Visitors: 116
Total: 116
55: Home
59: Event Calendar
104: Event Calendar
112: Event Calendar
113: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- shocks for stock swing axle and stock beam
Post Post subject: shocks for stock swing axle and stock beam
Posted: Tue Jun 10, 2008 06:10 AM
I want good cheap shocks.
5150? KYB?
Post Post subject: Re: shocks for stock swing axle and stock beam
Posted: Tue Jun 10, 2008 06:19 PM
KYB first step up
Bilstein next step above that.
Posted: Tue Jun 10, 2008 07:21 PM
I've got a pair of almost-new KYBs for sale. The ad is in the sale forum. $35 shipped.
Posted: Tue Jun 10, 2008 11:32 PM
For how many?
fatalifeaten
fatalifeaten
Posted: Tue Jun 10, 2008 11:39 PM
Erm... "A Pair" usually means 2...
--Harlan Ellison
Posted: Tue Jun 10, 2008 11:44 PM
Oops. Didnt even notice that.
Arent front KYB have stud tops up front, and eyes on the rear?
fatalifeaten
fatalifeaten
Posted: Tue Jun 10, 2008 11:56 PM
correct. Fronts are stud top, rears are eye top. Both are eye bottom.
Are you looking for a stock ride or baja? KYB's are STIFF for a stock application. Oil filled are smoother for stock.
--Harlan Ellison
Posted: Wed Jun 11, 2008 12:39 AM
BAJA.
Posted: Wed Jun 11, 2008 03:00 AM
These are GR-2, and they're for LP front end. They have eyes both top and bottom (I'm assuming by "eyes" you mean bolt holes instead of studs).
Posted: Wed Jun 11, 2008 03:09 AM
Dayum. I got ball joint. Yes Eyes= bolt holes.
Posted: Fri Jul 25, 2008 03:58 AM
Looking for good used KYBs, or similar priced shock (BJ and SA suspension)
I need cheap, even monroes are better then my shocks!!
No new posts VW Volkswagen & Baja Bug General Discussion Bent beam 1 cperry2704 544 Bent beam
 Tue May 30, 2017 03:38 AM
JWHracing View latest post
16 DerekT 2476 Axle's needed
 Sat Dec 10, 2016 06:17 PM
24 Kreed 20706 3" Body Lift, Class 11...
 Mon Apr 18, 2016 04:44 PM
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 3018 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
1 suburbangorilla 2711 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
