Latest: Milkmanbryan
Overall: 3583
Visitors: 131
Total: 131
11: Event Calendar
16: Event Calendar
19: Event Calendar
40: Drivers
42: Event Calendar
54: Pictures
67: Event Calendar
72: Event Calendar
123: My Account
129: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cut and turn issues
cut and turn issues
Patzke
Patzke
Post Post subject: cut and turn issues
Posted: Fri May 30, 2008 12:28 AM
cut and turned front axle, primed it, painted it, looks great and works great.... on the right side. Wink or maybe its the left....
WAS CUT AND TURNED 1/4" (.25")
the left side is a crap load stiffer than the right. I jump on the left, it goes down, and the car hops up about an inch. (very stiff and springy). jump on the right side, the car sags, comes up very spunky like, but doesn't jump off the ground. both sides DO NOT sag when cars weight is on.
Sum it up:
Left - very springy
Right - not so springy
Where is my problem? Left or right side, and why?
Post Post subject: Re: cut and turn issues
Posted: Fri May 30, 2008 12:34 AM
Balljoint or linkpin?
Posted: Fri May 30, 2008 02:25 AM
this might help you,
www.azbaja.com/Forums/...=3445.html
had kinda the same problem, kinda.
but theres a boat load of info
Posted: Fri May 30, 2008 03:21 AM
How old are the leaves, where/are they in good shape?
Patzke
Patzke
Posted: Fri May 30, 2008 07:31 AM
BJ.
as far as i know the leaves are original from 1971
they were in good shape as far as i know
bottom middle leaf was broken exactly in the middle.
Posted: Fri May 30, 2008 07:44 AM
Without shocks what does it do? Maybe a shock is binding? Along the same thought as BugZ was headed down... Maybe you have a bent component in your K/L set-up that's binding? Maybe oneof your arms is bent inside the housing and binding? Start taking things off and try to isolate it to a specific component.
Patzke
Patzke
Posted: Fri May 30, 2008 08:31 AM
Shocks are off.
When cutting and turning, I removed everything.
When reinstalling, i put the torsion leaves back in place followed by the trailing arms.
when reinstalling the trailing arms, on both sides i had to use motorcycle straps to pull them up enough to fit in the breaks.
both sides felt like they needed the same amount of power to pull them up...
i did the left side first - the ones that's stiffer...
Thanks for all in the input, a lot of the ideas are saying it's "binding" i feel like the stiffness isn't a "binding stiffness" but a higher preload... It's not 'binding stiff' i don't think...
Posted: Fri May 30, 2008 04:14 PM
You probably have a bad balljoint. If you just put the old balljoints back in one or more is most likely worn and can have a bad spot that could cause it to be stiff.
Patzke
Patzke
Posted: Fri May 30, 2008 08:10 PM
That could be too..
I dont suspect it to be anything binding or causing friction though. It just feels like the preload is a lot higher than it should be.
Are we looking into the wrong issue? Is the left side normal? and the right side is not as preloady as its stupose to be?
I'll get to the bottom of this soon. Any help is greatly appreciated. Smile
Patzke
Patzke
Posted: Fri May 30, 2008 08:11 PM
Opps, just remembered.
i was playing with all the balljoints before i put it together... so that rules that out unless things change with balljoints when their under pressure.
Posted: Sat May 31, 2008 12:41 AM
Did you do put new beam bushings in, when welded back together is it perfectly straight? Just asking, can't see it so have to ask questions.
Take it apart piece by piece and check each part as you take it off, if not found go to the next, if you get it all apart and see no problems switch the sides the torsions are on and see if it switches sides.
Patzke
Patzke
Posted: Sat May 31, 2008 09:30 AM
Yeah.
I think i'm going to let it be for a while, see if it fixes it's self. HAHA
If it doesn't, when i finish this task i'm working on now, i'll de-assemble it, and try and find the problem.
I'll be sure to let you all know what the issue is (if i find it).
No new posts New Members Air filter issues
Can't keep the Dust out
11 DerekT 4672 Re: Air filter issues
 Mon Oct 03, 2016 01:59 PM
No new posts VW Volkswagen & Baja Bug General Discussion Motor issues 12 Dirtjunkie 4536 Re: Motor issues
 Mon Sep 19, 2016 09:06 PM
Really bad issues
4 Pointvirus 2483 Clutch Issues
 Mon Dec 03, 2012 06:33 PM
No new posts VW Volkswagen & Baja Bug General Discussion Its my turn (picture heavy) 7 blubaron66 5795 Re: Its my turn (pictu...
 Thu May 17, 2012 12:24 AM
blubaron66 View latest post
what are yall's set'ups
7 vindeta 14005 Re: lights?????? (hea...
 Tue Oct 11, 2011 05:32 AM
