Latest: xbluegto
Overall: 3573
Visitors: 242
Total: 242
48: Event Calendar
53: Event Calendar
76: Event Calendar
150: Event Calendar
164: Baja Forums
173: Baja Forums
182: Baja Forums
190: AMAZON.com
193: Baja Forums
195: Baja Forums
197: AMAZON.com
198: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: Baja Forums
213: AMAZON.com
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
225: Baja Forums
226: AMAZON.com
227: AMAZON.com
229: Baja Forums
230: AMAZON.com
231: AMAZON.com
232: AMAZON.com
233: Baja Forums
234: AMAZON.com
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: Baja Forums
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- problems with my shifter...
Neander
Neander
Post Post subject: problems with my shifter...
Posted: Sun Jul 27, 2008 11:58 PM
so ive been having alot of trouble getting my shifter to work properly in my 68 baja bug. the car came with an old hurst trigger shifter that had the bolt slots shaved out on the sides to adjust the shifter to the side more i guess. so i got a new empi trigger shifter, which i cant even get close to working. so i got a stock shifter. with the stock shifter, for 1st you have to go over to the right a little and up to get into gear, 2nd is reverse, and 3rd and 4th work fine. other times first and 3rd wont work but reverse and 4th will Rolling Eyes . i have gotten the old hurst to go through all the gears, but it was tricky. i was thinking that the shift rod its self might be bent too much or is just not long enough.
sandshark
sandshark
Post Post subject: Re: problems with my shifter...
Posted: Mon Jul 28, 2008 01:30 AM
The guys at my local VW/buggy shop told me a "slight" bow in the rod is ok. I've found out by experience that correct placement of the mounting (base?) plate - with stock shifters - is critical. If yours has been messed around with a lot, you might save your self a lot of headaches by getting a pro's opinion. Oh yeah, check the condition of that plastic bushing in the tunnel a few inches behind the shifter too.
Posted: Mon Jul 28, 2008 02:18 AM
I second that. Check that plastic bushing and where it snaps in. Make sure the mount and bushing are still there and not broken off or cracked.
70bug
70bug
Posted: Mon Jul 28, 2008 05:04 AM
my buddy has an auto stick and we have had the same problem it stays in third or l2. if that coupling is not broke or cracked. then you really need to play with the shift base plate that being tweaked just a little will make that shifter not work. now if none of that works i would check out your shift coupling which is located under the rear seat. under a plate that unscrews check the rubber bushings for free play it will have a little because it is rubber then check for broken pieces of that coupling. if it still dosnt work you are going to have to pull the front nose cone off the tranny and check the hockey stick. anyone have anything else to add please do.
Posted: Mon Jul 28, 2008 04:16 PM
Does a '68 have the shift coupling bushing under the back seat? Those can cause a lot of grief if they're bad (sorry- all my VW's have been '65 or earlier, so I may be off on this one).
70bug
70bug
Posted: Mon Jul 28, 2008 06:33 PM
az thats a good question i believe it is on my 70 it is. i am not to sure how much they have changed in 2 years.
70bug
70bug
Posted: Mon Jul 28, 2008 06:41 PM
az the coupling that on later models its shaped like a horeshoe that has rubber bushings on each side that whole assembly then connects to the tranny shift rod selecter. and it is under the inspection cover under the back seat its really hard to describe the part go on to chirco.com and type this number into the search box on the left hand side CPR711108
Posted: Mon Jul 28, 2008 07:34 PM
That is the one I was referring to- it says '65 and later. That thing can take a LOT of slop out of your shift linkage. I had a '65 sedan that kept grinding toward reverse when I was looking for second, plus the shifter would move side to side like 3 inches when the car was in gear. I looked under the seat and that coupler was TOAST! The urethane piece was GONE on one side, etc. After replacing it, it felt like I was driving a brand new car practically! Unreal.
70bug
70bug
Posted: Mon Jul 28, 2008 10:28 PM
yea that is what happen with mine to
Posted: Tue Jul 29, 2008 02:10 AM
Take out the shifter grab the shift rod with needle nose Visegrips or some baling wire. If you can lift it up and down about 1/4" you have a bad shift rod bushing. Replace the rear coupler bushing under the rear seat with the Sway Away red urethane pieces. I have seen bent shift input selector rod in the transaxle nose cone. Worn nose cone bushings are a possibility but it is also rare like the bent hockey stick. I'm partial to GB and Scat shifters since they always work out of the box vs an Empi which usually does not work out of the box. I have had good luck with the Hurst shifter but it was fairly new. Scat sell a weld in rear section of the shifter rod that is adjustable but the shifter ,rod and coupler bushing must be ok for it to work. I could check it out and get it going for you if you were nearby. If the shifter worked fine in the past, I would suspected the two bushings.
Neander
Neander
Posted: Wed Jul 30, 2008 04:58 AM
thanks guys! but i had just recently replaced the bushing near the shifter, and the coupler in the back. its the horse shoe shaped 1. BUT... the coupler is already broken and is screwed up(bad quality). so i will try the urethane 1.
and i also ran into another problem... when i try to come out of first gear i really have to punch the gas or else it will stall. as soon as i start letting off on the clutch, it basically stalls. could the clutch be mis adjusted? i've driven stock bugs, this is WAY harder to drive. it wouldn't make it up a hill from a dead stop. i am pushing big tires on it, but i don't think it would be this hard.
Posted: Wed Jul 30, 2008 05:31 PM
Big tires should only make it sluggish.
Neander
Neander
Posted: Wed Jul 30, 2008 10:43 PM
yea, thats what i thought. i replaced the clutch, pressure plate, and TOB when i put the new engine in it soo the clutch is new.
Neander
Neander
Posted: Thu Aug 07, 2008 06:03 AM
could a sloppy coupler make it do what its doing tho?
Posted: Thu Aug 07, 2008 06:17 AM
Yes put the red Sway Away ones in it.
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 7391 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion bus shifter into bug 3 ghettodish 2104 Re: bus shifter into b...
 Mon Nov 14, 2011 02:09 PM
siacs View latest post
I need some advice...
14 chayes 8684 Re: Baja problems ? ?
 Tue Jun 22, 2010 11:32 PM
No new posts VW Volkswagen & Baja Bug General Discussion brake and aftermarket oil sump problems 5 milleraj119 3233 brake and aftermarket ...
 Thu May 14, 2009 03:17 PM
No new posts VW Volkswagen & Baja Bug General Discussion Carb problems 5 MusicManiac 2090 Re: Carb problems
 Mon Sep 22, 2008 03:10 AM
57baja View latest post
