Visitors: 102
Total: 102
15: Event Calendar
25: Pictures
45: Event Calendar
49: Home
51: Pictures
63: Home
78: Event Calendar
84: Pictures
94: Home
95: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Jumped it way to high!
JumpinBruceB
JumpinBruceB
Post Post subject: Jumped it way to high!
Posted: Sat Jul 26, 2008 01:12 AM
So im new to the forum and pretty new to the baja world as well. I have 1970 baja and while throwin a few back in the woods i thought it would be a good idea to jump a table top at 45...Long story short the pan is bent and will not alow the transmission to shift. So as for the question I have for you all is Do i take the time to replace the pan or just swap the motor into somethin different? What kinda work am I lookin at to replace the pan (now i know this is no small job)? Hopefully you guys can shed some light on the subject..... Very Happy
Post Post subject: Re: Jumped it way to high!
Posted: Sat Jul 26, 2008 03:40 AM
I have a hard time you'd bend a pan without bending the body, too. Maybe it's just the frame horns?
JumpinBruceB
JumpinBruceB
Posted: Sat Jul 26, 2008 03:50 AM
I thought of that actually and I will double check but i dont think thats it. I came down really hard on the front bar any other thoughts
Posted: Sat Jul 26, 2008 04:20 AM
JumpinBruceB wrote:
...any other thoughts
Ummm- don't drink and drive maybe? (Even off road). You asked. Laughing
I'd have to agree- bending the pan without bending the body seems unlikely. If the body is tweaked also, then scrap it or swap the motor into something else. I'd think it'd be hard to straighten a pan- as cheap as they are, IF only the pan was bent, pans aren't that hard to come by. OR, if your car is monetarily worth saving, buying a whole flippin' car (clunker) just for the pan would even be an option.
JumpinBruceB
JumpinBruceB
Posted: Sat Jul 26, 2008 05:21 AM
HAHA alright i deserved that one for sure. Yea it is worth saving for the moment and that was my plan i found one already but now that im getting second opinions that it is unlikely the pan just bent then im not sure what to do...thanks for the help i will get back tomorrow after taking a little closer look at it.
Posted: Sat Jul 26, 2008 09:04 AM
I'm betting it's the frame horns.
Posted: Sat Jul 26, 2008 03:46 PM
I have bent a frame in the middle. The pans on the side are flexible and the body was fine the doors still work ok not the best. this baja is long gone. I think it was 1991 or 1992.
JumpinBruceB
JumpinBruceB
Posted: Thu Aug 07, 2008 05:15 AM
ok finally got the baja home and pictures off the camera. You guys tell me what you think is bent based on the pics...
as you can see the engine is tweaked way to the left
here are a few pictures under...couldnt tell which one gave the best perspective
oh and here is what the broken tran looked like
Posted: Thu Aug 07, 2008 07:52 AM
DOH!!!
Posted: Thu Aug 07, 2008 08:10 AM
Oh gosh. That tranny has seen better days.
It looks to be like the frame horns are twisted. It's hard to tell. The torsion housing looks parallel to the body but your engine hanger looks like it's not parallel to the torsion housing.
A couple of things...
You look like you have a saggy ass end and need to adjust the spring plates to get you more clearance. Either that or your torsion bars are broken or worse... the torsion housing is broken. My guess is that it's just torsion adjustment, though. That's not part of this problem, of course. I thought I'd mention it, though.
If one of the frame horns is bent, which I suspect, I suppose I'd start by pulling the engine and trans. It can be done in less than an hour, but then again, I've done it so many times that it may take you a bit longer. I'd probably take very careful measurements between each of the frame horns to the shock towers. I'd also inspect the welds where the frame horns meet the torsion housing. Then, I'd probably take a floor jack and jack the whole car up my the lower frame horn until it's even with the other one, then just a hair more (maybe 3/16""). I'd weld a 1-1/2" piece of steel tubing from the frame horns (just ahead of where the CV joint is on the transmission) to the shock towers. While the jack is under it it, I'd reinforce the shock towers, since you will be putting a lot of stress on them by doing this. The right way to do it is to put a cage in the whole thing and tie that in to your shock tower, too. If you cant, you might consider running a 1-1/2" tube from tower to tower over the tranny, so at least you'll have some additional support from the other side.
