Latest: xbluegto
Overall: 3573
Visitors: 243
Total: 243
54: Event Calendar
76: Event Calendar
79: Event Calendar
149: Event Calendar
164: Baja Forums
168: Baja Forums
172: Baja Forums
180: Baja Forums
183: Baja Forums
190: AMAZON.com
193: Baja Forums
195: Baja Forums
197: AMAZON.com
198: Baja Forums
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
206: Baja Forums
207: AMAZON.com
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
212: Baja Forums
213: AMAZON.com
214: AMAZON.com
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: AMAZON.com
225: Baja Forums
226: AMAZON.com
227: AMAZON.com
229: AMAZON.com
230: Baja Forums
231: AMAZON.com
232: AMAZON.com
233: AMAZON.com
234: Baja Forums
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: AMAZON.com
239: Baja Forums
240: AMAZON.com
241: AMAZON.com
242: AMAZON.com
243: AMAZON.com
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Baja #2
Baja #2
Post Post subject: Baja #2
Posted: Tue Jun 03, 2008 07:37 AM
Heres another Baja that should of been driven and not painted. A friend gave up on it, when he traded his turbo engine for a cage 3x3 arms, Vanagon transaxle and a 16v VW engine. It never ran and he sold it to me.
I installed a 3 rib T-2 transaxle used 1915 air cooled engine. I sold the 16 valve engine and Kennedy adapter.
The drivers 1/4 panel had to be replaced. The old one had over 2 gallons of bondo in it.
It had hit everything but the lottery.
Time for a few patterns.
Nothing like a tight fit.
I was able to sand blast most of the rust off in the cavity and paint it before welding the new patch in place.
Can you say tweeker with a drill.
Some rocket scientist decided to fill the A-pillar cavity to the top with self expanding foam.
Resulitng in this.
Even the lower hinge was severely rusted.
I think they were trying to keep this stuff from rattling.
Some one bolted a roof rack to the roof. Bad idea. Note the beautiful crazed red lacquer paint.
After sand blasting the interior and trunk I ended up spending over three hours with the air nozzle bowing sand out of the heater channels and other cavities, vacuuming out about 200#s of sand.
When I bought the Baja someone had cut out the rear trunk to install the cage. The replacement id made from a VW Rabbit roof. Its made of 4 pieces. The left and right were formed by making a wooden buck that fit the contours of the left and right 1/4 panels.
For $275.00 the friend I bought the Baja from had the VW dealer in Guadalhara, Mexico install two piece hub and disc brakes and 7.00 15 front tires.
I widened the beam 9". It will get four supports added from it to the cage for support.
It has old school widened stock wheels and 33x12.50 BFG's.
The A pillar and dash are looking better.
New inner lf fender patch.
It will be a lot easier to finish the passenger door off the Baja.
There were a lot of cracked body parts. Three on the drivers door.
Post Post subject: Re: Baja #2
Posted: Tue Jun 03, 2008 08:38 AM
That thing's pretty damn cool, man.
Posted: Tue Jun 03, 2008 07:12 PM
cool
keep us updated with pics
Posted: Wed Jun 04, 2008 03:15 AM
looks like you been busy, keep it up.... Razz
Posted: Wed Jun 04, 2008 03:40 AM
Is it just me, or does that front tire/wheel look like it weighs like 400 pounds? Weird how the look of the tire can give the impression of mass weight...
Lookin' good though, perrib! You've got a LOT of time invested in that thing it appears.
Posted: Wed Jun 04, 2008 04:08 AM
THey weigh about the same as my 700x15 Yokahamas
Posted: Wed Jun 04, 2008 05:46 AM
With all that work is it going to be a driver or looker? Either way going to be nice.
70bug
70bug
Posted: Thu Jun 26, 2008 02:51 PM
look really good when is it going to be done! Very Happy
Posted: Fri Jul 04, 2008 06:13 AM
Its been 114 degress here so work on it has slowed way down. I will probably just sell it.
Posted: Fri Jul 04, 2008 02:39 PM
WHAT!?!?!? SELL IT? Shocked
After all that work, looks pretty close to done. Don't give up yet..
Posted: Fri Jul 04, 2008 08:53 PM
Locutisj
It will get finished and see some street usage before getting sold. It will be painted the same colors as Baja #1.
The body work is only close to being done compared to time served.The camera hides what the block reveals. There is at least another 20 hours of priming and block sanding left excluding the hood and nose before it can head to the paint booth. Four more bars are still needed to connect the cage to the wider front beam. A 2387 will provide the torque to motivate it.
Posted: Sun Jul 06, 2008 07:06 PM
Hot out side??? We put new wheels and tires on the van...I just forgot how hot out side it can be.
Posted: Sun Jul 06, 2008 08:10 PM
Normally I can but we spent the last three weeks in Lakeside and its requiring more time than I planed to get acclimated to being back in hell.
4 Admin_AzBaja 5713 Baja Bugs on Wiki need...
1568 mufasavnvmc 903623 Re: what did you do to...
285 MusicManiac 218973 Re: Baja sightings
0 Northmountainauto 268 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 1517 Baja hiding in Chandle...
