Latest: hulkbaja
Overall: 3594
Visitors: 86
Total: 86
12: Pictures
33: My Account
73: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- swingaxel conversion to irs in process NEED HELP
90xjlimited4x4
90xjlimited4x4
Post Post subject: swingaxel conversion to irs in process NEED HELP
Posted: Fri Jun 13, 2008 01:50 AM
ok i barrowed a irs pivot jig its way way off!!!!!! i bolted evertythiong together and now i need opinions this look right?
pivot mount connected to arm
arm and pivot
degrees at 91 on flat spot of body
dregrees at 91 on drum backing plate mount
im winging it cause the jig sets the mount in to far.... any one know if this looks right?
Post Post subject: Re: swingaxel conversion to irs in process NEED HELP
Posted: Fri Jun 13, 2008 07:26 AM
Looks about right.
90xjlimited4x4
90xjlimited4x4
Posted: Fri Jun 13, 2008 07:38 AM
kk i will tack it in tommorow and start on the other side! im measureing camber at 1 inche above full droop... i figure the torsions will sag about that much.... maybe a little more....
whats better negative or positive?.?.?.
Posted: Fri Jun 13, 2008 11:09 PM
i agree with mike....looks ok
you can bolt up the torsion plate ok ?
90xjlimited4x4
90xjlimited4x4
Posted: Sat Jun 14, 2008 12:06 AM
ya i put the bushings in with the spring plate (no torsion bars) checked how level the car was used that measurement as my level... then checked the 3x3's where the brake backing plate would mount at 1 inch above full droop its a 0 degrees right there........ so as long as im right in my thinking at ride hight it will be 0 camber which is good as far as i know...
but of course this being my first time doing anything of this kind and going off what i know (which isnt a huge amount) and winging it the rest of the way im unsure if i should weld it up and call it good!...
No new posts Projects and Builds my 74 Ghia conversion 3 _-Mad-Max-_ 3113 my 74 Ghia conversion
 Sat Jul 20, 2013 12:08 AM
_-Mad-Max-_ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin Conversion 8 Bryman042 6761 Re: Link Pin Conversio...
 Thu Jun 23, 2011 12:41 AM
Bryman042 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Mazda 13b Turbo Conversion 2 logan44 3603 Mazda 13b Turbo Conver...
 Tue Jun 21, 2011 09:00 PM
HuggingxCorners View latest post
No new posts VW Volkswagen & Baja Bug General Discussion baja body conversion...? 2 thext94 1717 baja body conversion.....
 Fri Jan 29, 2010 04:24 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion type 1 to 091 conversion? 5 nube_w_1970baja 6325 type 1 to 091 conversi...
 Fri Jan 23, 2009 04:55 AM
1FASTHOE View latest post