Sounds like you got yourself into a helluva mess. It can be fixed in a day (a long day!) but hopefully you learned something. Don't jump your car without a well built cage and some serious mods.
Change those goofy bumper mounts while you have the welder out.
Posted: Thu Aug 07, 2008 05:13 PM
Definitely need some more tension on your torsions- your clearance is low, but also your travel is limited by the low setting. When you jump the car with little travel, the suspension bottoms out sooner and leaves the rest of the car to absorb the remaining energy. Guess what THAT translates to? Yep, broke/bent stuff! (See pics above) Laughing
Now, I'm not saying that more clearance/travel would have prevented this, BUT it certainly would have helped reduce the stresses on the drivetrain/suspension AFTER the suspension bottomed out.
Hope you've got a money tree in your backyard! Because if you're going to routinely drive that car that hard, you're going to need beaucoup bucks for either 1) massive suspension upgrades or 2) frequent extensive repairs! Shocked
Good luck! Keep us posted on your progress with the fix.
Posted: Thu Aug 07, 2008 07:51 PM
There is no such thing as too high just not enough suspension. I use a anchor mount in concrete to chain a frame to the ground and use a jack to lift raise the up again. a 8x8 steel plate with chain welded to it mounted with wedge anchor bolts will work.
JumpinBruceB
JumpinBruceB
Posted: Tue Aug 26, 2008 10:09 PM
ok so i know it took me a while to get back to this but here i am the engine and tran are out and the frame horn is deff bent. It looks like the right one is like 3/4" higher on the very end of it the left one. I do believe the back end did bottom out and this is what bent the frame horn up. But I can not get the frame horn to bend at all. I tried jacking it up by the lower one but no movement and i actually think that the lower one is the straight one. So i dont know what to do here if you guys have any kind of ideas i will take them. I tried a big azz pipe on the end of it and that didnt really do much and i thought about heat but i dont want to weakin the metal. All help would be appreciated.....thanks. and yes i know im an idiot for getting my self into this mess haha
oldfart
oldfart
Posted: Wed Aug 27, 2008 05:05 AM
Working at home with limited tools, chain downs etc....I'd strongly recommend getting a different pan. It's not that big of a deal to swap out, just need about 6 strong buddies or a forklift.....naw really, it ain't that big a deal. Give you a chance to start with a new foundation, rebuild some stuff and paint it all pretty.
You can have everything unbolted in about 2 hours without a impact wrench. Engine and trans already out...piece of cake.
BTW....what part of Denver? Lived there 23 years, haven't been back since 1987 or so.
Posted: Thu Aug 28, 2008 09:43 AM
What if you run a chain up and around one (or both) of your shock towers and fasten it to a floor jack... kind of like you would do while setting your rear spring plates, only put the jack under the frame horn instead.
It's a thought.
No new posts VW Volkswagen & Baja Bug General Discussion Need Help....Dash lights go out when I switch to high beams 2 jemizasi 2609 Re: Need Help....Dash ...
 Thu Nov 10, 2011 06:55 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Anyone going to Flagstaff for the High Altitude VW Kampout? 12 biblethumpncop 4049 Re: Anyone going to Fl...
 Wed Aug 06, 2008 04:57 AM
No new posts Events and Get Togethers World Wide Anyone going to Flagstaff for the High Altitude VW Kampout? 2 biblethumpncop 2291 Re: Anyone going to Fl...
 Sun Jul 27, 2008 11:34 PM
biblethumpncop View latest post
No new posts VW Volkswagen & Baja Bug General Discussion high (lol( 5 i gained rank!!!!!!!!!!!!!!
18 blood_red_baja 5387 Re: high (lol( 5 i gai...
 Tue Mar 04, 2008 03:53 PM
blood_red_baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion cam with high ratio rockers? 1 nube_w_1970baja 1353 Re: cam with high rati...
 Fri Nov 30, 2007 02:53 PM
unlimited View latest post
