Visitors: 127
Total: 127
29: Home
94: Event Calendar
110: Home
115: Home
125: Event Calendar
126: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Dutchbugs dreamlist
Dutchbugs dreamlist
DutchBug
DutchBug
Post Post subject: Dutchbugs dreamlist
Posted: Mon Jul 28, 2008 12:02 AM
Hi,
I had plans to do a little rebuild on my Baja this winter but because of the low dollar I'm thinking about trying something else.
Perhaps you guys can help a little.
I want to look over the possibilities to ship a Baja from the US to Holland.
I want to sell my van and hope to get somewhere between 6 or 8k for it.
Than I will sell my Baja which should go for at least 2.5k that's Euro's so about 12k $ in total for baja and shipping. That should get me something I guess.
Perhaps a little less because I need some extra's to get it streetlegal, we have some stupid rules here. But that would probably not be more than a few hundred.
What I would like to do in this thread is to get a list of stuff that should be on it. To start:
Rollcage
Wide axle on front (which)
IRS
3x3 rearaxle
linkpin (?)
flipfront or bugeye
Engine??
Double tubed bumpers (I have them on mine now and can exchange them)
Must have windows (not tinted, illegal in Holland)
shocks (?) I want it high!
Bodylift (?)
Color (for my girlfriend :))
Tires (?)
Brakes (disc?)
Wheeladapters are illegal in Holland
Please ad anything that comes in mind.
I want to have a list and than find something that come's closest to it and doesn't have to much milage and isn't used to much off road (yet, hahaha!)
It will probably take some time before I sold my van.
I look forward to your suggestions, thanks.
just been browsing around, something like this would be nice Smile
blue Baja
Post Post subject: Re: Dutchbugs dreamlist
Posted: Tue Jul 29, 2008 01:09 AM
I would think you should be able to find a Baja like the one in your link for ~10k. It costs more to build than to buy one, and if someone is motivated it would be an easy buy.
As far as your list, 6" wider beam w/2 1/2" x 1" trailing arms pushed out ~4" is the norm. For your budget, think aftermarket or custom link pin stuff.
Posted: Tue Jul 29, 2008 03:13 AM
that baja in the link is beast i saw one that but it need work and what not it had full tube chassis ford engine. it need some work but could of easly could of made it to that easly and some paint. it was like only 4k.
Posted: Tue Jul 29, 2008 11:27 AM
That baja has a huge Body lift on it. Your still about 15" to 20" off the ground. not sure what size ture he is running.
DutchBug
DutchBug
Posted: Tue Jul 29, 2008 06:04 PM
DONT wrote:
... w/2 1/2" x 1" trailing arms pushed out ~4" is the norm.
What does this mean? All thise numers confuse me Embarassed
Linkpin is preffered above balljoints right?
What I'm a bit worried about is the compatibilty of aftermarket with stock.
Because aftermarket stuff might not be available here easily.
Or am I overworried?
When I break something I'm afraid it will not be able to repair fast with parts not available here in Holland. Stockparts are easy to get.
The blue one I linked as an example is perhaps a bit to clean right?
It's beautifull but a car like that is easily damaged when going off road.
Just some thoughts....
Posted: Tue Jul 29, 2008 06:33 PM
2 1/2 x 1 trailing arms are 2 1/2" longer and 1" wider for more travel. (and your increased height) The beam pushed out ~4" is what most builders do to increase the wheelbase (for stability and ride) and also to clear the tires and the body w/longer trailing arms (since the arc of the tires is bigger with a longer radius)
Quality aftermarket trailing arms are hard to break, so you should never hurt them unless hit some large im-movable objects. The stock spindles with gussets are oftain used to save $ over combo spindles.
If you look at the pictures of my car, you will see the front end and rear end that is common. Just not the best pictures for details. (Bugzylla's secrets) The next pictures may actually have paint on it also.
www.azbaja.com/Forums/...=2720.html
The blue one looks nice and appears quite stout, but many feel a baja without scratches is not a baja.
DutchBug
DutchBug
Posted: Tue Jul 29, 2008 08:16 PM
Yeah it just an example, I don't have the money yet.
It's still in the cars I have now :s
I will make the scratches after I bought it, haha! Smile
No new posts Projects and Builds Dutchbugs Baja
A Baja in the lowlands
1 DutchBug 2379 Re: Dutchbugs Baja
 Sat Aug 28, 2010 08:41 AM
Rybob View latest post
