F250 Truck ***
*** Stolen White 2004 Ford F250 Truck ***
7 Conundrum 3132 *** STOLEN White 2004 ...
 Sat Dec 19, 2015 07:36 PM
No new posts VW Volkswagen & Baja Bug General Discussion Travel- Delivery- Open trailers or truck beds?
Parts
0 catchbats 1855 Travel- Delivery- Open...
 Mon Oct 25, 2010 06:06 PM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion beer liner 5 luhrman645 3038 beer liner
 Wed Aug 25, 2010 12:04 AM
luhrman645 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion [ Poll ] buggy converted to a truck 4 lvrider 2867 Re: buggy converted to...
 Tue Mar 09, 2010 09:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion '61 BUG TRUCK 12 Preston 8053 Re: '61 BUG TRUCK
 Wed Aug 06, 2008 12:46 AM
danjones333 View latest post
