Visitors: 87
Total: 87
05: Event Calendar
08: Event Calendar
38: Pictures
50: Event Calendar
72: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 12v flywheel / 6v trans
r8rfan66
r8rfan66
Post Post subject: 12v flywheel / 6v trans
Posted: Sat Jul 12, 2008 06:09 AM
Trying to install a rebuilt engine w/12v flywheel. I'm having more difficulty than usual getting the trans to mate up. This is an all new set-up to me, the engine is a new-rebuilt longblock and the trans I bought awhile back. The guy told me it was a flyer.
I guess my question is; will a 12v flywheel fit a 6v trans without modifying the bell housing?? It's the only thing I can think of that would prevent the engine from slippin on in...
Post Post subject: Re: 12v flywheel / 6v trans
Posted: Sat Jul 12, 2008 07:32 AM
No. You have to grind out the extra material.
r8rfan66
r8rfan66
Posted: Sat Jul 12, 2008 08:09 PM
you mean the material over the lower bolt holes in the bellhousing? Or do I need to go all the way around the bell housing? Thanks for the help! I gotta get this thin on the road.. $4.60/gal in So. Ca!
Posted: Sun Jul 13, 2008 07:35 AM
It's not all the way around. I'll look of a link to an explaination of how to do this.
Posted: Sun Jul 13, 2008 07:52 AM
Sorry, I can't find the picture. The best I can tell you is to line up the fly whell and determine where to grind. I have heard some people will line up the engine and use the flywheel to scratch in a groove that tell them were to grind.
r8rfan66
r8rfan66
Posted: Sun Jul 13, 2008 08:46 PM
Cool, I'll give that a try. Thanks for the help!
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2893 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion Changing over to 3-rib bus trans... maybe? 10 planenutz 5868 Changing over to 3-rib...
 Wed Jan 18, 2012 08:20 AM
planenutz View latest post
17 TwistedMetal 13783 Which trans with a 22r...
 Mon Dec 05, 2011 01:51 AM
chrispy56 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Instructions to install 002 trans. in 1969 1600 Baja?J 12 glenf 11092 Re: Instructions to in...
 Fri Apr 24, 2009 06:45 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion trans adapter for 1.6 hyundai motor 1 trumpit 1900 Re: trans adapter for ...
 Wed Dec 17, 2008 05:03 PM
