Visitors: 103
Total: 103
05: Event Calendar
13: Event Calendar
20: Event Calendar
24: Pictures
26: Pictures
32: Event Calendar
39: Event Calendar
52: Event Calendar
62: Event Calendar
68: Event Calendar
97: Event Calendar
98: Event Calendar
102: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Engine is out
Engine is out
Post Post subject: Re: Engine is out
Posted: Tue Jul 29, 2008 06:41 AM
the rust goes pretty deep in the cylinders. up to 2"s!
BTW this motor WAS siezed good before I got it (fromt sitting)
Posted: Tue Jul 29, 2008 06:42 AM
Its going to be a smoker.
Posted: Tue Jul 29, 2008 06:57 AM
It went through that phase, it doesnt smoke. AT ALL right now!
Posted: Tue Jul 29, 2008 07:20 AM
That good. Hope you get it running soon.
Posted: Tue Jul 29, 2008 07:23 AM
Yea it was a blast. It will be more fun since I had a few leaks from the empi cooler adapter, I got it fixed, and I get to clean this out.
I love to beat on the baja.
Next mod is shocks. Nothing crazy.
Thanks all.
Posted: Tue Jul 29, 2008 04:51 PM
WaBaja wrote:
I am def. porting and polish them.
I dont have 200 bucks for a 87mm P/C. I think ill just port and polish my exhaust and polish my intake. I heard exhaust porting is were its at, if done right.
It is good to polish the exhaust ports, but do not polish the intake. You want the air and fuel to tumble a little bit to keep the fuel atomized.
Which heads did/are you buying?
Posted: Tue Jul 29, 2008 05:07 PM
Just stock SP heads. It works for now
Posted: Tue Jul 29, 2008 06:19 PM
Just replacing the bent valve, or having them rebuilt? SP's work well, many racecars made good power with them until they opened up the rules to include DP's due to lack of available parts. I have a SP now, that I will use untill I build a larger engine and then it will be a backup.
Posted: Tue Jul 29, 2008 09:13 PM
Im taking valves off, spark plugs out, sand blast it, port and polish! , put valves/springs back on!
Posted: Wed Jul 30, 2008 12:39 AM
Be careful with the sand, try to look into glass beads or another less abrasive media.
Most high performance shops have a valve spring tester, you may want to test the spring pressures while you have them out.
Posted: Wed Jul 30, 2008 09:40 AM
I got 2 set of heads but one has better valve guides but they are open chamber??? and my other are closed chamber???
Posted: Wed Jul 30, 2008 01:00 PM
Dash idea (make a triangle pie shape piece and maybe weld some bolts onto some brackets inside and drill holes in my dash and just put nuts from my trunk.
I would put switches, gauges, lights, radio.
******Sorry paint made the picture distort HORRIBLY...*****
70bug
70bug
Posted: Sun Aug 10, 2008 06:37 PM
make sure when you set the rings again you turn the part where the ring split 180 from one another or else you will have to much blow by and that could be why you are reading a low compression rating i would personally change the rings. no matter what, that is a main piece if they are failed then you can start getting gas in the lube oil then it thins the viscosity of your which then makes your engine run hot and you guessed it just keeps on snowballing from there.AZ is right, if you have a second car then i would just save the 150 bucks and replace the jugs and pistons. it will save you money in the long run.
Posted: Sun Aug 10, 2008 11:19 PM
I am getting 87mm C/P/Rs off of STF (marc v.) Very nice guy. He said hes ordering new grant rings, from the warehouse he works at.
So ill be a 1641cc soon!
bajatink
bajatink
Posted: Mon Aug 11, 2008 03:13 AM
Guess you don't want the 85.5mm cylinders then, huh?
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 238 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 814 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 1481 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 1722 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 3814 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
