Visitors: 117
Total: 117
14: Pictures
28: Event Calendar
45: Event Calendar
67: Home
68: Home
69: Home
77: Event Calendar
90: Pictures
95: My Account
112: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Intake Manifold Temp
r8rfan66
r8rfan66
Post Post subject: Intake Manifold Temp
Posted: Sun Jun 15, 2008 07:57 PM
I was wanting to paint my intake manifold on my stock 1600 sp (converted to doghouse) and was wondering if I could get away with using something other than high temp paint. The aluminum colored paint I want to use is good up to 200 degrees....
As always, thanks for any suggestions.
Post Post subject: Re: Intake Manifold Temp
Posted: Sun Jun 15, 2008 08:12 PM
I wouldn't think that the intake manifolds get to over 200*, except in the area of the flange where they attach to the cylinder head. That's probably going to be your problem area right there.
Have them hi-temp powdercoated instead maybe....
Posted: Sun Jun 15, 2008 08:23 PM
intakes run cool, in fact you cn have them freeze and build up frost. The castings of the DP head might get hot, but the runners down from the carb will be cool. Air & Fuel and Vacuum make a real nice evap type cooler inside the intakes. That is why you have the little pre heater tubes.
I think your safe.
r8rfan66
r8rfan66
Posted: Sun Jun 15, 2008 08:45 PM
Thanks guys! ..just had my tins powdercoated last week as a matter of fact, a cool red color. It was a bit pri$ey, but the guy did an excellent job! I have some high-temp paint that's "silver", but it has that BBQ look about it that says; "CHEESE!!!". I'll go with the aluminum color..
By the way, can you suggest a good way/tool to use to tighten that hard to get nut at the base of the intake on the flange?
r8rfan66
r8rfan66
Posted: Sun Jun 15, 2008 08:48 PM
down on the head flange...
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 2058 Re: Carb Intake Covers
 Tue Jan 10, 2012 11:46 PM
Gunpilot View latest post
No new posts VW Volkswagen & Baja Bug General Discussion manifold heat
again...
4 DeathBug 2167 Re: manifold heat
 Tue Nov 15, 2011 01:31 AM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb and intake setup? 11 Torg37 6809 Carb and intake setup?
 Fri Feb 05, 2010 03:26 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Where to put oil temp sender? 1 catchbats 1802 Re: Where to put oil t...
 Sat Dec 27, 2008 05:46 PM
No new posts VW Volkswagen & Baja Bug General Discussion engine exhaust temp? 4 cperry2704 1891 Re: engine exhaust tem...
 Mon Apr 14, 2008 12:17 AM
macbaine View latest post
