Visitors: 151
Total: 151
23: Event Calendar
42: Pictures
83: My Account
94: Event Calendar
109: Event Calendar
114: Pictures
130: Event Calendar
150: Baja Forums
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- Hedrock's 'vert project
1 2 3 ... 10 11 12 ... 14 15 16
The following users give thanks for this topic Anonymous - Tue Mar 17, 2009 12:48 PM
Post Post subject: Re: Hedrock's 'vert project
Posted: Tue May 20, 2008 03:34 PM
dang that is a good idea
Posted: Tue May 20, 2008 04:43 PM
Ice chest/Rubermade boxes etc. Budy used to call them adventur moduals. He had them set up for snow, summer, river, mud, rock crawl etc. so what ever type of 4x4 trip he would go on he would pull out the proper adventur modual that ad all the stuff he needed for that type of off road trip. All had invanory sheets etc. so he could restock or add things that he might need or did not have. When he got back home the Adventur modual went on the shelf and he was back in daily driver mode.
They have a name for that behavior- it's called "Obsessive-Compulsive Disorder". Laughing That's just wayyyy to anal/organized! I wish I was HALF that prepared!
But the cooler rack in the back of the car- definitely slick.
Posted: Mon Jun 02, 2008 04:11 AM
Well, I have been doing a bunch of body work on my car the last few days and some parts gathering. The latest was this oil cooler. After I got the cooler I realized that the two ice chests were going to have to go Sad . I will keep one and I'm planning to enclose the area around the ice chest and oil cooler for storage now. I will post pics when I'm finished.
New to me cooler... 13"x13"x3.5".......Fan pulls from the back
Cooler mounted...
I'll post more as work is completed... Wink
Posted: Mon Jun 02, 2008 05:03 AM
looks damn good hedrock. maybe i might be able to have that well made of a baja!
Posted: Mon Jun 02, 2008 05:07 AM
looks good i cant wait to see the finished bug.
Posted: Mon Jun 02, 2008 05:34 AM
not much of the "BUG" left!!
Posted: Mon Jun 02, 2008 07:18 AM
Once the body is put back on the Baja will shine through, he is going about it the right way, protection where it is needed and performance where it counts.
Posted: Sun Jun 08, 2008 06:42 PM
A little more body work done. I'm planning on putting the door glass back in someday so I will leave them open.
Done...
Also started on the roof. Here's a pic with it just clamped on. I will trim the windshield frame down just a tad to take a little of the curve out.
Posted: Sun Jun 08, 2008 07:06 PM
Just make sure you make that roof rack big enough to carry all my spare parts.
VIN70
VIN70
Posted: Mon Jun 09, 2008 03:16 AM
who made those rear arms?? 3x3?? also what springs on the rear??
Posted: Tue Jun 17, 2008 04:31 AM
Still plugg'in away.... Finally put the body on for the last time and started working on the mounts. Due to not having any heater channels mounting the body wasn't as straight forward as I would have liked. I still need to add some mounts to the "A" pillar and my flared hole pieces to the rocker area.
The heater channel was cut out some time ago and I welded in a piece of 1 1/2" X 2" square tubing along the under side of the door.
Next I had a piece of 3/16" metal bent like a 3 x 4 angle iron and put it from the outside of the square tubing and set the other side on the pan like normal.
It turned out real clean... I just need to finish welding it at the door.
I also added my shifter mount and box. Here are a couple of different views...
And I even had a little time for some goof'in off. Took all of the shocks off to see what it would look like at full compression front and back at the same time...(like that could ever happen) Wink .
I think I need to do a little fender trimm'in... What do you think Leather Wink
VIN... I'm not sure on the rear arms... They are 3x3"s and the rear springs are 300/350. These springs came from some one that had an ACVW and switched to a water pumper. He told me that they worked real well on his car until he did the conversion... and the price was right Wink
I'll keep posting as more work is done... Brian
Posted: Tue Jun 17, 2008 05:08 AM
Holy jeez!!!
that thing is ridicuolous!!!!
Posted: Tue Jun 17, 2008 05:22 AM
what paint colors are you thinkin bout ???
Posted: Tue Jun 17, 2008 05:26 AM
Body will be "new beetle blue" and the frame light gray. Engine tin will be blue also.
Posted: Tue Jun 17, 2008 05:41 AM
Any graffix?
1199 Dalton 339399 My 69 project
No new posts Projects and Builds Project Purple People Eater 4 Yasha7fold 3382 Project Purple People ...
88 Dirtjunkie 62708 Project II
65 PaDan 57053 Re: My project
 Thu Feb 11, 2016 06:07 PM
No new posts Projects and Builds project 6911 (aka) JINX 10 TINMAN 8334 Re: new project
