Visitors: 100
Total: 100
16: Pictures
41: Pictures
46: Event Calendar
78: Pictures
95: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bug to baja
bug to baja
Post Post subject: bug to baja
Posted: Tue Jul 29, 2008 04:54 AM
i was wondering on what you would have to do if you just bought a running decent bug and you wanted to turn it in to a baja.
what parts would you need and what would you have to do to it to make it baja bug worthey.
Post Post subject: Re: bug to baja
Posted: Tue Jul 29, 2008 04:59 AM
Cut the back off, and the front apron, baja kit if wanted.
heres a quick rundown on this website, its a good site.
bluegrassghostinvestig...m/baja.htm
Posted: Tue Jul 29, 2008 05:22 AM
yeah i saw that before.
what does it take to lift it to get lift and what not.
i dont think that you can just put big tires on a bug or can you.
Posted: Tue Jul 29, 2008 05:27 AM
Thats the story with my bug, at least in the rear anyways.
My fronts got a cut n turn beam with big tires.
that website is what got me in to baja bugs.
thats still one of my fav low dollar bajas.
Posted: Tue Jul 29, 2008 05:33 AM
i dont think you would have to do anything to it you would just have to get the right size for it.
Posted: Tue Jul 29, 2008 05:49 AM
I dont have any front end lift with 28"s, plenty of travel. I got 31"s out back, and have max swing axle lift (dont know exact how much splines its turned) But max without making your tires all gay.
I would get a good brand 1 piece front end, and do the front stock steel fenders on your rear end like the green azbaja bug article (cant find it for hte life of me).
Thats a 350 doller 1pc front end and a free rear fenders.
Sure beats 6-7pc kit for ~400-500 and im guesing its alot nicer to have a 1pc front end! I dont like my 4pc front end very much(nose cone, hood, fenders)!
Posted: Tue Jul 29, 2008 05:51 AM
1 piece sucks for cold weather tho, but yerr in AZ soo it doesnt matter.
lucky dog.
Posted: Tue Jul 29, 2008 06:38 AM
yeah were in az and it is hoter then HELL and no a/c that sucks
Posted: Tue Jul 29, 2008 06:58 AM
a/c and heater is for wusses! LOL JK. But I never use a/c or heater (jeep and toyota had no A/C, and never used heater) and it goes form 10 to 115 degrees here.
Posted: Tue Jul 29, 2008 07:24 AM
I am in Chandler you can take a look at mine.
greenehoosier
greenehoosier
Posted: Wed Jul 30, 2008 03:12 AM
Mine is a $30 set of fenders, a $10 nosepiece and a stock hood cut down. The rear is lifted one spline and the front is stock. Here is a before and after. The rears are 31x10.5/15 and the fronts are 235's. This took a few weeks, but that includes an all new pan under it. A mostly stock Baja with some lift on the back and some tires can do fun and wonderful things.
Cheap and easy. You should be able to find a MUCH better starting point than I had. Good luck and give it a shot.
Posted: Wed Jul 30, 2008 03:36 AM
how idd you lift it in the back end.
Posted: Wed Jul 30, 2008 03:40 AM
Take off tire, (i found it easier to remove shock), take off 3 bolts from spring to axle, slowly lower spring plate (jack), and and pull it off, turn it clockwise and jack it back up, put against the lip and bolt springplate back to axle.....
THats just a crappy writeup, go to google.com and find some good write-ups!
greenehoosier
greenehoosier
Posted: Wed Jul 30, 2008 03:53 AM
There is a good write up on here on how to do it, just explore some with the search and buy the Jeff Hibbard book, it is a wealth of info, though some of the stuff is outdated. Here is a link to the book.
product.half.ebay.com/...QprZ529095
Posted: Wed Jul 30, 2008 05:34 PM
You covered up the patina. When does the enine go in?
4 Admin_AzBaja 5213 Baja Bugs on Wiki need...
1567 mufasavnvmc 855124 what did you do to you...
 Tue Aug 15, 2017 03:29 AM
285 MusicManiac 209258 Re: Baja sightings
Off-road event
1 wideopenmotorsports 362 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3306 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
