Latest: strike77
Overall: 3575
Visitors: 119
Total: 119
39: Event Calendar
70: Home
88: Pictures
98: Event Calendar
107: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bug engine trouble??????
70bug
70bug
Post Post subject: bug engine trouble??????
Posted: Tue Jun 24, 2008 10:10 PM
my baja seems to be running very hot and it backfires through the carb and exhaust i have adjusted all of the valves ran checked them again i even made them a little loose because a tappy valve is a happy valve the engine is cold at that point. this is my first bug and im not to sure of all the ends and out of this engine so any advise will be greatly appreciated.
mg_277
mg_277
Post Post subject: Re: bug engine trouble??????
Posted: Tue Jun 24, 2008 11:41 PM
sounds like you timing maybe off.... i'm no mechanic so can't really be sure but i'd check it>
Posted: Wed Jun 25, 2008 12:41 AM
Your running lean.
70bug
70bug
Posted: Wed Jun 25, 2008 01:01 AM
fatten up the mixture and i should be good.
Posted: Wed Jun 25, 2008 01:17 AM
If nothing was done and it started running lean check for cracked boots vacuum leak at the end castings or manifold, that is important cause leaning it up will not fix the problem if there is a leak. If not then yes some adjustments are in order and also check the timing as suggested by mg_277. If you are running stock push rods then adjust to 006 if chro molly go loose 0 but don't just loosen for the sake of loosening.
70bug
70bug
Posted: Wed Jun 25, 2008 01:26 AM
on the intake manifold there is a nipple where it looks like a hose should be there thats probally one of the vacumm lines there but i will check the rest.
VIN70
VIN70
Posted: Wed Jun 25, 2008 02:14 AM
you want that nipple to be plugged.
Posted: Wed Jun 25, 2008 06:55 AM
Oh heavens yes. Plug that nipple off. I'm not exaggerating when I way that you will destroy a VW engine in a matter of a few miles (maybe even sooner than that) if you run it too lean and/or overheat it. WHen you say it's running hot, do you have temp gauges, and if so, what are they reading?
70bug
70bug
Posted: Thu Jun 26, 2008 01:30 AM
ok so check this out i pulled the cylynder heads today they looked good besides one valve seat was gone on the number one cylinder exhaust valve then i remember looking at a post about the chromoly push rods so i checked mine and they are chromoly so i have been doing valve clearances for steel push rods great but anyways what tolerances do i use with chromoly push rods????????????????????????????????????? thank you
Posted: Thu Jun 26, 2008 03:27 AM
Leatherneck wrote:
if chromolly go loose 0 but don't just loosen for the sake of loosening.
70bug
70bug
Posted: Thu Jun 26, 2008 05:14 PM
ok what is loose 0 i have never heard of this before if you could walk me through it thanks
oldfart
oldfart
Posted: Thu Jun 26, 2008 05:24 PM
you sure it was #1 cylinder bad valve seat, not #3? Left front, closest to the driver is #3. just checking.
70bug
70bug
Posted: Thu Jun 26, 2008 07:24 PM
yea its #1 passenger side front. do you know anything about the loose 0
70bug
70bug
Posted: Thu Jun 26, 2008 07:26 PM
old where abouts in sierra vista do you live im in vail, az
Posted: Sun Jun 29, 2008 07:01 AM
"Loose zero", or "Soft Zero" refers to running your valves with no play at all between the rocker arm and the valve at all. When you adjust the valves with chromoly pushrods, you want to run the adjustment tight enough that there is absolutely no movement between these parts, but loose enough that you can grab the pushrod between your thumb and forefinger and swivel it when the rocker arm adjuster is tightened down. Do this, of course, when the engine is cold.
BTW, I wouldn't run chromoly pushrods unless you really need to... like if running a hot cam, ration rockers, and dual springs. I'd run the aluminum pushrods on most engines.
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 574 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 1116 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 1729 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 1894 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 4106 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
