Visitors: 110
Total: 110
02: Home
11: Event Calendar
18: Event Calendar
89: Event Calendar
94: Event Calendar
99: Event Calendar
100: Event Calendar
101: Event Calendar
107: Home
109: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Baja gas tank behind back seat
flyboy942003
flyboy942003
Post Post subject: Baja gas tank behind back seat
Posted: Thu Jul 03, 2008 10:25 PM
Probably a stupid question but whats out there for a fuel tank to fit behind the back seat? I have a one peice front end w the battery and a spare tire under the hood so the fuel tank has to be moved behind the back seat. Theres all ready a fuel cap/tube installed to put fuel in but all the tanks Im finding on line are fit for just a cap and not to hook a hose to. Any ideas? I could always just have the aluminum tank neck cut off and a bung welded on.
tody
tody
Post Post subject: Re: Baja gas tank behind back seat
Posted: Thu Jul 03, 2008 10:44 PM
i think you can mount a small fuel cell, like 10 gallons. move it all the way against the firewall, and you might be able to put in a bench. here is a baja with a 10 gal fuel cell, and it looks like there is enough room for some seats.
the picture doesnt show much space but there is quite a bit
"A good plan violently executed now is better than a perfect plan executed next week."
"A pint of sweat, saves a gallon of blood."
-- George S. Patton
flyboy942003
flyboy942003
Posted: Thu Jul 03, 2008 11:08 PM
thats exactly what I need just where do I get it? Like I said its probably an absolute stupid question but there it is.... Thanks for the pic
flyboy942003
flyboy942003
Posted: Thu Jul 03, 2008 11:28 PM
Never mind Im completely stupid. Just got onto Summit and found a bunch of them. Looks like I can fit a 15 gallon and still have room for the back seat. Thanks for not laughing at me.
tody
tody
Posted: Thu Jul 03, 2008 11:55 PM
your welcome, you might even be able to have 1 custom made if you found the right place.
or you could build your own and have these guys build a bladder for it.
www.aerotechservicesin...ices.shtml
i saw these guys at an offroad show, and they said you build a fuel cell to your needs, any shape or size and they will build a bladder for it and a fuel cap. pretty cool
-- George S. Patton
Posted: Fri Jul 04, 2008 09:04 PM
A VW T-2 tank also fits there. I weld the filler door and tube from a T-1 into the 1/4 panel.
flyboy942003
flyboy942003
Posted: Fri Jul 04, 2008 10:10 PM
I have the fliler installed all ready, its an old charger filler neck w the flipper to it. It looks pretty trick. Now I just need the gas tank. You say the Type 2 will fit behind the back seat? You have any pics of that?
Posted: Fri Jul 04, 2008 10:48 PM
I will get you some. I have done several. Baja #4 has one installed but it not at the house.
flyboy942003
flyboy942003
Posted: Sat Jul 05, 2008 06:29 PM
Is there any certain year to go for? Not really familiar w type 2's
Posted: Sat Jul 05, 2008 09:34 PM
68-79, 68-74 are the easiest since they are set up for carbs. 75-79 require plugging the return line not a big deal.
Posted: Tue Jul 08, 2008 07:01 AM
I looked at the one I started I had not made the mount yet. I used 1x1 angle or square tubing and 1"x1/8" straps. On the ones that were not attached to a cage I welded 5/16" id diameter tubing throught the 1" to keep it from crushing. I made 3x3 x1/8" washers from flat stock on both sides to keep it from pulling though the fire wall and floor.
Posted: Tue Jul 08, 2008 08:21 AM
I'm digging this thread! Mine is a 12 gallon marine tank and it fits behind my seat, but it's kinda cool to know about the T2 thing. Post some pics when you get a chance!
flyboy942003
flyboy942003
Posted: Tue Jul 08, 2008 10:43 PM
I was thinking of just going with an RCI 16 gallon set up, it has the sender and all that as well as the straps in one easy set up. Plus I think it would look trick sitting behind the seat. Seems like the measurements would almost be perfect for the application.
Posted: Wed Jul 09, 2008 05:06 AM
Its sounds like the way to go. I always had T-2 tanks around and tubing was cheap..
5 Admin_AzBaja 8397 Baja Bugs on Wiki need...
1569 mufasavnvmc 1061777 Re: what did you do to...
 Sat May 11, 2019 07:20 PM
285 MusicManiac 255976 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion FREE VW BAJA'S 0 azdesertrat87 1252 FREE VW BAJA'S
0 Northmountainauto 2193 Shop Baja
